Sam
Posted: Sun Jan 25, 2009 2:51 pm Post subject: Attaching D-sub shells |
Is there some way to connect D-sub connectors to each other? The connector itself is fine, but I can't find the female (I guess that is what you call it) version of the backshells. I was thinking of joining the two with self fusing tape, but there must be a better way.
Thanks.
Sam Hoskins
Murphysboro, IL
www.samhoskins.blogspot.com
_________________ Sam Hoskins
www.samhoskins.blogspot.com |
riggs_la(at)yahoo.com Guest
Posted: Sun Jan 25, 2009 4:38 pm Post subject: Attaching D-sub shells |
You should be able to find a double female-female adapter at your local computer parts store.
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sam Hoskins
Sent: Sunday, January 25, 2009 4:40 PM
To: Aerolectric List
Subject: Attaching D-sub shells
Thanks.
Sam Hoskins
Murphysboro, IL
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
dsvs(at)ca.rr.com Guest
Posted: Sun Jan 25, 2009 4:57 pm Post subject: Attaching D-sub shells |
If not at a computer store, Mc Master Carr has them.
[quote] --
Allen Fulmer
Joined: 10 Jan 2006 Posts: 79 Location: Alexander City, AL
Sam
Posted: Sun Jan 25, 2009 6:52 pm Post subject: Attaching D-sub shells |
The mother lode of D-sub accessories! Thanks!
Sam
On Sun, Jan 25, 2009 at 6:52 PM, Allen Fulmer <afulmer(at)charter.net (afulmer(at)charter.net)> wrote:
[quote] This is a blowup of what it looks like:
https://www.alliedelec.com/Search/ProductDetail.aspx?SKU=8100067&MPN=C89E014050&R=8100067&SEARCH=8100067&DESC=C89E014050
And this is a page from Allied catalog with lots of hardware choices:
https://www.alliedelec.com/Catalog/pf.aspx?FN=198.pdf
HTH,
Allen Fulmer
[quote] --
thorps18(at)gmail.com Guest
Posted: Sun Jan 25, 2009 6:58 pm Post subject: Attaching D-sub shells |
They have shells for sale here:
http://www.steinair.com/connectors.htm
On Sun, Jan 25, 2009 at 2:39 PM, Sam Hoskins <sam.hoskins(at)gmail.com (sam.hoskins(at)gmail.com)> wrote:
[quote]Is there some way to connect D-sub connectors to each other? The connector itself is fine, but I can't find the female (I guess that is what you call it) version of the backshells. I was thinking of joining the two with self fusing tape, but there must be a better way.
Thanks.
Sam Hoskins
Murphysboro, IL
tp://forums.matronics.com
| [b]
bicyclop(at)pacbell.net Guest
Posted: Sun Jan 25, 2009 7:12 pm Post subject: Attaching D-sub shells |
Sam,
You could always just mate them up and secure them with a couple of tie wraps. When I assemble them, I leave out of the shell the little mating screws and then just put small cable ties right through the screw holes. Easy, cheap, light and easy to separate later.
Pax,
Ed Holyoke
Sam Hoskins wrote: [quote]Is there some way to connect D-sub connectors to each other? The connector itself is fine, but I can't find the female (I guess that is what you call it) version of the backshells. I was thinking of joining the two with self fusing tape, but there must be a better way.
Thanks.
Sam Hoskins
Murphysboro, IL
| [b]
stein(at)steinair.com Guest
Posted: Mon Jan 26, 2009 7:19 am Post subject: Attaching D-sub shells |
We also have the gender changers in stock...I'll try to get them on the website asap for ya'll. Those allows the Dsubs to be connected.
Cheers,
Stein
[quote] --
