Bob Perkinson
![](images/avatars/187783528146c31f0b12a13.jpg)
Joined: 10 Jan 2006 Posts: 51 Location: Hendersonville, Tennessee
Posted: Tue Jan 06, 2009 11:05 am Post subject: Static Line Route |
Group,
Where exactly did you rout the static line through bulkhead F5 (seat back bulkhead)? I am at the point or running the static line and have it up under the longeron, the way I see it the 7/16" hole needed to run the line would need to be placed some where well below the rivet group holding the F5 doubler, putting a 2" water trap in the line. Does this sag even matter? If the hole is drilled high on F5 it looks like the edge distance on the rivets would be violated.
If any one has photos of this area, that would be nice.
Bob Perkinson
| - The Matronics RV9-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV9-List |
wowens(at)darientel.net Guest
Posted: Tue Jan 06, 2009 1:46 pm Post subject: Static Line Route |
An RVator from about two years ago has a picture.
Bill Chenoweth
Posted: Tue Jan 06, 2009 2:33 pm Post subject: Static Line Route |
Thanks - I was just about to ask you for her name again. Looks like the
project is going forward.
Bill Chenoweth
Posted: Tue Jan 06, 2009 3:25 pm Post subject: Static Line Route |
Sorry folks - slip of the "response" finger with the "project is going
forward" thing.
However, Bob, regarding your static line routing. As mentioned, the RVator
has an article but as I recall there were some labeling errors in the
captions or such. I did mine the way the article suggested and am still
pretty much wide open in the fuselage department so I can send pictures if
you want.
Bill
Bob Perkinson
Posted: Tue Jan 06, 2009 3:47 pm Post subject: Static Line Route |
bmrv09(at)hotmail.com Guest
Posted: Tue Jan 06, 2009 5:37 pm Post subject: Static Line Route |
I have an rv6a C but I run mine C right under the longeron C all the way C then along horizontally to the insturment pannel..
I use plastic C stand offs C glue with proseal C C alongl the way to hold plastic line C with tie wraps.. Acutally you do not need that..
Robert
[quote] From: wowens(at)darientel.net
To: rv9-list(at)matronics.com
Subject: Re: Static Line Route
Date: Tue C 6 Jan 2009 16:42:48 -0500
--> RV9-List message posted by: "Wayne" <wowens(at)darientel.net>
