Dick Maddux
Posted: Sat Jan 24, 2009 6:35 am Post subject: trip to Oshkosh/big prep, short |
Lynn,
In reply to the F210 installation I just wanted to pass on that I installed my sender about 2 inches above the gascolater (splicing into the fuel line). I shortened the electrical cord to about 3 ft (from about 15) and was able to connect to the gauge in my panel. It worked out very nicely. I covered both the sender and fuel line in aircraft fire sleeve and I now have a very stable installation. This is also a vertical installation as the instructions specify. If you want a picture of the installation let me know and I will remove the cowling and send you one.
I too like having a fuel flow. Mine is indicating a fuel consumption of 3.3 gal at 5000 rpm. I thought that was rather low on my 912UL but prior computations at a few hundred rpm's less was revealing 2.8 gph and that was over a 10 hour period. ?????
I love your flying adventures by the way.
Dick Maddux
Fox 4-1200
Pensacola,Fl
From Wall Street to Main Street and everywhere in between, stay up-to-date with the [url=http://aol.com?ncid=emlcntaolcom00000023 ]latest news[/url].
Lynn Matteson
Posted: Sat Jan 24, 2009 12:35 pm Post subject: trip to Oshkosh/big prep, short |
Thanks for the offer to shoot your installation, Dick, but I've got
mine installed now and it's working fine. I think I'll do like you
did, and shorten that HUGE long cable, too. My sender (transducer) is
at about a 45 degree angle within my console, and works great. I see
5.8 gals/hour during climbout, and down to anywhere from 3.7-4.4 in
cruise mode depending on rpm, wind direction, etc.
If you like adventures, I'm getting ready to post todays' rather
scary...briefly....hop, one of several hops I made in the snow today.
Lynn Matteson
Jabiru 2200, #2062, 600.2 hrs
Sensenich 62x46
New skis done and flying
On Jan 24, 2009, at 9:29 AM, Catz631(at)aol.com wrote:
| Quote: | Lynn,
Dick Maddux
Fox 4-1200
P
ensacola,Fl
to-date with the latest news. _-
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
msm_9949(at)yahoo.com Guest
Posted: Sun Jan 25, 2009 9:10 am Post subject: trip to Oshkosh/big prep, short |
Dick, that must be some fat firesleeve to fit over the sender. Don't suppose you have about 4" of that scrap left over from your installation?
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1 w/clutch
--- On Sat, 1/24/09, Catz631(at)aol.com <Catz631(at)aol.com> wrote:
| Quote: | From: Catz631(at)aol.com <Catz631(at)aol.com>
Subject: Re: trip to Oshkosh/big prep, short
Date: Saturday, January 24, 2009, 9:29 AM
Lynn,
Dick Maddux
Fox 4-1200
Pensacola,Fl
>From Wall Street to Main Street and everywhere in between, stay up-to-date with the latest news.
Lynn Matteson
Posted: Sun Jan 25, 2009 9:36 am Post subject: trip to Oshkosh/big prep, short |
2.8 gph? man, I gotta get one of those engines that you're using!
Lynn Matteson
Sensenich 62x46
On Jan 25, 2009, at 12:08 PM, Marco Menezes wrote:
| Quote: | Dick, that must be some fat firesleeve to fit over the sender.
installation?
Marco Menezes N99KX
Lynn,
Dick Maddux
Fox 4-1200
P
ensacola,Fl
_-
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3
_-
N369LM |
Dick Maddux
Posted: Mon Jan 26, 2009 5:51 am Post subject: trip to Oshkosh/big prep, short |
Lynn,
I was cruising the 912UL at about 4500rpm and that is why I was getting the low gas consumption. I have since found out that the engine should be set at around 5000 rpm so I am sure my consumption is much higher. I am tracking it so I can get the Northstar f/f closer to the actual consumption. Right now I believe it is a little too optimistic and I have tweaked the flow up higher. In any case, this engine doesn't use much fuel.
Dick Maddux
Pensacola,Fl
