fvalarm(at)rapidnet.net Guest
Posted: Fri Jan 02, 2009 6:41 pm Post subject: Using TurboCad |
To the Cad whizzes out there.
I'm taking advantage of the bad weather and trying to "professionalize" my wiring diagrams using TurboCad. I'm starting to feel really old here cause I'm so frustrated with this TurboCad program. I really want to make it work and not get something else. I've imported a drawing from Bob's collection in DWG format. All I want to do is erase a few lines, re-draw them slightly elsewhere and copy a few fuses to add the extra circuits. Erase, copy, cut, paste, snap are eluding me even though there are a bazillion tools all around. Can I not just put a square around a section of the drawing, cut and paste etc?
Jack Daniels is starting to tempt me!
Bevan
[quote] [b]
harley(at)AgelessWings.co Guest
Posted: Sat Jan 03, 2009 7:11 am Post subject: Using TurboCad |
Morning, Bevan...
It's been awhile since I played with TurboCad, I use VisualCad now, but the basics are pretty much the same in just about any CAD program.
First, you may not be able to work directly with the dwg file, in case you are. Save it in Turbocad format before doing anything else. Then close the dwg file, open the Turbocad file and work with that. Although I have no problem editing Bob's drawings directly in VisualCAD, TurboCad may be different. Different CAD programs treat dwg drawings differently and may not allow editing until in the native format.
I just checked one of Bob's Z drawings in my VCADD, and was able to edit it without any conversions, but it may be different for you in TCADD.
>>Can I not just put a square around a section of the drawing, cut and paste etc?<<
Yes and no! Remember, unlike the normal graphics we see on computers, CAD programs are a collection of components like lines, squares, circles and other geometrics as well as symbols that are complete in themselves. With a "normal" raster graphic (like a jpg or bmp file) simply drawing a "square" ("window" in CAD speak) around what you want to delete, then hitting the delete key removes everything inside the window.
However, with CADD some of the components may lie OUTSIDE your selection window (like unseen points used to construct the object you are seeing...known as construction points. Or the other end of a line or symbol). When editing, CAD programs consider only COMPLETE objects and their components that are inside the window as having been selected.
For example, putting a selection window around a straight line but not including one end of it, will not select that line. Also, curves and text often have reference points considerably removed from what you see. Unless these are included in the window, the object you see and want to work with will not be selected.
In summary, any object whose visible AND invisible parts are inside the selection window will be selected and can be edited or removed.
I find it easier to just use the selection tool (usually an arrow) to point to (then click on) an object to see what is included. Whatever gets highlighted is the entire object that has to be selected to edit. Right clicking then usually produces a menu of options for the highlighted (selected) object. Or you can use the delete key, ctrl-c or ctrl-x if you want to remove it, copy or cut respectively.
To display the normally invisible construction points, which must be included in the selection, look for the command "Display Construction Points", or something similar. In Visual CAD it is the two letter command "DC".
If the item you've selected by clicking on it with the selection pointer appears to be complex, i.e. made of several lines, circles, curves, etc, that are all highlighted at once, it has been been made into a symbol. If you want to remove the entire symbol, you're all set, as it has been selected in it's entirety. If you want to edit only a portion of it, then you first have to "de-symbolize" it (now that's a new word!). Look for a command that will do that. In VCADD, it's "Explode Symbol" (YX). You will then see the symbol broken down into it's component parts, and you can edit the individual lines, circles, text, etc.
Hope this helps a bit...remembering Turbocad when I worked with it, I seem to recall that it had a pretty good help system, so any questions you have can probably be answered with a bit of search. The learning curve will eventually get you to the point where you can be comfortable with the level of drawing that you need. There are many commands and procedures in VCADD that I don't use, but with the drawing I do, I probably never will.
Harley Dixon
B Tomm wrote: [quote] To the Cad whizzes out there.
Bevan
Posted: Sat Jan 03, 2009 7:23 am Post subject: Using TurboCad |
Hi Bevan,
The (AutoCAD) Dwg format needs to be saved as a TurboCAD format. That
said, some of the characteristics of line manipulation will not carry over
and you may need to break the drawing down to smaller elements or just
make a new drawing. Starting with the TurboCAD is the better idea and when
you get used to the program, you'll find it twice as fast as AutoCAD and
much more intuitive.
Larry McFarland 601HDS
B Tomm wrote:
| Quote: | To the Cad whizzes out there.
cut and paste etc?
Bevan
Allen Fulmer
Joined: 10 Jan 2006 Posts: 79 Location: Alexander City, AL
Posted: Sat Jan 03, 2009 12:16 pm Post subject: Using TurboCad |
I have had pretty much the same frustrating experience with Turbo CAD! I bought the version 10 like BobN suggested for $10 or so, but found the program and internet devoid of any help or tutorials. Finally gave up.
I get regular emails from the IMSI folks trying to get me to upgrade to the latest version, 15.2, for 50 bucks or so. Anyone care to offer an opinion on versions?
I need to do something as my hand done drawings (sketches) won't really do for the finished product.
Allen Fulmer
RV7 Wiring
Alexander City, AL
[quote] --
_________________ RV7 QB Fuselage
Eggenfellner H6 on orde
N808AF reserved
Alexander City, AL |
Posted: Sat Jan 03, 2009 1:17 pm Post subject: Using TurboCad |
Hi Allen,
TurboCAD is a fine program for one off drawings. Having experienced Pro
E and AutoCAD, I've found TurboCAD is a versatile program if you sit down
and read the reference manual completely. Spend a little time with it
and you can't help but like it. If it's not part of your background,
i.e., engineering or design
you may take a little longer to get on with it, but don't get
discouraged. I used the Aeroelectric guidance and did a
schematic/drawing in TurboCAD
without too many of the formal symbols.
http://www.macsmachine.com/images/electrical/full/primary-wiring.gif
Allen Fulmer wrote:
| Quote: | I have had pretty much the same frustrating experience with Turbo
Finally gave up.
Allen Fulmer
RV7 Wiring
Alexander City, AL
Allen Fulmer
Posted: Sat Jan 03, 2009 3:18 pm Post subject: Using TurboCad |
Thanks for the encouragement, Larry.
Any comment on version 10 vs. latest (15.2 at this time)?
Allen
[quote]>>--
N808AF reserved
Posted: Sat Jan 03, 2009 6:30 pm Post subject: Using TurboCad |
Allen,
I started with version 8 a long time ago, but kept upgrading and using
TurboCAD to put models into a TrueSpace
program. Pro E was dropped at work and I got involved in modeling
military equipment that the USMC needed. Several
upgrades included V10 and it's still a good program. I now use version
15 (mechanical) and it supports pretty much anything you
want to do. A small price for a program that does 3-D modeling so well.
It even has a good rendering capability that
provides material surfacing, accurate reflections and shadowing. that
can be used within (Light Wave) an animation
program that I use. If you intend to advance your work or employment
with engineering drawings, TurboCAD
is a fine program to know. If you only need it for the current wiring
diagrams, and your aircraft project, then Version 10
is likely all you'll ever really need.
Allen Fulmer wrote:
Allen
mrspudandcompany(at)veriz Guest
Posted: Sat Jan 03, 2009 7:10 pm Post subject: Using TurboCad |
I purchased the tutorial from IMSI. I found it to be quite good for a relative beginner. There are a lot of subtleties that are hard to ferret out of the manual alone, and the tutorial leads you through many of these and gives you a very good starting point.
Good luck,
Roger
Allen Fulmer
Posted: Sat Jan 03, 2009 9:10 pm Post subject: Using TurboCad |
Thanks Larry,
Guess I'll give it a try again. And maybe contact IMSI re: upgrade and/or
tutorials.
And I've bookmarked your web site to see what you have done.
Allen
DO NOT ARCHIVE
N808AF reserved
Sam
Posted: Sun Jan 04, 2009 6:01 am Post subject: Using TurboCad |
I have used various CAD systems over the years and when I retired I was seeking a good free one for home use. I came across a professional program called Siemens' Solid Edge Designer for 2D. I really like it. It uses something called "Relationship handles" which is useful, but difficult for me to describe here.
The company makes it free to individuals and companies in the hope that you like it so much that you'll upgrade to their 3D system. It does work with all of Bob's drawings.
The bad new is there is no manual available. The good news is the online help is adequate and, best yet, there is also ae e-mail list run by tech experts at SolidEdge.
Sam Hoskins
Murphysboro, IL
On Fri, Jan 2, 2009 at 8:40 PM, B Tomm <fvalarm(at)rapidnet.net (fvalarm(at)rapidnet.net)> wrote:
Bevan
_________________ Sam Hoskins
www.samhoskins.blogspot.com |
Eric M. Jones
Posted: Sun Jan 04, 2009 9:56 am Post subject: Re: Using TurboCad |
Eric's Guaranteed Ten-Step Program for Learning TurboCAD (or any CAD program):
Intro:
1) Almost all CAD programs are wonderful. The more expensive ones have only a tiny bit more than the cheapest (or the FREE ones). Any CAD is a million times better than no CAD. CAD, along with a web browser, email, a spreadsheet and a word processing program are just about required to express your technical talents nowadays.
2) Pareto's Principle: 20% of any tools will do 80% of the work, so you don't have to learn it all. Once you can do the basics, you will intuitively know there are additional tools for more complicated stuff.
3) If you really want to get good at mechanical drawing, get a copy of ANSI-Y14.5M Dimensioning and Tolerancing. The 1982 edition is $20 and 99% current today. The 1994 edition is about $90 on Amazon. This is not required for electrical schematics and other arts.
4) You'll need a good monitor, a decently fast computer (Especially for 3D), and a mouse. But you can use any printer, and the fancy devices you sometimes see in CAD setups are not needed.
Basics:
5) The computer screen is a window to look through, not a piece of drawing paper to look upon. This simple idea often baffles new users. Understand this thoroughly or you will be lost.
6) CAD has no display scale. Print scales are only rarely followed (see point 5). A CAD information block never (or rarely) says "SCALE", unless the boss is an idiot.
Learning it:
7) If you have a paper tutorial manual (remember the software has the manual in it, usually in a more usable form). Turn on the CAD program. Tear the covers off the manual and drop them into the trash. Then look at a page, understand and DO what is on it and drop it into the trash. Don't puzzle over anything...you can do that later. If a tool does not seem relevant, toss it into the trash. Very satisfying.
Turn off the CAD program and sleep on it. You'll get better at it as you sleep.
9) Remember that there is a simple way to do everything, and CAD has tools to make those simple task even easier (and more sophisticated), but you can always revert to doing things in simple ways. As a learning game--Draw a circle: It can be done with a center and one point on the circumference, Two semicircles, four quarter-circles, the letter "o", the zero, a three point circle, a freehand sketch...see how many you can come up with.
10) Start using it. Begin slowly and don't beat yourself, and don't push yourself if it is not fun--because you'll never learn it unless you enjoy it.
Appendix:
CAD provides an infinite variety of capabilities. Sometimes machined parts are drawn as CAD drawings, but a layer under the drawing can be the Bill of Materials, the revision history, design notes, whatever. A drawing can have a huge number of layers.
A thing drawn in CAD can be saved and never has to be drawn again. CAD data can be input to automatic machinery to make a part. CAD can be drawn parametrically to make different sized parts. The applications are endless.
Things can be drawn in CAD that simply CANNOT be drawn by hand. These vary from the simplest second-order curves to complex spirals, and 2d and 3d geometric forms, Bezier splines, log curves, etc.
Finally:
Have faith! Sell or give away your set of mechanical drawing tools, including Tee Square and drawing boards, templates and engineering rulers, drawing pens, triangles, french curves, centers, trammels, lettering guides, electric eraser, on and on....That day ain't never coming back.
ps (Google "TurboCAD tutorial" NOT "turbo CAD tutorial").
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
ainut(at)hiwaay.net Guest
Posted: Sun Jan 04, 2009 11:21 am Post subject: Using TurboCad |
I've tried several CAD programs over the years, an own a version of TurboCAD. What I dislike intensely about these is the horrible user interface. None of them are intuitive. Just to layout a simple wall with adjoining wall is my initial test. All of them fail. <sigh>
David M.
jaybannist(at)cs.com Guest
Posted: Sun Jan 04, 2009 11:37 am Post subject: Using TurboCad |
Try AutoCAD Lite. I have been using AutoCAD for about 25 years and find it very intuitive for the basic functions. (I suppose that experience could have something to do with that ;>) AutoCAD Lite has all the basic functions plus. It is probably more expensive than others, but it WILL do what you want it to do.
Jay in Dallas
Eric M. Jones
Posted: Sun Jan 04, 2009 1:08 pm Post subject: Re: Using TurboCad |
Let's not make this a back-and-forth about which CAD program is best. TurboCAD is fine (and it's NOT even what I use...). ALL CAD programs are good, and the differences between them make comparisons difficult. Any first-time user might find the learning curve steep, but see my (above)suggestions. Simple programs are easy to use but limited, complex programs are harder to learn but powerful and expensive.
But learn SOMETHING, and they all talk to each other...so what the heck.
"....be sure to make a copy of everything before getting rid of it."
--Samuel Goldwyn
113 Brentwood Drive
(508) 764-2072
Posted: Sun Jan 04, 2009 4:45 pm Post subject: Using TurboCad |
Thanks for advice. I am downloading now and will give it a try.
Bevan
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sam Hoskins
Sent: Sunday, January 04, 2009 5:58 AM
Subject: Re: Using TurboCad
Sam Hoskins
Murphysboro, IL
Bevan
emrath(at)comcast.net Guest
Posted: Mon Jan 05, 2009 5:19 pm Post subject: Using TurboCad |
FYI, I downloaded for free the Turbocad LE or Learning edition. The
tutorial is on line. Worked for me, but it is a bit cumbersome but it was a
good price to value ratio.
Marty
Brentwood TN
Time: 04:45:24 PM PST US
Subject: RE: Using TurboCad
Bevan
_____
Hoskins
called Siemens'
<http://www.plm.automation.siemens.com/en_us/products/velocity/solidedge/fre
e2d/index.shtml> Solid Edge Designer for 2D. I really like it. It uses
Sam Hoskins
Murphysboro, IL
and paste etc?
Bevan
Marty ҿӬ
n85ae
Posted: Wed Jan 07, 2009 7:48 am Post subject: Re: Using TurboCad |
I use plain old graph paper, with a sharp pencil, and a ruler and
some symbol templates and draw electrical drawings REALLY fast!
Spend more time trying to get software installed and running on my
PC, let alone the learning curve to use them, than I can pencil out
a light airplane electrical system by hand.
Jeff
Posted: Wed Jan 07, 2009 9:30 am Post subject: Using TurboCad |
Thanks Jeff,
I've been making some headway with TurboCad, but considering the time and
frustration level, may go back to paper too. Some entrepreneurial type may
want to develop a very simple cad program for homebuilders including
preloaded drawings and symbols.
Bevan
rv-9a-online(at)telus.net Guest
Posted: Wed Jan 07, 2009 10:10 am Post subject: Using TurboCad |
Bevan, have you tried expressPCB's schematic program?
It's easy to learn and free.
Here's a link to get you started, including my RV-9A schematic
http://vx-aviation.com/#Free%20Stuff
Vern
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Wed Jan 07, 2009 10:26 am Post subject: Using TurboCad |
I think the simplest program to use for diagramming might be Microsoft's
Visio, but it's not cheap.
I have been using CAD full-time for over 25 years and I know I could sketch
out a diagram faster with pencil and paper, but I would use CAD to make it
legible and presentable, just like Bob N. does.
Terry
