Engine and radiator hoses
paul.the.aviator(at)gmail
PostPosted: Sat Jan 03, 2009 10:32 am    Post subject: Engine and radiator hoses Reply with quote
Hi all
Some time ago someone posted a few pictures of blue silicone hoses for
the rotax engine and radiator. I was wondering who that was and if
the hoses turned out to be a success.
Thanks, Paul
Gilles.Thesee(at)ac-greno
PostPosted: Sat Jan 03, 2009 11:04 am    Post subject: Engine and radiator hoses Reply with quote
Paul and all,
When installing our 914, someone had installed blue silicone hoses, and
showed really great pictures of his engine. As the price of those
"racing-car" hoses was high, we were induced into thinking that we would
get what we were paying for from this race-car online shop.
The result was disappointing :
- Those hoses are slippery, and tend to slip out of their fittings
despite dual hose clamps. Scary when it concern oil lines. They needed
constant surveillance.
- They are rather bulky, and hard to route in our really cramped
cowling. But I understand that the Europa is somewhat larger in this
respect.
- They are very flimsy, and this may prove critical concerning oil
aspiration from the oil tank when cold (see relevant Rotax SBs)
- The soft material gets cut by the clamps we were using.
- And most important, this multiple layer blue material was porous : it
started "sweating" oil through the hose walls from day one on every
line. No measurable amount, though, but enough to make things a bit
untidy, and make us worry about our circuits liquid-tightness. Nothing
visible with radiator
Bottom line, we finally replaced them with regular rubber-based hoses,
and dumped the sticky blue stuff. No problem since.
Took some pictures at the time, for a future information page on Contrails.
Caveat builder Wink
FWIW,
With Best Wishes,
Gilles
http://contrails.free.fr
karelvranken(at)hotmail.c
PostPosted: Sat Jan 03, 2009 1:41 pm    Post subject: Engine and radiator hoses Reply with quote
Hi Paul,
If my memory is still intact it was Svein Jonhsen
sidsel.svein(at)oslo.online.no who refered to a Swedish man perhaps Stefan
Ingmarsson who used that kind of blue hoses. I don't know if it was with
success. You may ask him directly about.
Kind regards,
Karel Vranken.
Ivor Phillips
PostPosted: Sat Jan 03, 2009 1:51 pm    Post subject: Engine and radiator hoses Reply with quote
Hi Gilles
I wouldn't use Silicone for oil or fuel its NOT a suitable material,
But its use for water/ glycol mix is recommended, If you use the latest Rotax type spring clamps it will stop any weapage due to expansion and contraction,
I have changed all my coolant pipes to silicone and after 130 hours haven’t lossed a drop, IMHO they are superior to the rubber hose supplied by Europa,
regards
Ivor
Paul and all,
respect.
rparigor(at)suffolk.lib.n
PostPosted: Sat Jan 03, 2009 2:14 pm    Post subject: Engine and radiator hoses Reply with quote
Hi Gilles
Silicone hose is suitable for coolant and intake.
It is not well suited for fuel or oil.
See www.mcmaster.com
search 51845KAC
I have a set of blue silicone hoses for coolant and intercooler. It was
purchased from the guy who was advertising them in the Europa Clubs
newsletter.
Best use constant tension spring type clamps if you can. Some race car
guys that really turn up turbo have them pop off. One secret that seems to
work is they clean and install with hairspray on intake.
Ron Parigoris
PostPosted: Sat Jan 03, 2009 2:22 pm    Post subject: Engine and radiator hoses Reply with quote
Ivor,
Thank you for the info.
I must say that we never lost a drop of water, whatever the hoses. The
cylinder head to expansion tank hoses and clamps came with the engine.
Out of memory the fuel lines are Aeroquip 601 or something.
Best regards,
Gilles
kheindl(at)msn.com
PostPosted: Sat Jan 03, 2009 5:25 pm    Post subject: Engine and radiator hoses Reply with quote
Paul C
I bought the two silicone hoses to/from radiator from Ingmarsson in Sweden C but by the time you pay for shipping C paypal fee C and taxes C I ended up paying almost 200 dollars. You can buy several sets of rubber hoses from Europa for that. I replaced the other coolant hoses with silicone hoses from ACS. I use ss hose clips C but may change to those oetiker clips.
Karl
Date: Sat C 3 Jan 2009 12:29:52 -0600
Subject: Engine and radiator hoses
--> Europa-List message posted by: "Paul McAllister" <paul.the.aviator(at)gmail.com>
Hi all
Th======================
&gt==================
air.guerner(at)orange.fr
PostPosted: Sun Jan 04, 2009 9:17 am    Post subject: Engine and radiator hoses Reply with quote
Hi Paul,
I have installed the blue silicone hoses from Stefan Ingemarsson on the water radiator and am very happy with them. The replacement was done one and a half year and 150 flying hours ago. The silicone is a lot better than the original rubber material for withstanding the heat radiated by the exhaust. Expensive but absolutely worth it in my opinion.
Remi
F-PGKL
630 hours now
Hi all
cptimm(at)telus.net
PostPosted: Sun Jan 04, 2009 10:40 am    Post subject: Engine and radiator hoses Reply with quote
I am also flying with the silicone hoses from Stefan Ingemarsson in Sweden and find them to be very high quality and easy to install. For the spring-clips I could not find a special tool and used an old pair of two-position pliers, which worked like a charm. Europa Aircraft could not supply the formed hoses for the classic mono-wheel at the time.
I also recently finished and installed fairings for the main wheel and have flown with that installation for a few hours. It turns out, that there is lots of room for a landing light in the forward part of the fairing, which is attached to the swinging arm. I have made moulds for the two-part fairings and could produce the moldings for interested parties.
Peter Timm
#110
 Filesize:  17.47 KB
 Viewed:  235 Time(s)
