Monowheel Support
h&jeuropa
PostPosted: Sun Jan 04, 2009 1:29 pm    Post subject: Monowheel Support Reply with quote
We discovered our monowheel tire is flat yesterday. We have a fixture like Terry Steaver's to jack up the airplane. In the past when we have put blocks under the spars near the fuselage to support the airplane with the wheel off, the wings don't sit flat on them (tailwheel on the ground) and the support seems unstable (like the wings want to slide off the rear of the blocks). How do others support their airplane with the wheel off for maintenance?
Jim & Heather
N241BW
paul.the.aviator(at)gmail
PostPosted: Sun Jan 04, 2009 2:22 pm    Post subject: Monowheel Support Reply with quote
Hi Jim & Heather,
I use the same jacking block. What I do is chock the tail wheel,
place blocks under the outriggers so the wings don't rock, and once I
pull the wheel off I have a thick block of wood that I place under the
swing arm. I then lower the jack until the swing arm touches the
block. Although it would be possible for it to "all fall over", I
generally find that this is stable enough.
How did you get out to your hanger this time of year, dog sled ?
Cheers, Paul
terrys(at)cisco.com
PostPosted: Mon Jan 05, 2009 9:59 am    Post subject: Monowheel Support Reply with quote
Hi Jim,
We use the wooden jacking block when we just need to remove the wheel.
When working on the gear (and needing to retract it) we put blocks
under the wings at the spar locations. We first remove the tailplanes
and put saw horses under the tailplane torque tubes to level the plane.
We then tie weights to the tail wheel to keep the tail down once the
plane is resting on the wing spars. We then jack the plane up with the
jacking block and put the blocks under the wings, with blue foam pieces
touching the wing skin to minimize scratches, etc. We can then lower
the jack, leaving the plane on the wing blocks. The weight on the tail
is necessary because the plane will be nose heavy (stable in pitch) when
resting on blocks at the center of lift.
Terry Seaver
