uvtreith(at)t-online.de Guest
Posted: Thu Jan 15, 2009 1:18 pm Post subject: AW: AW: Retractable Landing light or LED |
Hi Fred,
Attached is a photo of the changed rudder and a PDF-file of that Luxeon LED light (very bright).
When I decided using LED wing Nav lights I did not like to use a standard bulb light for the tail. I found this LED solution and it was quite easy to make.
I bonded an aluminium tube in the rudder sized so that the aluminium cooling body of the LED fits easily and shaped a flange for the retainer ring with the 140° of an used Wheelen (or whatever) tail light. The electronic to this LED light is embedded in resin with two mounting lugs which I screwed on a second aluminium bus plate, which is installed underneath of the baggage bay and will be also used for the strobe lights, the wing lights and the door security switches..
Bruno
Von: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von Fred Klein
Gesendet: Mittwoch, 14. Januar 2009 21:29
An: europa-list(at)matronics.com
Betreff: Re: AW: Europa-List: Retractable Landing light or LED
On Jan 14, 2009, at 6:39 AM, UVTReith wrote:
I have installed LED Wing Lights from CreativAir.com with covers from Fred Klein and I am using Luxeon LED from Periheliondesign.com in an old Wheelen Housing.
Hi Bruno,
Your tail light looks intriguing...could you post a photo showing it from the side?
Fred
believed to be clean. | Quote: | | http://www.matronics.com/Navigator?Europa-List | 0123456789
653.08 KB |
215 Time(s) |
195.46 KB |
226 Time(s) |
 Download |
| Filename: |
Tail_Light_led.pdf |
63.07 KB |
| Downloaded: |
221 Time(s) |
