gmvouga(at)hotmail.com Guest
Posted: Tue Mar 14, 2006 6:04 am Post subject: Avionics Dealer References |
Hi everyone,
I am in the process of finalizing my avionics order and I would like some
input on the various dealers out there. Is there anyone that has provided
particularly good or bad service? Obviously, I would like to keep my costs
to a minimum, but I'm reluctant to deal with companies that have bad
reputations. I'm planning on installing the items myself, so a full service
shop is not required. I've listed the items I plan to install below in case
that makes a difference on recommendations.
GRT EFIS
Dynon D100 EFIS
Garmin GMA-340
Garmin GNS-430
Garmin SL-30
Garmin GTX-327
Advanced Flight Systems AOA Pro
Digiflight IIVSGV
Also, If you are a dealer please feel free to email me a quote at
gvouga(at)gmail.com.
Greg Vouga
RV-7A
Raleigh, NC
mlas(at)cox.net Guest
Posted: Tue Mar 14, 2006 7:28 am Post subject: Avionics Dealer References |
Greg,
I have dealt with every company that you listed. I will break down who
they are and give you my opinion of customer and tech support and how
many times I have had to use them in the last year or two. I am a seven
year avionics technician and an airline pilot with an A&P. I just
finished a project of my own, a Lancair Legacy with a Chilton EFIS, Blue
Mountain EFIS, Advanced Flight AF-2500 engine system and AOA system,
Garmin SL-30 SL-40 GMA-340 and GTX-330, Trutrak Sorcerer Autopilot, Sony
AM/FM/CD/DVD/XM entertainment system, GRT EIS 6000 Air Data, Light Speed
Plasma III (dual) electronic ignition, DAC GDC34A digital converter, and
Mountain High O2D2 oxygen system.
I'll get the big one out of the way first: Garmin GMA-340, Garmin
GNS-430, Garmin SL-30, and Garmin GTX-327 Garmin makes good stable
products and has top notch Technical support, and for the most par are
becoming the leader in general aviation avionics. All the units you
listed are robust, are TSO'ed and perform well. Garmin is a
manufacturer that uses a dealer network to sell and maintain their
products. Garmin will work directly with the home builder to provide
technical support. My favorite avionics shop that works well with
homebuilders is Aerotronics up in Montana. Gary Wirrell is the VP of
the experimental division and would be more then happy to answer any
questions you may have. Aerotronics address is: 1651 Aviation Place,
Billings Logan International Airport, Billings, MT 59105, Phone: (406)
259-5006, Fax: (406) 252-4369. I have a quick question about your
choice of the GTX-327, if you get the GTX-330 you will get the TIS
(Graphic Traffic function provided by approach radar)function which
provides traffic information that can be displayed on your Garmin
GNS-430 and maybe even you GRT EFIS. A Great Function!
Grand Rapids Technology GRT EFIS: I have purchased some products from
them but not the EFIS unit yet. My experience has been very favorable;
they have top end tech support and have been willing to up grade units
to suite for free. They make very stable products and I have had good
luck with them. Gary at Aerotronics is a seller for GRT or you can buy
direct.
Advanced Flight Systems AOA Pro: I can't say enough great things about
them. I have installed and/or use their products over six time and they
work great. On two occasions I had a minor problem with a unit and they
pulled out all the stops to make it right, what more can I say. I too
have the AOA Pro and love it. A good dealer for this product that I have
used is Robby Attaway at Attaway Air. www.attawayair.com.
Trutrak Digiflight IIVSGV: I have only worked with them a few times and
they have offered an acceptable level of service. The reason I say it
this way is, I haven't had the opportunity to truly test the tech
support because I haven't had any problems with their systems. I just
took delivery of the new Sorcerer autopilot which was in development
when I ordered it and they were always up front with what was going on
(no false promises just the truth) and they honored the original quoted
price without even having to ask. A good dealer for this product that I
have used is Robby Attaway at Attaway Air www.attawayair.com.
Dynon Avionics D100 EFIS: I have owned a D10 and installed a few
D10A's. Basically I find the unit a good VFR unit and mostly stable.
The unit works well but I feel their are other units out there that are
better for the price. One issue I have had with their systems from the
beginning is the lack of an internal GPS that would give you winds aloft
and TAS as well as position and an intergraded map. Other issues I have
had in the past have been the lack of interface to display external
navigation information like VOR/LOC/GS which most competing products
offer. I think their engine monitor system is missing some key system
information like trim indicators and fuel quantity. As for customer and
tech support I would rate them Fair; On the Tech side, if you get one of
them they are very knowledgeable and helpful. On the customer side I
found them to be less then helpful with options, changes and additions.
The tended to nickel and dime us and were hard to get a hold of most of
the time. With Dynon you can buy direct.
I hope this information helps.
Mike
Dynon D100 EFIS
dfultz7(at)earthlink.net Guest
Posted: Tue Mar 14, 2006 7:46 am Post subject: Avionics Dealer References |
What would you recommend over a Dynon for the price or there abouts with the
experience you have had? Thanks Dale
Posted: Tue Mar 14, 2006 8:09 am Post subject: Avionics Dealer References |
Dale,
For the price and product, I like and have had good luck with the most
recent release of the Blue Mountain products. Their earlier products
were poor performers, but the new line is much better. Like Dynon,
their customer support is fair. There are pros and cons to each product
but I find the BM provides more bang for the buck and it is more stable
then the Dynon. That's the EFIS side, on the engine monitor side I like
the Advanced Flight AF-2500 (Great), Xerion AuRacle(NEW! Good), and the
EI MVP-50 (Great but pricey)
Mike
glastar(at)gmx.net Guest
Posted: Tue Mar 14, 2006 2:14 pm Post subject: Avionics Dealer References |
Dale,
could you please specify in detail why the BM is more stable then the Dynon?
Many thanks
Werner
Mike wrote:
Dale,
Mike
Mike,
Thanks for all the input. You asked why i'm going with the GTX-327.
Basically it's price. The 330 is about double the price and my budget won't
allow it.
Thanks again,
Greg
[quote]From: "Mike" <mlas(at)cox.net>
Reply-To: avionics-list(at)matronics.com
To: <avionics-list(at)matronics.com>
Subject: RE: Avionics Dealer References
Date: Tue, 14 Mar 2006 08:27:02 -0700
Greg,
direct.
Mike
Dynon D100 EFIS
ktlkrn(at)cox.net Guest
Posted: Wed Mar 15, 2006 6:49 am Post subject: Avionics Dealer References |
Confused as to whether you are asking about the equipment or someone to supply the equipment.
I have nearly the same stuff. Sub out the SL30 for a 40 and the 327 for a 330S. I have the Dynon 10A and AF2500 engine monitor. Approach Systems Wiring hub. Wouldn't do anything different
Most everything was purchased from Stark Avionics. They are in Columbus GA so they are in your end of the country. I'd also highly recommend Steinair in Minnesota.
Darwin N. Barrie
Chandler AZ
RV-7 N717EE
rene(at)felker.com Guest
Posted: Wed Mar 15, 2006 8:17 pm Post subject: Avionics Dealer References |
Try: http://www.starkavionics.com/
Rene'
Posted: Wed Mar 15, 2006 11:11 pm Post subject: Avionics Dealer References |
Hi Mike,
I own a Dynon D10A (upgrading from a D10) and new an EMS-10 (engine monitor)
| Quote: | The unit works well but I feel their are other units out there that are
offer.
It's always up to what you want, I believe If you don't want to go the
expensive route and are happy what they offer for, it's a good deal for
the money (GPS signal integration is on the way)
| Quote: | I think their engine monitor system is missing some key system
Sorry, your information is incomplete, you can have up to four fuel
tanks connected to it and have a read out for them, further I'm not a
big fan of having flight information (trim) on the engine monitor, but
you have 3 General Purpose inputs which might be used
| Quote: | As for customer and
I agree, we (3 users) had to dispute a bit but found with Ron Ulbrich a
person you can discuss, we had a problem to get the D10 with the EMS10
and OAT to work, when we upgraded to the D10A and EMS10A we got the
EMS10A upgrade for free (after some discussion)
I think for a VFR airplane the D10A/EMSD10 or D100/EMSD120 with a price
for a 4cyl carbureted engine no fuel flow of 4500$ or the larger package
(including remote compass) for $5000 (fuel flow adds 200$ and add your
capacitive or resistive sensors) including all other sensors is a good
deal out of my view.
http://www.steinair.com/dynon.htm Steinair is a great dealer with many
helpful information too.
Werner
Posted: Fri Mar 17, 2006 5:58 am Post subject: Avionics Dealer References |
Thanks to all who responded. It seems that Stark Avionics, SteinAir, and
Affordable Panels all have great reputations within the group. I called
Stark a month or so ago requesting a quote and spoke to John directly. He
was very helpful on the phone and seemed to have very competitive prices. I
have not checked out the other two guys yet, but I plan on giving them a
call before I make my final decision in a couple weeks.
Thanks Again,
Greg
RV-7A
