Rotax Flydat
keithhickling(at)clear.ne
PostPosted: Fri Jan 23, 2009 2:38 am    Post subject: Rotax Flydat Reply with quote
On firing the starter motor for the first time to check the oil pressure after priming the oil system, my Rotax Flydat screen went blank, then after turning off the starter motor it cycled through the initial start-up screens twice before returning to the normal display. This happened repeatedly on running the starter motor.
Can someone with a flydat tell me if this is normal? And if not normal does it risk damaging the unit if it is caused by sudden voltage changes? Should it be switched off when starting the engine?
Keith Hickling,
New Zealand.
davidjoyce(at)doctors.org
PostPosted: Fri Jan 23, 2009 3:05 am    Post subject: Rotax Flydat Reply with quote
Keith, It always does that which is a pain and one of the failures of the
design. Mine however has survived 7 yrs of starting without switching it
off.
Regards, David Joyce, G-XSDJ
Trevpond(at)aol.com
PostPosted: Fri Jan 23, 2009 4:25 am    Post subject: Rotax Flydat Reply with quote
Hi Keith,
Fly-dats only run if they are receiving 12 volts or better. It is quite common for them to blank out when you are running the starter because of the voltage drain from the battery. As soon as the engine is running, it will come up quickly.
regards
Trev Pond
G-LINN
bill.sue(at)orcon.net.nz
PostPosted: Fri Jan 23, 2009 11:58 am    Post subject: Rotax Flydat Reply with quote
Keith,
Mine does the same, a feature of the unit.
Hear on the grapevine you are nearly ready to fly!!!!!!!!
Cheers
Sue & Bill Sisley
Keith Hickling wrote: [quote] On firing the starter motor for the first time to check the oil pressure after priming the oil system, my Rotax Flydat screen went blank, then after turning off the starter motor it cycled through the initial start-up screens twice before returning to the normal display. This happened repeatedly on running the starter motor.
Keith Hickling,
New Zealand.
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
PostPosted: Fri Jan 23, 2009 3:57 pm    Post subject: Rotax Flydat Reply with quote
Thanks for the replies everyone. Good to know it's normal.
Yes Bill, nearly ready to fly ! Haven't run the engine yet, but all else complete - all the electrical systems seem to work - Amazing
Keith Hickling,
New Zealand.
XS ZK MEE
