Jimmy Young
Joined: 24 Nov 2007 Posts: 182 Location: Missouri City, TX
Posted: Tue Jan 27, 2009 6:19 am Post subject: Check your Horiz. Stblzr bolts |
On pre-flight insp. Sunday, I noticed my bolts connecting my horizontal stabilizers to the boom tube had a bit of play in them. Pulled them off and saw the bolt was worn at least 35-40%. Everyone should pull them off and check them, as you can't really see it that well until you pull them out. I checked the rest of my tang bolts going to the tail feathers, and the rest were fine. Seems the bolts at the horiz. stblzrs spin around and grind a groove in them, so be sure and check!
_________________ Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700 |
Posted: Tue Jan 27, 2009 7:16 am Post subject: Check your Horiz. Stblzr bolts |
stabilizers to the boom tube had a bit of play in them. >
Quote: | --------
Jimmy Young
Jimmy:
Most all Kolbs I look at have tail wires that are too loose. I keep mine
tight as a fiddle string. I am not happy unless they make a twang when I
pluck them.
Loose tail wires would allow those 3/16 bolts to spin more than if they were
tight.
How many hours do you have on them?
If the wires are tight, you may have a vibration problem.
_________________ John Hauck
Titus, Alabama |
Jimmy Young
Posted: Tue Jan 27, 2009 9:11 am Post subject: Re:Re: Check your Horiz. Stblzr bolts |
>tight.
Hi John,
The 3/16" bolts that wore out are the ones connecting the inboard front part of the horizontal stabilizer to the boom tube. I know they spin a bit. The bolts holding on my flying wires were all fine. I do keep my wires nice and tight. My FS has 298 hrs on the airframe and 79 hrs on my new engine.
My main point to everyone was, if you don't pull them and look, you won't know if they are worn.
76 degrees (at) 11 am, cold weather is on the way later today.
Missouri City, TX
Posted: Tue Jan 27, 2009 9:43 am Post subject: Check your Horiz. Stblzr bolts |
Jimmy:
Understand.
However, the tail wires control how much pressure is exerted on the front
horizontal stabilizer attachment.
Along these same line, it is a good idea to check the cable thimbles on the
tail wire tangs. As time accumulates on the airframe, the thin edge of the
tangs will start to cut through the cable thimble. I changed mine to a
different system using different hardware. I put a lot of hours on my Kolb.
Found myself changing out tail wires more than I wanted to. Several years
ago I designed a new system. Have not had a problem since then.
Titus, Alabama |
JetPilot
Posted: Tue Jan 27, 2009 10:34 am Post subject: Re: Check your Horiz. Stblzr bolts |
Thanks for the Heads up Jimmy, it could save someones bacon one day.
To stop wear, I use Mobil 1 synthetic grease on all those bolts ( Not the threads ! ) where they move against anything. I also get the added benefit that my controls feel like they are on bearings. I do the same with the tail wire thimbles John is talking about, I like Johns tail wire hardware, and will copy it one day. In the mean time make sure there is some grease where the tail wire thimbles contact the tang and I have no noticeable wear in 200 hours or so.
Kolb MK-III Xtra, 912-S |
Jimmy Young
Posted: Tue Jan 27, 2009 11:41 am Post subject: Re:Re: Check your Horiz. Stblzr bolts |
John H said:
>Understand.
>However, the tail wires control how much pressure is exerted on the >front horizontal stabilizer attachment
As soon as I hit the send button, I realized what you meant. I got it now.
This flying wire hardware you changed to...what kind is it?
Jimmy Y
Missouri City, TX
Posted: Tue Jan 27, 2009 12:19 pm Post subject: Check your Horiz. Stblzr bolts |
Jimmy:
I probably need to take some photos and post on the List to better show how
I built my tail wire system.
I didn't use the standard SS wire tangs or the cable thimbles.
I made tangs from 4130 strap.
I used a cable pulley (that's what it looks like) with a 3/16 bolt to secure
it to the 4130 tang/fork.
I also have four turn buckle to adjust each wire. The are mounted outboard
at the top and bottom of each side of the horizontal stabilizers.
If you get right down to the real nitty gritty, the cable thimble was not
designed to be used with a thin edge tang, as used on Kolb tail wires.
Another way to get around this problem is use a 3/16 clevis with the
thimble.
Titus, Alabama |
icrashrc
Joined: 16 Mar 2006 Posts: 247 Location: Mishawaka, In
Posted: Wed Jan 28, 2009 4:01 am Post subject: Re: Check your Horiz. Stblzr bolts |
John,
Saved ya the trouble of taking pics.
Description: |
Filesize: |
58.6 KB |
Viewed: |
767 Time(s) |
Description: |
Filesize: |
44 KB |
Viewed: |
718 Time(s) |
_________________ Scott
www.ill-EagleAviation.com
do not archive |
Posted: Wed Jan 28, 2009 5:11 am Post subject: Check your Horiz. Stblzr bolts |
Morning Scott:
Great!!! Thanks, buddy.
Titus, Alabama |
Rick Lewis
Joined: 03 Jul 2007 Posts: 122 Location: Kingston, Tn.
Posted: Wed Jan 28, 2009 6:30 pm Post subject: Re: Check your Horiz. Stblzr bolts |
Jimmy
I think I know the area your talking about. I saw this could be a problem down the road with wear on the two attach bolts at the boom tube. I have attached pictures showing how I'm avoiding this problem. Your really lucky you caught this before things turned loose in flight. The bushings you see in the pictures came from Wicks, part# SF812-4 and cost less than a dollar each. Two nut plates, four rivets, two bushing and a little work is all it takes to fix it right.
Rick Lewis
Description: |
Filesize: |
148.95 KB |
Viewed: |
649 Time(s) |
Description: |
Filesize: |
168.79 KB |
Viewed: |
667 Time(s) |
Posted: Wed Jan 28, 2009 7:14 pm Post subject: Check your Horiz. Stblzr bolts |
Rick L:
I haven't experienced a problem with the elevator control mechanism.
I think the problem was up at the forward attach points.
I fixed mine with a 4130 bushing I made from a piece of 1/4" tubing with a
3/16" ID. Works good.
Again, I don't think I have photos of the installation.
Let us know how your modification works out after you get some time on them.
Titus, Alabama |
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Wed Jan 28, 2009 8:05 pm Post subject: Re: Check your Horiz. Stblzr bolts |
FWIW, the forward attach bolts for the elevator halves had the same wear on my FSII. It had about 450 hours on it when I bought it, during a routine check of the stabilizer halves I found the bolts badly grooved. In fact it was bad enough that I grounded the plane until the replacement bolts came in.
The wires were probably too loose, having read John's description. Mine didn't "guitar string" when plucked (they had the stock nicos looped through the tangs construction which was probably how they had loosened over time).... I did snug the nylocs on the new bolts up against the two ears of the brackets so the bolts couldn't rotate without a fair bit of force (but not enough to distort the ears).
I don't recall any problem with the elevator mechanism. There was a slight amount of play in one elevator half where the bolt was a little loose inside the little sleeve thingy but that was about it.
The original owner used to fold/unfold the plane a lot so that might have contributed to the extra wear on those points......
LS
_________________ LS
Titan II SS |
Jimmy Young
Posted: Thu Jan 29, 2009 2:54 am Post subject: Re:Re: Check your Horiz. Stblzr bolts |
Rick Lewis said:
>>I think I know the area your talking about.<<
Rick,
My problem was at the forward attachment point where 3/16 bolts connect the hrzntl stabilizers to the tube. I should have taken a photo.
I checked the 5/16 bolts you mentioned, along with every other bolt back there on the flying wires and control assemblies. They were all fine, but for less than $30 I ordered all new ones and am replacing them anyway.
Jimmy Y
Houston
FS II, 298 hrs/AF, 80 hrs/Twin-V
Posted: Thu Jan 29, 2009 6:13 am Post subject: Check your Horiz. Stblzr bolts |
Jimmy
I have a concern about that Genrec being bolted solid to your engine mount.
Could that be the source of your bolt ware. I see others have had some in
that area also but it sounded like yours was worse. Check your whole plane
over very carefully. I know from personal experience when my VW had
vibration issues there was a lot of stress cracking and bolt ware.
Rick Neilsen
Redrive VW powered MKIIIC
Posted: Thu Jan 29, 2009 6:37 am Post subject: Check your Horiz. Stblzr bolts |
Rick
You have been adding a lot of bushings and stuff. My concern is that all
control surface bolts that aren't tight should have castle nuts or some
other positive safety. In your photo of your tail boom you show a nut plate.
Are you planning to safety that bolt in some way? Just be very careful when
you fix things you don't make it dangerous.
Another concern is, when people get all caught up fixing everything they
work on that they never finish their planes.
Rick Neilsen
Redrive VW powered MKIIC
Posted: Thu Jan 29, 2009 6:42 am Post subject: Check your Horiz. Stblzr bolts |
mount.
Rick N:
No Lord mounts???
Titus, Alabama |
rlaird
Posted: Thu Jan 29, 2009 7:12 am Post subject: Check your Horiz. Stblzr bolts |
I've seen Jimmy's Firestar with the Generac, and that was one of the first things I noticed, too... no Lord mounts. But the engine runs -very- smooth... much smoother than any Rotax, with Lord mounts, I've ever seen.
-- Robert
On Thu, Jan 29, 2009 at 8:30 AM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
[quote] --> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
Rick N:
No Lord mounts???
" target="_blank">http://www.matronics.com/Navigator?Kolb-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Posted: Thu Jan 29, 2009 7:54 am Post subject: Check your Horiz. Stblzr bolts |
At 09:27 AM 1/29/09 -0500, you wrote:
Quote: |
Rick
Rick,
The best time to install the bushings is when you are building. I wish I
had. But I had to wait until it became obvious that it was important to do
so. So far I have bushed the knuckles on the rear wing attachment and the
through bolt at the rear of the fuselage with porous Oilite bronze bushings.
I have flange Oilite bushings in the box waiting to be installed in for the
horizontal stabilizer to the rear ring on the fuselage tube through bolts.
On the FireFly the next most wear prone seems to be the aileron bell crank
hole in the inboard steel wing rib. If I was to do it over again, I would
bush every hole in which a pin or bolt is used to attach a wing, wing strut,
and horizontal tail surface. A few extra minutes during assembly when you
can't fly will save hours later on when you find that significant steel to
steel wear has taken place. In most cases it is not a difficult repair but
when you are in the process of repairing, it is always seems like you could
be flying.
Yesterday, we got a foot of snow. Spent four hours on the Kubota blowing
snow. Not as much fun as flying. Blowing like crazy today, so I will get
more Kubota time.
Jack B. Hart FF004
Winchester, IN
Posted: Thu Jan 29, 2009 8:47 am Post subject: Check your Horiz. Stblzr bolts |
Many years ago, during my Firestar days, I discovered the soft Lord Mounts allowed my 447 to twist and cant during full power. I also discovered that at full power acceleration, it would only attain about 70 mph. May have been more or less, but so long ago I don't remember. With some experimentation in flight, I discovered if I came back off power and very slowly increased power, allowing air speed to increase, I could attain 85 mph which was normal top speed for this airplane.
Brother Jim and I decided we needed harder engine mounts to prevent movement of the engine under high and full power operation. Jim designed and welded up some really nice engine mounts utilizing two automobile shock absorber rubber donuts for each mount. They were well designed and there was no metal to metal contact. They really stiffened up the engine, holding it in place rather than letting it twist and roll.
I made the two hour flight back to Alabama from Florida. I could tell through feed back in the airframe that there was a lot more vibration than normal. By the time I got home I had just about shook the airplane to pieces. Remember the aluminum angle muffler mounts on the 447? Those were cracked, broken, and disintegrating. Shook my strobe light so hard it quit working. My feet got numb from vibration feed back through the rudder pedals.
I got on the phone, called Little Mike at Old Kolb. He sent me a new set of harder Lord Mounts. My problem was solved.
The reason I share this is my concern for problems that may be encountered by Jimmy Y's Firestar flying with no Lord Mounts. Doesn't take long for vibration to take its toll on a 4130 airframe and everything attached to it.
-- Robert
Titus, Alabama |
Rick Lewis
Posted: Thu Jan 29, 2009 3:43 pm Post subject: Re: Check your Horiz. Stblzr bolts |
NeilsenRM(at)comcast.net wrote: | Rick
Rick Neilsen
Don't worry Rick, this bolt will be safety wired in place. The nut plate itself should lock the bolt in place but won't be relied on to do so. Thank for the concern and I appreciate the comment.
I feel the time to make these modest changes, fixes, are now while I'm building the plane since it's much easier to get to.
Rick Lewis
