jessejenks(at)hotmail.com Guest
Posted: Mon Jan 19, 2009 6:50 am Post subject: Static wicks |
I have always wondered why (most) certified airplanes have static wicks C but not homebuilts? This makes me want to know what their actual function is? I was always taught "they dissipate static electricity". Is static really that big of an issue C and if so C do wicks actually make a difference? I'm building an all metal airplane C and so far have not given any thought to control surface bonding C or static wicks.
Thanks.
Windows Live™: Keep your life in sync. Check it out. [quote][b]
harley(at)AgelessWings.co Guest
Posted: Mon Jan 19, 2009 7:31 am Post subject: Static wicks |
They can work to dissipate static if they are attached to a conducting surface. That way, they can bypass whatever is creating the static and insulating the object from a normal ground (like the plastic or rubber tires on a fork lift).
But on many homebuilts, the plane is made of non conducting materials (wood and fabric or fiberglass and/or epoxy), and a static wick will only discharge the point that it is attached. A couple of inches away from that point, the charge remains as strong as ever.
I had many a discussion with fork lift drivers at Pennwalt when they would attach a static wick to the plastic part of the frame on the truck (it was easier to drill a hole into), and then complain that they still got zapped when they stepped off the truck. For those that really thought they needed it, we would attach the wicks to the metal frame under the truck. But, that often didn't help either, because the wick was often dragging on a non conducting surface (epoxy sealed floors).
Also, the line operators used vacuum cleaners to pick up the spilled foot powder...even though they used a so-called static proof hose (it had a grounded wire spiraling along the length of it) they would still get zapped when they put the hose down. The charge was decreased, because of the presence of the wire, but still built up on the hose between the wire coil wraps.
In short, you need a continuous conductive path to discharge a static charge. From every area where the charge can build.
Harley
Jesse Jenks wrote: [quote] .hmmessage P { margin:0px; padding:0px } body.hmmessage { font-size: 10pt; font-family:Verdana } I have always wondered why (most) certified airplanes have static wicks, but not homebuilts? This makes me want to know what their actual function is? I was always taught "they dissipate static electricity". Is static really that big of an issue, and if so, do wicks actually make a difference? I'm building an all metal airplane, and so far have not given any thought to control surface bonding, or static wicks.
Thanks.
Windows Live™: Keep your life in sync. Check it out. | Quote: |
Agelesswings certifies that no virus is in this incoming message.
Checked by AVG - http://www.avg.com
| [b]
BobsV35B(at)aol.com Guest
Posted: Mon Jan 19, 2009 9:23 am Post subject: Static wicks |
Good Morning Jesse,
I have almost no experience in homebuilt aircraft, but I do have several thousand hours in aircraft that were equipped with static wicks and several thousand hours in aircraft with no static wicks applied.
My suggestion would be to thoroughly bond all control surfaces, flaps included, but not bother with static wicks unless you note a problem.
The static problem was greater in the days of low frequency radio. It was not at all uncommon to lose all communication capability when we were using the HF transmitters and receiving on low frequency. I have encountered precipitation static strong enough to knock out VHF communications for just a very few minutes, but that has never lasted more than four or five minutes.
I have also experienced static discharges, but that has always been on aircraft that were equipped with static wicks. There is no doubt that I have flown in much heavier precipitation in static wick equipped airplanes than I have in airplanes that are not so equipped, but I have flown both in some rather severe situations.
Wait and see if you have a problem.
If you lose VHF navigation capability in a heavy thunderstorm, you may want to add static wicks or you may just decide to stay out of such conditions!
In any case, I have never seen a GPS signal affected by any static build up.
The only time I would suggest using static wicks is if your only means of navigation is a LORAN. Even then, you don't need it if you stay out of precipitation.
Summary? Bonding YES, Static Wicks? NO
Happy Skies
Old Bob
AKA
Bob Siegfried
Ancient Aviator
628 West 86th Street
Downers Grove, IL 60516
630 985-8502
Stearman N3977A
Brookeridge Air Park LL22
In a message dated 1/19/2009 8:52:32 A.M. Central Standard Time, jessejenks(at)hotmail.com writes:
| Quote: | I have always wondered why (most) certified airplanes have static wicks, but not homebuilts? This makes me want to know what their actual function is? I was always taught "they dissipate static electricity". Is static really that big of an issue, and if so, do wicks actually make a difference? I'm building an all metal airplane, and so far have not given any thought to control surface bonding, or static wicks.
Thanks.
A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
Posted: Wed Jan 21, 2009 9:58 pm Post subject: Static wicks |
Thanks.
When two dissimilar materials slide past each other
rapidly, there is a tendency for electrons to be transferred
from one material to the other . . . usually from
the lesser conductor to the greater conductor.
Shuffle your feet on the carpet and you can get a
pretty good zap touching a doorknob. Slide out of
your car on a cold dry day and it's not uncommon to
find your body charged with a noteworthy packet of
energy that wakes up your nervous system where the
sparks jump from your bod.
Airplanes flying in snow, ice particles or even rain
can accumulate a surface charge of excess electrons.
The faster airspeeds and higher particle density
makes the build up stronger.
If the quantity of excess charge is great enough
AND there's some handy point or edges where the
charges tend to collect, you can SEE the effects
in the form of a luminous hazy discharge along
the edge or at the point.
On some models of King Airs we used to get reports
of luminous glow around the window frames of glass
fitted with internal de-icing heaters. While the
airplane is shedding excess charge from trailing
edges, antennas, window frames, propeller tips, etc
the phenomenon creates a broadband radio noise that
HAS been strong enough to disable ADF, LORAN, Omega
nav, HF communications and in severe cases, gets the
VHF comm and nav receivers too.
http://en.wikipedia.org/wiki/St._Elmo%27s_fire
http://science.howstuffworks.com/st-elmo-fire1.htm
The big problem we were having with discharges
around the window frames is that it was etching
the glass and in some cases, killing the de-ice
heat sensors. VERY expensive.
The radio noise comes from the disordered, high density
discharge of an un-treated structure. The cure is
to provide devices that have a propensity for dropping
electrons off into the slip stream. These can be
"wicks" . . . a thing that looks like a fine brush
of copper cat-hairs . . .
http://www.aircraftspruce.com/catalog/elpages/staticdischrgr.php
Or an array of tiny points like these:
http://www.b737.org.uk/wingtips.htm
http://www.aircraftspruce.com/catalog/elpages/nullfieldtip.php
This effect is not limited to airplanes. It can
be a significant noise problem on stationary radio
installations when there is blowing snow, dust, rain
or significant convective activity as far away as
20 miles.
If you have a sensitive enough ammeter, you can probe
and actually measure this current as cited in
this article.
http://www.repeater-builder.com/pdf/staticbusterarticlecomplete.pdf
A number of years ago, Beech did some extensive
testing on the discharge characteristics of various brands
and styles of wicks in the lab. There was a huge difference
in performance of products then offered. I think folks making
these things now are much better at it.
Doing a GOOD discharger is not a trivial task although
many folks have attempted it. Check out some of the
techniques suggested here:
http://www.aeroelectric.com/Reference_Docs/Patents/Static_Dissipation/
There have been a number of articles and postings to
various forums about how to build your own. I've never
seen an article that actually tested the handy work
on the bench. Given what I witnessed at Beech many moons
ago, I'm convinced that performance of DIY static
wicks is a dart throw without quantified bench marks.
The same process used to test wicks is use to test the
airplanes probable discharge locations. The airplane is
set up on plastic blocks. A long wand with a spherical
end on it and a pico-ammeter in series is raised up to
about 100,000 volts dc. You can run the wand along the
trailing edges of possible concentration points and
see the ammeter go up when the wand is closest to
a location that would benefit from an effective
discharge wick.
Wicks are useful only on metal airplanes and then
finding the optimum wick and placement is difficult.
The occurrence of p-static is pretty rare for us
guys who don't fly for a living.
It won't hurt to have a half dozen wicks on your airplane
but it may not be all that helpful. Wicks have
nothing to do with lightning protection. Bonding
the hinges on an airplane has nothing to do with
mitigation of p-static effects. The idea here is
to avoid welding the hinge rigid in case a lightning
strike attaches to the control surface.
Here's an short article I did on static-wicks for
an EAA chapter newsletter some years back.
http://www.eaa326.org/Newsletters/eaa326-3-2005.pdf
rv8builder
Posted: Thu Jan 22, 2009 6:27 am Post subject: Static wicks |
I flew DeHavilland Dash-8's for nearly 20 years and despite lots and lots of static dissipation & airframe bonding efforts through out (to include lots of static wicks) you could still see St. Elmo's Fire from the prop tips. It took moderate to heavy precipitation for the St. Elmo's Fire to be visible. And then only visible at night. It was neat to see from front end. The passengers seldom saw it because the cabin lights were too bright!!
_________________ Dale |
mlas(at)cox.net Guest
Posted: Thu Jan 22, 2009 7:50 am Post subject: Static wicks |
On Airbus jets with all the static wicks they have we still suffer
from reduced VHF radio performance in hi P-static environments. On
the Lancair airplanes many builders have installed wicks with limited
to no improvement to radio performance during high P-static events.
Many over time have then removed the wicks.
Mike
walter.fellows(at)gmail.c Guest
Posted: Thu Jan 22, 2009 1:10 pm Post subject: Static wicks |
On a plastic airplane, if the composite parts are made with a specialized copper or aluminum mesh in the first layer of the mold, the parts of the airplane can be bonded together and static wicks added to give the same p-static bleed as an aluminum airplane (this the major part - without the wicks - of a program to provide lightning protection in composite aircraft). However there are weather conditions that will overwhelm the system even in an aluminum airplane, I had my HSI spinning and a loss of VHF reception (while retaining VHF transmission ability) over Lake Michigan at night in a Cessna 210 due to p-static apparently caused by almost invisible ice crystals in the air. I was IFR at the time and inadvertently stepping on center trying to restablish communcation much to their annoyance.
On Thu, Jan 22, 2009 at 7:44 AM, MICHAEL LARKIN <mlas(at)cox.net (mlas(at)cox.net)> wrote:
[quote] --> AeroElectric-List message posted by: MICHAEL LARKIN <mlas(at)cox.net (mlas(at)cox.net)>
On Airbus jets with all the static wicks they have we still suffer from reduced VHF radio performance in hi P-static environments. On the Lancair airplanes many builders have installed wicks with limited to no improvement to radio performance during high P-static events. Many over time have then removed the wicks.
Mike
[quote] --> AeroElectric-List message posted by: Dale Ellis <rv8builder(at)earthlink.net (rv8builder(at)earthlink.net)>
mprather(at)spro.net Guest
Posted: Thu Jan 22, 2009 3:18 pm Post subject: Static wicks |
An aside:
Bob Buck, author of "Weather Flying" flew many research missions during
and after WWII with the specific purpose of understanding P-static and
testing equipment designed to alleviate its effects on aircraft systems.
His discussion of this in his autobiography ("North Star Over My
Shoulder") is quite interesting.
There is also anecdotal information that suggests that electrical bonding
of control surfaces to the airframe can alleviate certain p-static
effects. Apparently the charge that builds up on the body of the airframe
doesn't always readily pass through the hinges and control mechanisms to
control surfaces. A small charge builds up between the control surface
and what it's mounted to, and then bleeds off in small discharges. Each
discharge radiates a small amount of electrical noise which can apparently
interfere with the function of some equipment. The story about this that
I read was one about a shipboard tactical Navy aircraft which suffered
poor nav system performance without the control surface bonding. Again,
this is anecdotal..
Matt-
[quote] On a plastic airplane, if the composite parts are made with a specialized
aircraft).
in
a
> Lancair
> improvement
> then
> removed the wicks.
> Mike
>> rv8builder(at)earthlink.net>
>> lots
>> include
>> to be
>> front
>> bright!!
Posted: Fri Jan 23, 2009 10:33 am Post subject: Static wicks |
| Quote: | Apparently the charge that builds up on the body of the airframe
I've heard this on numerous occasions and listened/participated
in a number of discussions about the physics of how this might
happen.
P-static currents are measured in micro-amps. The energies
that might be released as electromagnetic radiation in hinge
gaps is pretty small. The gap is measured in thousandths of
an inch and the arc-over voltage for this is low assuming
a perfectly spaced gap and high resistance. A hinge will never
go open circuit . . . it's more appropriately described as
a dynamic resistance on the order of hundreds of milliohms.
Static wicks have HUGE resistors built in (many tens of
megohms) for the purpose of killing the ability of the
wick to resonate and to convert energy to heat (like the
resistor wires on spark plugs).
We could see how a hinge in motion might generate moderate
CONDUCTED noise into an electrical system if say a landing
light were grounded to a gear door and the hinge resistance
was wobbly as the door moved.
But the idea that dynamic resistance characteristics of
hinges at p-static currents produces detectable noise
in the RF spectrum was pretty far fetched. I'd like to
read an explanation of the simple-ideas that support the
notion of bonding hinges for the purpose of reducing
deleterious effects of p-static.
Now, there could be OTHER radio frequency issues that
are addressed by bonding. I think I described a case
where the unintended consequences of going from a
voltage fed wire HF antenna to a current fed loop
on the vertical fin turned the whole empennage of
the airplane into a high energy RF test chamber. The
unintended consequences of which showed how many
pieces of 1980's technology would scream for mercy
as the transmitter was keyed.
( -Thomas Paine 1776- )
Posted: Fri Jan 23, 2009 1:20 pm Post subject: Static wicks |
Good Afternoon Lectric Bob,
I have no doubt that what you have told us is good information and that it was derived from careful observation. Nevertheless, when Loran was all the rage, we found that adding bonding straps to every possible control surface or gear door made a huge difference in the reception of adequate Loran signals. Adding static wicks added a bit more, but the cost of installing and maintaining the static wicks was quite high and the bonding costs were next to nothing. It may not do much good, but I still vote for bonding and only going to static wicks as a last desperation "throw money at the problem" solution.
This time I vote for the OWT!
'Course, you may not need anything at all!
Happy Skies
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 1/23/2009 12:35:22 P.M. Central Standard Time, nuckolls.bob(at)aeroelectric.com writes:
| Quote: | --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
happen.
= Use lities y - MATRONICS WEB FORUMS =========================< - List Contribution Web Site ; =========================
