Fuse Stands
Phil.Perry(at)netapp.com
PostPosted: Mon Jan 12, 2009 5:50 pm    Post subject: Fuse Stands Reply with quote
Hi,
I'm expecting my QB fuse in the coming weeks and I'd like to have a fuse stand waiting on it.
After researching on Tim's site and he a photo of Rick Sked's fuse holder.
Does anyone else have photos of similar fuse holders?
Phil
MauleDriver(at)nc.rr.com
PostPosted: Mon Jan 12, 2009 7:18 pm    Post subject: Fuse Stands Reply with quote
I used two motorcycle stands from Harbor F (they were on sale). I used a couple of 2x4s to connect them, then I threw a 4x4 board on top. Crude but it is VERY easy to roll around.
Perry, Phil wrote:
Hi,
Phil
 Filesize:  151.41 KB
 Viewed:  492 Time(s)
 Filesize:  172.2 KB
 Viewed:  467 Time(s)
n8zg(at)mchsi.com
PostPosted: Mon Jan 12, 2009 7:29 pm    Post subject: Fuse Stands Reply with quote
Phil –
I used two engine stands from Harbor-Freight on my RV-7. Minor changes to the aft attachment would adapt it to the -10.
Phil
 Filesize:  42.78 KB
 Viewed:  468 Time(s)
 Filesize:  44.14 KB
 Viewed:  451 Time(s)
wcurtis(at)nerv10.com
PostPosted: Mon Jan 12, 2009 8:30 pm    Post subject: Fuse Stands Reply with quote
Here are some thoughts.
http://nerv10.com/wcurtis/fusestand/index.html
http://www.vansairforce.com/community/showthread.php?t=37550
William
pitts_pilot(at)bellsouth.
PostPosted: Mon Jan 12, 2009 8:37 pm    Post subject: Fuse Stands Reply with quote
Here's the best pic I have of my fuse stand. all 2X4s .... the uprights
have a screw (protect the spar with plastic hose around the screw)
through the wing attach holes, and the blocks on the step keep it from
sliding off. One crosspiece across by the uprights. Then I added an 8'
2X4 under that because the CG went too far aft with the tail feathers
on. Note the block on the floor next to the step ..... the 8' 2X4 sags
too much and needs another caster. This keeps the fuse low so you can
lean over to work on the innards and it rolls around when I need it to.
Linn
 Filesize:  195.48 KB
 Viewed:  452 Time(s)
rv10rob(at)gmail.com
PostPosted: Tue Jan 13, 2009 8:16 am    Post subject: Fuse Stands Reply with quote
I copied Rick's design and am very pleased with it:
http://nerv10.com/wcurtis/fusestand/fusestand32.html
On Mon, Jan 12, 2009 at 8:27 PM, William Curtis <wcurtis(at)nerv10.com (wcurtis(at)nerv10.com)> wrote:
[quote]--> RV10-List message posted by: "William Curtis" <wcurtis(at)nerv10.com (wcurtis(at)nerv10.com)>
William
ricksked(at)embarqmail.co
PostPosted: Tue Jan 13, 2009 8:34 am    Post subject: Fuse Stands Reply with quote
It worked well for me and the added benefit after I was done with it, I screwed a 4 x 4 sheet of plywood I had laying around to it and now its a roll around storage table.
Rick S.
40185
pascal(at)rv10builder.net
PostPosted: Tue Jan 13, 2009 8:44 am    Post subject: Fuse Stands Reply with quote
I sort of did too except I found that I had lots of wood from the crates the kits came in and used all that wood. Bought the caster/wheels from HF. Works well and is inexpensive
Sent: Tuesday, January 13, 2009 8:15 AM
Subject: Re: Fuse Stands
William
johngoodman
PostPosted: Tue Jan 13, 2009 10:29 am    Post subject: Re: Fuse Stands Reply with quote
Phil,
I took an old heavy-duty pallet I had laying around and put some casters on it, then covered the top with some old carpet padding. It worked well for a while but it tends to become a pain when you need access to the bottom.
If I were doing it over, I'd use Bill Curtis' simple plan.
