Tail wheel
Goto page Previous  1, 2, 3, 4, 5, 6  Next
Lynn Matteson
PostPosted: Mon Jan 19, 2009 2:19 pm    Post subject: Tail wheel Reply with quote
I'm not sure what you're suggesting, Noel. It seems like a drilled
head would only retain the bolt if the nut decided to leave. Unless
you're suggesting to wrap safety wire through the drilled head,
around the spring leafs, and through the drilled bolt body and nut...?
Maybe you'd better clarify, Noel, I'm gettin' nowhere with it. : )
It is simply a case for a cross-drilled bolt...2 holes at 90 degrees
to one another.... (through the threaded end) and a castle nut. This
gives 1/12th turn resolution for tightening...twice the options for
getting the nut to a preload that is preferred, over that of a single-
drilled hole through the threads.
Lynn Matteson
Jabiru 2200, #2062, 600.2 hrs
Sensenich 62x46
New skis done and flying
On Jan 19, 2009, at 8:17 PM, Noel Loveys wrote:
How about a spot for a drilled he4ad and a bit of lockwire?
Noel
Lynn
Kitfox IV-Jabiru 2200
N369LM
Guy Buchanan
PostPosted: Mon Jan 19, 2009 2:36 pm    Post subject: Tail wheel Reply with quote
At 09:54 AM 1/18/2009, you wrote:
Look at Gary's picture three. That is definitely extremely in the
wrong direction.
Reference the photo on page 17 of that Maule tailwheel writeup.
I'm going to kick the nest, just to see if I can get some
good data. I looked at the pdf, thinking it was a Maule document, but
found it wasn't, so I'm not overly inclined to believe it, (or
otherwise.) My configuration is as Lynn's, with the pivot "forward",
meaning a line projected through the pivot to the ground intersects
the ground forward of vertical. I use a Grove (gasp!) spring so
there's no question of it flexing even under the load of my
incredibly powerful physique. And yes, my plane taxis just fine at
all speeds. Why?
My conjecture during assembly was that the "forward"
configuration minimized shimmy. Did I do any math? No. But here's my
educated opinion: Shimmy is a resonance condition requiring mass for
inertia, plus a restoring force for amplification. To amplify shimmy
that restoring force wants to act at a time and in such a way to
"amplify" the response. We have two cases to investigate:
1. Pivot "forward": (As above.) At rest, if the tailwheel turns the
tail drops and the tailwheel wants to continue to turn up until it
has turned 180 degrees. In motion, if the tailwheel turns, the moment
offset between the contact patch and the pivot causes the wheel to
want to return to centerline. The "tail drop" caused by the "forward"
pivot tends to reduce this restorative force.
2. Pivot "aft" per
http://www.bowersflybaby.com/tech/Maule_Tailwheel.pdf, page 17: At
rest, if the tailwheel turns the tail lifts and the tailwheel wants
to return to centerline. In motion the response is the same as in 1,
above. The "tail lift" caused by the "aft" pivot tends to add to the
restorative force.
I won't address the case of the pivot being vertical,
because that's nearly impossible to achieve. Now in case 2 there is
more restorative force than case 1. I therefore speculated that
because the shimmy was driven by the restorative force I'd have less
likelihood of shimmy if I had a "forward" pivot.
That was my logic and it left me, for whatever reason, with
no shimmy. Now as you have probably guessed, I are an engineer,
(though I don't play one on TV,) and I did due diligence via the
Internet. What I found was that, not surprisingly, caster wheel
shimmy, being a resonance phenomenon, does not lend itself to
cookbook answers; there are simply too many variables involved.
Oh, and I also found this: http://www.pierceaero.net/tws.php.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Float Flyr
PostPosted: Mon Jan 19, 2009 2:58 pm    Post subject: Tail wheel Reply with quote
Cameras have been around a long time. Romans knew the Camera Obscura...
literally "Dark Room". Like Freddy Fintstone the artist went in the camera
and traced the picture inverted. George Eastman Patented paper roll film in
1880 and the Kodak Camera (roll film) in 1888. We have had home computers
less than 35 Yr... Acrobat, around 25 yr. Inserting pictures into the file
is no more difficult than inserting the drawings. Yes he could have used
photographs if he wanted to.
He probably thought the drawings were cleaner.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
akflyer
PostPosted: Mon Jan 19, 2009 2:58 pm    Post subject: Re: Tail wheel Reply with quote
I are an engineer,
Guy Buchanan
San Diego, CA
Did you at least stay at a holiday in express last night :dunno: If not we are gonna have to lump your opinion in with the other chumps LOL. Sorry, I let the humor outa the bag again, I need to tie a tighter knot in the top of it.
My tail wheel is the Matco Pneumatic and with the 2 leaf spring (gasp, I hope is does not fall off) as luck would have it it is pretty much straight up and down on the pivot point, maybe leaning slightly aft. No issues with shimmy, but I take off full stick forward and get the tail up in just a few feet so I don't have anything digging into the turf. Landings are normally 3 pointers but I have not had any shimmy issues yet. I run the compression springs pretty darn tight and that may have alot to do with it too.
 Filesize:  312.42 KB
 Viewed:  585 Time(s)
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Guy Buchanan
PostPosted: Mon Jan 19, 2009 3:03 pm    Post subject: Tail wheel Reply with quote
At 09:30 PM 1/18/2009, you wrote:
Yes it certainly sits higher but the angle is really the problem I think. If mine is sitting stationery and I give the tail a push to unlatch the tail wheel it will swing completely 180 deg so that the tail wheel assy faces backwards. It's then a doozy trying to get it turned around.
Gary,
Though I think you've got the right direction, it sounds like you've got too much of a good thing. My angle "forward", (pivot centerline forward of vertical at the ground,) is only about two or three degrees. (And no, I don't flex "aft". I have the Grove spring. It ain't goin' nowhere.) I'll try to measure it when I get a chance.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Paul A. Franz, P.E.
PostPosted: Mon Jan 19, 2009 3:12 pm    Post subject: Tail wheel Reply with quote
On Mon, January 19, 2009 8:29 am, fox5flyer wrote:
It amazes me that we have so few choices for a decent tailwheel out there.
Maule and Scott have been mentioned. Mine is a Matco and seems to be pretty well built.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Lynn Matteson
PostPosted: Mon Jan 19, 2009 3:36 pm    Post subject: Tail wheel Reply with quote
Nope, NOT a Maule document, and not overly accurate in at least one
statement, that of the break-away occurring only on left turns. This
document seems to have grown a life of its own being, perhaps, one of
the few available. I printed it out early on in my Kitfox-building
life and hung onto it like a life preserver. It got me where I needed
to get to, and now I can see some faults with it, but it's better
than nothing...I think. As a primer for taking your assembly apart
and fixing it, it suffices, but it is not an end-all. It is not a
textbook about tailwheel geometry.
Lynn Matteson
Sensenich 62x46
> wrong direction.
but found it wasn't, so I'm not overly inclined to believe it, (or
"forward", meaning a line projected through the pivot to the ground
intersects the ground forward of vertical. I use a Grove (gasp!)
spring so there's no question of it flexing even under the load of
my incredibly powerful physique. And yes, my plane taxis just fine
at all speeds. Why?
my educated opinion: Shimmy is a resonance condition requiring mass
for inertia, plus a restoring force for amplification. To amplify
shimmy that restoring force wants to act at a time and in such a
way to "amplify" the response. We have two cases to investigate:
moment offset between the contact patch and the pivot causes the
wheel to want to return to centerline. The "tail drop" caused by
the "forward" pivot tends to reduce this restorative force.
2. Pivot "aft" per http://www.bowersflybaby.com/tech/
Maule_Tailwheel.pdf, page 17: At rest, if the tailwheel turns the
tail lifts and the tailwheel wants to return to centerline. In
motion the response is the same as in 1, above. The "tail lift"
caused by the "aft" pivot tends to add to the restorative force.
less likelihood of shimmy if I had a "forward" pivot.
Guy Buchanan
San Diego, CA
Lynn
N369LM
Float Flyr
PostPosted: Mon Jan 19, 2009 3:53 pm    Post subject: Tail wheel Reply with quote
I don't know why, but I was under the impression the bolt was threaded into
one of the leaves as a vibration damper...
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Lynn Matteson
PostPosted: Mon Jan 19, 2009 4:04 pm    Post subject: Tail wheel Reply with quote
Excellent article, Guy....http://www.pierceaero.net/tws.php. Not
being an engineer (bad enough being a Michigander), I found it very
useful and informative. Notice all the theories therein....high tire
pressure, low tire pressure, forward tilt, backward tilt, etc...ya
gotta love it.
One thing I did object to though, was his spelling of the word
"caster" ...he likes "castor" as does Drew Fidoe, author of the oft-
mentioned "Maule article" The dictionary likes the use of caster (in
respect to the current subject), but gives a nod to castor being a
"variant" of caster. I prefer caster because that's the word I
learned way back when. I think of castor as being something too close
to being a cathartic, and also a close dictionary neighbor of
"castrate", which I also like to avoid.
Lynn Matteson
Sensenich 62x46
> wrong direction.
at all speeds. Why?
Guy Buchanan
San Diego, CA
Lynn
N369LM
Paul A. Franz, P.E.
PostPosted: Mon Jan 19, 2009 4:14 pm    Post subject: Tail wheel Reply with quote
On Mon, January 19, 2009 2:32 pm, Guy Buchanan wrote:
clip clip
That is a pretty good story and writeup. He also has posted his arbitrary definition
with a drawing of what he uses as positive and negative caster angle.
<http://www.pierceaero.net/techdata/tws.jpg>
I see that the amount of caster offset apparently offers greater shimmy resistance
which more than compensates for the loss by the tail lifting force produced by the
posiitive angle. This is confirmed by testing and corroborates Lynn's experience.
A small positive angle (like Lynn's) seems to be the ticket to success along with good
maintenance, lubrication, and if using a pneumatic tire, high enough pressure to keep
the tire from slipping on the rim in spin up. A positive angle also makes it easier to
induce a turn. Too much and it will spin around backwards.
It would appear to me that 15 to 20 degrees of negative king pin angle is likely to
produce shimmy.
I have mine set at very close to vertical. If I have shimmy problems, I'll give it a
wee bit of positive tilt by shimming the tail spring.
This has been great with so many people providing experience input. Lynn, Deke, Guy,
Lowell, Noel, Len and Gary have all contributed to this knowledge base.
Paul A. Franz
Bellevue WA
425.241.1618 Cell
Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
f.miles.tcp.833(at)clearw
PostPosted: Mon Jan 19, 2009 4:18 pm    Post subject: Tail wheel Reply with quote
O.K - I can't stand it any more. I don't know who you are Lynn Matteson
but you must not have a life. I count 14 postings since 11:30 a.m. and you
don't really have that much profound to say. Why don't you two or three
guys, as the kids use to say, get a room.
Frank Miles
Clarkston, Washington
K - III
Lynn Matteson
PostPosted: Mon Jan 19, 2009 4:20 pm    Post subject: Tail wheel Reply with quote
Not from what I've seen. No, the bolt passes through the 2 main
leaves...in the case of the 3-leaf McBean spring at least, and
through the tailwheel assembly, and has a nut on the other side. In
the case of the original single *main* leaf spring, you can tighten
that mounting bolt up 'til the cows come home. But with the 2 main
leaves, one having a larger hole than the other...to allow for the
different lengths of travel as they bend...you cannot tighten the
mounting bolt as much. The leaves must slide against each other as
they flex, although this movement is small and in accordance with how
much the spring flexes....the more bounce, the more longitudinal
movement between them. This is why I suggested a castellated nut, and
a drilled bolt shank, and to get a more accurate "fine-tuning" of the
amount of torque, a cross-drilled shank (2 holes at 90 degrees to
each other) to allow 1/12th of a turn accuracy in adjusting the torque.
Lynn Matteson
Sensenich 62x46
threaded into
Noel
Lynn
N369LM
gary.algate(at)sandvik.co
PostPosted: Mon Jan 19, 2009 4:33 pm    Post subject: Tail wheel Reply with quote
Well I was going to post the fotos of my new setup plus results but certainly don't want to offend Frank Miles or others - I'll send the details off-line!
Gary
Gary Algate
Kitfox Classic Jab 2200
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
“This year, instead of sending you a Christmas card in the mail, we have made a contribution to [url=Arial]UNICEF Australia[/url]. We wish you a safe and happy Christmas".
"Frank Miles" <f.miles.tcp.833(at)clearwire.net>
Sent by: owner-kitfox-list-server(at)matronics.com
20/01/2009 10:54 AM
Please respond to
kitfox-list(at)matronics.com To
<kitfox-list(at)matronics.com> cc
Subject
RE: Tail wheel
--> Kitfox-List message posted by: "Frank Miles" <f.miles.tcp.833(at)clearwire.net>
Frank Miles
K - III
Lynn Matteson
PostPosted: Mon Jan 19, 2009 4:35 pm    Post subject: Tail wheel Reply with quote
Ever heard of "delete"?
And I've GOT a life....I spent my time today...when I wasn't counting
postings....working on the skis that I recently built and will fly up
to Oshkosh this weekend. For lunch, I met with three other fliers who
flew their ski-equipped Piper Cubs into Napoleon Airport in 13 inches
of snow.
I fly my Kitfox plane from coast-to-coast when it suits me, and I've
learned a lot from this group of builders, and when I can share some
of what I've learned, I do so, and I usually don't bother with petty
grievances such as yours, but this one caught me in just the right
mood to strike back.
How's YOUR life if it means counting posts? Have you got a
contribution to make to the group?
Lynn Matteson
Sensenich 62x46
Matteson
and you
three
Frank Miles
K - III
Lynn
N369LM
matronics(at)bob.brennan.
PostPosted: Mon Jan 19, 2009 4:46 pm    Post subject: Tail wheel Reply with quote
Here's one vote to say please post them to the group. At first I was convinced that the "Maule Geometry" was correct, although with all the traffic here did not need to add my input. (Remember, I are a engineer<g>). But you guys have made a great case for the "Matteson Geometry" and I think you should go ahead with that Pat Pending Lynn<wink>. And some of the long winded diatribes I did in fact delete...
Keep up the good discussion guys, never mind the cranks.
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of gary.algate(at)sandvik.com
Sent: 19 January 2009 7:32 pm
Subject: RE: Kitfox-List: Tail wheel
Gary
Gary Algate
“This year, instead of sending you a Christmas card in the mail, we have made a contribution to UNICEF Australia. We wish you a safe and happy Christmas".
20/01/2009 10:54 AM
Please respond to
Subject
RE: Tail wheel
Frank Miles
K - III
Yes, I have heard of delete and I do it often. When you get over being
offended maybe you will think about what I said and slow down down on the
verbiage and keep your postings relevant. Those 14 or so postings was just
today!
Frank
Oh, I don't really care what you did all day!
djwild2(at)hotmail.com
PostPosted: Mon Jan 19, 2009 4:51 pm    Post subject: Tail wheel Reply with quote
Gary,
I have a Kitfox Model 1 and I just broke my spring last week so I have been absorbing all this talk about springs. Please continue to post pics on the group. There might be others out there interested. If people aren't interested in this subject they don't have to read them.
Dan Wild
mdl1
532
From: gary.algate(at)sandvik.com (gary.algate(at)sandvik.com)
Sent: Monday, January 19, 2009 6:31 PM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Subject: RE: Tail wheel
Gary
Gary Algate
20/01/2009 10:54 AM
Please respond to
Subject
RE: Tail wheel
Frank Miles
K - III
akflyer
PostPosted: Mon Jan 19, 2009 4:58 pm    Post subject: Re: Tail wheel Reply with quote
:Snack:
 Filesize:  165.98 KB
 Viewed:  463 Time(s)
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Guy Buchanan
PostPosted: Mon Jan 19, 2009 4:58 pm    Post subject: Tail wheel Reply with quote
Please don't respond to this. (I see I was too slow for Lynn, but
please don't respond to his post either.) The moderators will handle
it off-line.
Guy Buchanan, Kitfox List Moderator
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Paul A. Franz, P.E.
PostPosted: Mon Jan 19, 2009 4:59 pm    Post subject: Tail wheel Reply with quote
details off-line!
If others are like me, I have been eagerly anticipating your photos and writeup. I
don't see posting them in the forum as being intrusive at all.
Paul A. Franz
Bellevue WA
425.241.1618 Cell
Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
Page 5 of 6
