Ianrat
Joined: 31 Mar 2008 Posts: 43 Location: Brisbane AUSTRALIA
Posted: Sun Jan 18, 2009 4:23 am Post subject: Rear Elevator trim deflection |
In the plans on page 6-T-6 the up and down deflection of the trim tab is stated as 20 up and 40 down how ever in the pictures that came on the CD that came with the plans it states 30 up and 30 down.
I am aware of the new limits for the rear elevator put out from Zenith but has there been any changes to the trim deflection.
Any suggestions.
Thank you
Ianrat
Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
Posted: Sun Jan 18, 2009 7:51 pm Post subject: Re: Rear Elevator trim deflection |
No changes that I'm aware of. The prints are what I follow and mine are dated 8/05 for 6T6. The on-line builder site updates don't state any changes either for the trim tab 20 degrees up and 40 degrees down.
From what I've learned about things the prints and a cross check of the print updates are what you need to follow. If you find a mistake or can't quite determine the answer, post a note here or call Zenith for help.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
https://sites.google.com/site/corvairenginedata/ |
Ianrat
Posted: Mon Jan 19, 2009 4:09 am Post subject: Re: Rear Elevator trim deflection |
On the disk under the section 6-T-6 the first page is a copy of the plans. It is dated the 08/05 the same as the printed copy. That is why i asked if there was any updated info. Due to the time difference from the USA to Australia i thought i would try the forum instead of waiting until Zenith opens next week.
Thank you
Ian Ratcliffe
Ron Lendon
Posted: Mon Jan 19, 2009 5:47 pm Post subject: Re: Rear Elevator trim deflection |
FYI,
I don't use the CD. I always get the most current information from the Zenith builders website. I have just started work on the fuselage and just printed out all the 6B pdf files from the web site. I check that and the print updates list when I start a new section of the build.
CH 601 XLB
N601LT - Flying
