GLJSOJ1
Joined: 18 Aug 2007 Posts: 82 Location: Chesapeake, Virginia
Posted: Sun Jan 18, 2009 6:18 pm Post subject: VEDIO AND AUDIO RECORDING |
Hi all
I am looking for a way to record my first flights and wondering how to get the audio to pick up more than just engine noise. There is a something called a "patch cord cockpit voice recorder"pn: 13-01456. Any body out there using this or have other ideas
thanks
Glenn
_________________ 601XL N676L FLYING PHASE I
CHESAPEAKE VA |
N1BZRich(at)aol.com Guest
Posted: Sun Jan 18, 2009 8:25 pm Post subject: VEDIO AND AUDIO RECORDING |
In a message dated 1/18/2009 9:24:23 P.M. Eastern Standard Time, gljno10(at)hotmail.com writes:
| Quote: | | patch cord cockpit voice recorder |
Glenn,
Here is a suggestion that I have used while doing phase one testing on several different experimental aircraft, including the 601XL that the EAA chapter in Williamsburg (Chapter 156) built. Get yourself a voice activated digital recorder and a lapel microphone. The one I have came from Radio Shack about four years ago. Place the lapel mic (they are very small) in one of the ear cups of your headset. Turn on the recorder in the voice activation mode and be sure the aircraft intercom is also on. Now anything that you hear in your headset will activate the digital recorder. I suggest you also "talk to yourself" to record any test data (engine data or flight data) that you want to record during the flight for later playback and test analysis.
And yes, there is also a patch cord adapter that we used in fighters (I flew F-4s for 28 years, so this was many years ago). When we wanted to record an air to air engagement we carried a small tape recorder in the G suit pocket and turned on the tape recorder before each engagement. Being able to replay each engagement before the debriefing helped us remember specific things we wanted to debrief.
Blue Skies,
Buz Rich
A Good Credit Score i3x1201028747/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=DecemailfooterNO62"> See yours in just 2 easy steps!
Posted: Sun Jan 18, 2009 8:42 pm Post subject: VEDIO AND AUDIO RECORDING |
Glenn,
Let me add one more comment to my last message since your subject line mentioned Video and audio recording. Of course, my previous comments had to do with audio recording. As to video recording, I recommend not trying to do any video recording if you are thinking about any kind of hand held camera. Your hands will be busy enough just flying the airplane during any testing. So keep the hands on the stick and throttle. Now if you have a helmet mounted camera or something that you can set up that you don't have to touch during the flight - OK.
Blue Skies,
Buz Rich
EAA Flight Advisor and Technical Counselor
Williamsburg, VA EAA chapters 156 and 1377
A Good Credit Score is 700 or Abovaol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=DecemailfooterNO62"> See yours in just 2 easy steps!
z601(at)anemicaardvark.co Guest
Posted: Mon Jan 19, 2009 6:52 am Post subject: VEDIO AND AUDIO RECORDING |
On Sunday 18 January 2009 20:18, GLJSOJ1 wrote:
Hi all
I haven't looked for one in years, but at one time there was a pickup coil
used to record phone conversations. There was a suction cup on the end, which
you stuck to the telephone, and a plug on the other end that would go to a
recorder or microphone.
I'd think the thing would also work very well with a headset. It has the
advantage (since it was not a microphone, just a coil to pick up the magnetic
field) of not getting any stray background noise.
Do not archive.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
Patrick.Best(at)telus.com Guest
Posted: Mon Jan 19, 2009 7:34 am Post subject: VEDIO AND AUDIO RECORDING |
EAA Mag "Sport Pilot" has an article about just this subject. They recommend a lapel mic stuffed into one of the headset earpeices. Any camcorder will have the input slot for the mic jack.
GLJSOJ1
Posted: Mon Jan 19, 2009 1:39 pm Post subject: Re: VEDIO AND AUDIO RECORDING |
Thanks everyone
I just read the article in sport aviation and was really thinking that was the way to go. Does that also pick up when I key the mike button to transmit? If so that's perfect
I plan to hard mount the camera over the baggage area and turn it on before I start the engine and turn it off when I shut it down.
Thanks again
Glenn
CHESAPEAKE VA |
tigerrick(at)mindspring.c Guest
Posted: Mon Jan 19, 2009 6:37 pm Post subject: VEDIO AND AUDIO RECORDING |
Hi, Glenn.
When we needed cockpit audio for aviation marketing videos, that's exactly what we did. A small Radio Shack bullet mike taped into the earcup and plugged into our camera worked perfectly, getting both the radio transmissions and the attenuated cockpit background noise.
If you can hear yourself transmit via the comm radio's sidetone, it will be picked up by the mike as well.
Good luck!
Rick Lindstrom
First Light Media
