rlborger(at)mac.com Guest
Posted: Fri Jan 02, 2009 6:49 pm Post subject: Taxi test videos |
Fellow Europaphiles,
My friend Joe Flood made videos of some of the taxi testing we did on
2008 01 01. Should you be interested, go to You Tube, type "Bob's
Europa" into the search box and click on "Search." You should see 5
videos. #003 is not of the Europa, but of a nice Cessna 195 taking off.
Check six,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
(99.999% done) Essentially complete. Running Tests & Final Inspections.
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
josok-e(at)ukolo.fi Guest
Posted: Fri Jan 02, 2009 9:59 pm Post subject: Taxi test videos |
Happy New Year to everybody here!
Great to see your bird moving under it's own steam, looking beautifully Bob.
You must be even more happy then i am, seeing this
What was the fuel problem mentioned?
I think the door-close slings will end up outside the cockpit real soon now, and give you a fright.
Good luck with the first flight,
Jos Okhuijsen
Visit - www.EuropaOwners.org
Posted: Sat Jan 03, 2009 6:22 pm Post subject: Taxi test videos |
Jos,
And a Happy New Year to you too!
Good to hear from you.
Yes, we are quite happy with the progress to date. There is an issue
with the rudder pedal attachment on the pilot side. That's going to
take a week or so to fix. Then I am redirecting the tail wheel drive
cables. My idea of running them out the sternpost isn't working well
at all. I'm in the process of running them in a straight line out the
sides of the tail to the tail wheel.
The fuel problem was encountered the first time we actually tried to
fill the tank from the fuel pump. I was carefully running fuel into
the filler hole and things seemed to be going quiet well. Suddenly,
there was a huge fuel gyser that must have dumped a quart (250 ml,
probably all the fuel that was in the filler neck) of fuel into the
door and down into the well behind the passenger. Fuel all over.
Found out that the vent is the limiting factor on how rapidly you can
put fuel into the tank. Fueling is a slow process
Those door-close slings are necessary to ensure the rear bolt-shoot is
engaged. Really can't close the door without using them. So the end
up inside when you close and properly latch the door. We'll have to
see how they work over time.
Thanks, still a couple more weeks till first flight.
Best regards,
Bob Borger
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
beautifully Bob.
Jos Okhuijsen
Posted: Sat Jan 03, 2009 6:54 pm Post subject: Taxi test videos |
Craig,
If I can ever find my miniscule little video camera, I hope to mount
it on the pilot headrest to collect video in flight.
There will be three folks present at the first flight: Gary, the
first flight pilot, Tommy and I. Either Tommy or I will be operating
video camera and the other a still camera.
Right now, no telling when that will be. Still lots of testing to do
and some fixes to make.
Check six,
Bob Borger
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Jan 3, 2009, at 20:50, craig bastin wrote:
hopefully you will have time to video the test flights for us all...
hint
hint
fklein(at)orcasonline.com Guest
Posted: Sun Jan 04, 2009 9:35 am Post subject: Taxi test videos |
Bob...thanks for posting these videos...they've given me some vicarious
thrills for a Sunday morning before heading out to the workshop.
Nice to see your thoughtful (and unhurried) preparations for 1st flight.
Best of Luck,
Fred
believed to be clean.
topglock(at)cox.net Guest
Posted: Sun Jan 04, 2009 9:44 am Post subject: Taxi test videos |
Great to see that you're "almost" done. Maybe we'll see you at the
Rough River gathering, this year...
Jeff - Baby Blue
Robert Borger wrote:
Quote: |
Jos,
cables. My idea of running them out the sternpost isn't working well at
fill the tank from the fuel pump. I was carefully running fuel into the
filler hole and things seemed to be going quiet well. Suddenly, there
was a huge fuel gyser that must have dumped a quart (250 ml, probably
all the fuel that was in the filler neck) of fuel into the door and down
into the well behind the passenger. Fuel all over. Found out that the
vent is the limiting factor on how rapidly you can put fuel into the
engaged. Really can't close the door without using them. So the end up
inside when you close and properly latch the door. We'll have to see
Best regards,
Bob Borger
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
> beautifully Bob.
> Regards,
> Jos Okhuijsen
Posted: Sun Jan 04, 2009 10:13 am Post subject: Taxi test videos |
Jeff,
Well, I sure hope it's flying by that time! Unless Mo schedules
another cruise at the same time, I plan to be there.
Check six,
Bob Borger
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Jan 4, 2009, at 11:42, Jeff B wrote:
Quote: |
Jeff - Baby Blue
