aviateer
Posted: Wed Dec 03, 2008 10:48 am Post subject: Trailering a Kitfox |
I trailered my Kitfox about 300 miles. When folded the wings back out, I noticed that from the flaperon vibrating on the horizontal stabilizer in the folded position, it wore the aerothane off clear to the fabric. Any suggestions on how to alleviate this in the future?
Also, what about keeping the inside of the Kitfox dry while trailering? I had a tarp on it, but it still got wet in the cockpit as I trailered. And the tarp wore some of the paint as well.
Kirk
clint_bazzill(at)hotmail. Guest
Posted: Wed Dec 03, 2008 11:20 am Post subject: Trailering a Kitfox |
I keep my aircraft at home and trailer it to the airport all the time. I have a foam piece on each flaperon to keep it from rubbing. Keep them in the wing lockers and use velcro to quick fasten it in place. I use wing supports also.
Clint Kitfox IV 1400 hours.
Date: Wed C 3 Dec 2008 12:47:47 -0600
Subject: Trailering a Kitfox
I trailered my Kitfox about 300 miles. When folded the wings back out C I noticed that from the flaperon vibrating on the horizontal stabilizer in the folded position C it wore the aerothane off clear to the fabric. Any suggestions on how to alleviate this in the future?
Also C what about keeping the inside of the Kitfox dry while trailering? I had a tarp on it C but it still got wet in the cockpit as I trailered. And the tarp wore some of the paint as well.
Thanks C
Kirk
ww.matronics.com/contribution
Quote: | http://www.matronics.com/Navigator?Kitfox-List
ronics.com
815TL
Posted: Wed Dec 03, 2008 11:35 am Post subject: Re: Trailering a Kitfox |
I trailered my Kitfox about 1200 miles from the Minneapolis, MN area to Corning, NY. About 20 miles into the trip the first day I noticed that this was going to be a problem. The rudder wanted to slap around on the flaperons. I pulled into a K-Mart and boughth a $3 bath towel, and a roll of duct tape. I taped the towel around the rudder, and it made a nice soft cussion between the rudder and flaperons. It sayed on the full 1200 mile trip. There was one small spot that was not covered, that I had to touch up the paint on. It reduced the flapping of the rudder as well.
Not a pretty, nor permanent fix, but for the occasional trailering, it works fine.
Andrew
Kitfox II, 815TL, Rotax 582-C
Lynn Matteson
Posted: Wed Dec 03, 2008 11:51 am Post subject: Trailering a Kitfox |
Rubbing on the *horizontal stab*? Mine doesn't even come close. I got
the trailer-towing pad from Skystar just before they went belly-up,
but it doesn't protect the horizontal, just the vertical. Do you have
the standoffs that keep the wing from going back too far? And do you
have the wing support brackets that go from the front spar down to
the lower fuselage bracket?
To keep it dry, you have to use plastic film and about a roll of duct
tape! Well, maybe not a whole roll. A tarp won't do much good unless
it is taped down everywhere. I think a tarp is too heavy, and when it
gets to oscillating in the wind, it's gonna beat the crap out of the
paint, but I guess you found that out.
Lynn Matteson
Jabiru 2200, #2062, 593hrs
Sensenich 62x46
flying again after rebuild, and new Electroair direct-fire ignition
system;
also building a new pair of snow skis
On Dec 3, 2008, at 1:47 PM, Kitfoxkirk wrote:
Quote: | I trailered my Kitfox about 300 miles. When folded the wings back
Kirk
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
msm_9949(at)yahoo.com Guest
Posted: Wed Dec 03, 2008 11:56 am Post subject: Trailering a Kitfox |
Kirk,
I use a piece of scrap carpet, about 10" wide, cut to slip over the vertical stab and sewn together fuzzy side in. I only tow about 6 miles to the airport and haven't really had any issues with wear on the horizontal stab. Can't think off-hand how that would even rub on the flapperons. Trailing edge of the elevator, maybe, but only if it's secured for travel in full-up position.
As for water, even with an expensive custom made, padded cover there is always going to be some leakage IMO. Water under pressure will go anywhere pressure is lower, which generally, is precisely where you don't want it to go
matronics(at)bob.brennan. Guest
Posted: Wed Dec 03, 2008 12:08 pm Post subject: Trailering a Kitfox |
Using the duct tape ONLY on the plastic film or tarp, never on the paint,
right Lynn? Duct tape and aerothane like to stick together, and stay
together. I found that out when I repainted my plane, and that was the
low-sticky painter's tape too.
A small tarp with eyelets and bungees wrapped around the belly works well
without leaving any marks, if you can find the right size/shape tarp.
I fold and trailer mine all the time - and I find a double-thick U-shaped
hunk of black Duct tape right where the flaperons rub (yes on the vertical
stabiliser) works as a permanent solution. I strap the wings together to
keep them tight, once wing-to-wing and once to the trailer for redundancy.
Since I trailer it backwards having a wing unfold at speed is my worst
nightmare!
Bob Brennan - N717GB
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
Lynn Matteson
Posted: Wed Dec 03, 2008 12:46 pm Post subject: Trailering a Kitfox |
Actually, I used duct tape right on the Poly-Fiber paint. I have had
it pull some paint like when I tape over a bunch of air leaks getting
the plane ready for winter, but very little. Of course, there is duct
tape and there is duct tape....that stuff varies all over the place
as far as quality goes, but yes, you should try to avoid taping right
onto the paint if you can. The thing you gotta ask yourself is "do I
feel lucky?" Well, do ya......ooops, sorry I got carried away.
Whatever you do, DON'T use Gorilla Tape...that stuff is amazing, and
sticks so good you will have Trouble getting it off the roll...and
that's Trouble with a capital "T" and that rhymes with "P" and that
stands for.....damn, why can't I get those movies out of my head!? : )
Anyway, back to reality, you're probably better off laying the tape
down sticky side out, around the fuselage, and then pressing the
plastic film/tarp onto it. It might not be as good a seal, but you
wouldn't pull any...or much...paint off.
Lynn Matteson
Sensenich 62x46
system;
On Dec 3, 2008, at 3:07 PM, Bob Brennan wrote:
Quote: |
<matronics(at)bob.brennan.name>
paint,
works well
shaped
vertical
together to
redundancy.
nightmare!
N369LM |
jdmcbean(at)kitfoxaircraf Guest
Posted: Wed Dec 03, 2008 12:50 pm Post subject: Trailering a Kitfox |
Kirk,
We have a Tow package that includes the tail pad and wing support braces for the leading edge. Wing hold backs if needed are also available.
Fly Safe !!
John & Debra McBean
Ph 208.337.5111
www.kitfoxaircraft.com
"The Sky is not the Limit... It's a Playground"
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Kitfoxkirk
Sent: Wednesday, December 03, 2008 11:48 AM
Kirk
Tom Jones
Posted: Wed Dec 03, 2008 5:32 pm Post subject: Re: Trailering a Kitfox |
Quote: | I noticed that from the flaperon vibrating on the horizontal stabilizer in the folded position, it wore the aerothane off clear to the fabric. Any suggestions on how to alleviate this in the future? |
Kirk, is it a speedster? They have little or no wing dihedral. That can cause the flaperons to be close or touch the horizontal stab. If you have the electric trim, be sure to trim nose up (leading edge of horizontal stab down) before swinging the wings back.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
vetdrem
Posted: Wed Dec 03, 2008 6:43 pm Post subject: Re: Trailering a Kitfox |
I bought a foam "noodle" that is normally used in a swimming pool, cut it in half, making 2 pieces about 3' long. Then I cut a slit lengthwise in each piece. when the wings are folded aft, the trailing edge of the flapperons are up, and I just slip the foam over the trailing edge where they would contact the rudder/vert stab. Velcro is used to hold the wings together.
I also discovered the need for this after my first 20 mile trip. Since then I have trailered mine for thousands of miles. I did make a support for the front spar, I drain the fuel, and I have the rods that attach the wings to tail.
Louie
Model 3 912ul
rudderdancer
Joined: 28 Aug 2006 Posts: 27 Location: Victorville, CA
Posted: Wed Dec 03, 2008 8:04 pm Post subject: Re: Trailering a Kitfox |
Kirk,
Like Louie said, I too use the swimming noodles, wal-mart etc., slit in half. But I the whole length on each wing held onto the flaperons with small bungies. I use a smaller piece of noodle on the trailing edge of the rudder. I haven't gotten around to using something like the noodles on the gust locks for the horizontal and elevator. When the noodles all come together when the wings are folded, it tends to limit any flapping. Also like others have said it's best to use the supports for the front spar and the standoffs. Good luck with the weatherproofing.
Jack
_________________ J. Henry Hall
Kitfox II, 582, Tundra Tires,
jhenryhall@mac.com |
kitfoxfugit(at)yahoo.com Guest
Posted: Fri Dec 05, 2008 10:00 pm Post subject: Trailering a Kitfox |
Kitfoxkirk <aviateer(at)gmail.com> asks:
"I trailered my Kitfox about 300 miles. When folded the wings back out, I
suggestions on how to alleviate this in the future?"
Mine is a Speedster that came with a Skystar factory trailer and brackets. The trailer is single axle with springs and a large toolbox. Two brackets go from each front spar to the landing gear brackets. Two go from each rear strut to the horizontal stabilizer. These secure and support the wings.
I tie the outer flaperon weights together with a bungee. This keeps the flaperons immobile and clear of the horizontal stabilizer. I leave the stick forward, elevators down. I put foam pipe wrap over the rudder and secure it to the wing brackets with bungees, so that the rudder is turned fully to one side.
The tail is supported by a bracket that holds the aircraft on also. So do the ramps, and a motorcycle tie on each landing gear. I only tow it a few miles, but could go indefinitely like that, as everything is secure and nothing moves.
I have never covered the top, but would explore a cover held on with bungees with pads under grommets and hooks, angled out, or tied on with cloth or ropes, using bungees from each tie or rope to the landing gear brackets or trailer as a tensioner to keep the rope or cloth tie tight to avoid flapping.
JA KF IV Speedster
WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Sat Jan 03, 2009 6:29 am Post subject: Re: Trailering a Kitfox |
Here is another question that seems to be on topic here, and important to me since I am going to have to trailer my Kitfox from Orlando to Nashville.
How have you all been handling the tail control surfaces in tow? Do you just allow them full deflection to one side and let the wind (or a bungee) hold it in place? Can this cause any warping to the control surfaces or damage to the stops? What are the max towing speeds you have happily used with no issues?
I was considering making a rudder-lock like we used on gliders, out of wood bracing and some sort of padding. Basically it will end up being a slotted piece of wood that fits over the top of the rudder and V-stab. Any thoughts on this idea?
I have gotten a lot of good ideas of how to set the plane up for her tow home from this thread already, I just need a few more. Thanks.
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
Posted: Sat Jan 03, 2009 6:43 am Post subject: Trailering a Kitfox |
These questions are best answered if you give us a bit more information
James (I assume is your name?). I trailer my Model 2 all the time on a car
trailer and also have the original Denney-supplied tow kit. As I understand
from posts on this list different models have very different towing
requirements.
To start you off I have attached a picture of my KFII tail section ready for
the road, speeds up to 50 mph but that is a self-imposed limit and I don't
have far to go.
ELSA Repairman, inspection rated
Wrightsville Pa
Description: |
Filesize: |
271.07 KB |
Viewed: |
907 Time(s) |
7suds(at)Chartermi.net Guest
Posted: Sat Jan 03, 2009 7:13 am Post subject: Trailering a Kitfox |
WurlyBird,
I purchased a damaged Kitfox in Indiana and towed it to Upper Michigan,
about 500 miles. I opted to remove the wings and wrap them in blankets and
lay them under the fuselage, they already had some damage and I was not
worried about scuffing the finish, Flaperons were also removed from the
wings. If you decide to fold and transport the outboard end of the wings
will need to be supported, there are also hold back brackets that were
supplied with some kits that attach the outboard strut area of the wings to
the vertical tail area. You will want to be aware of the weight on the tail
wheel in the folded position and decide how to address. A rudder lock as you
described is a good idea and I believe many on this list have used them for
transport. I believe a couple thin boards with padding and a couple bolt is
all that is required. I towed on an open trailer, aircraft facing forward
and towed at speeds up to 75 mph. I secured at the main gear (Grove) and the
tail wheel. There has been allot of discussion about towing on the tail
wheel with the wings folded because it adds allot of weight there and, I did
not have that problem, perhaps other can give you there experience on that
topic. Took me 5 hours with 2 helpers to drain all the fuel, remove the
wings and flaperons, load and secure.
Lloyd
Posted: Sat Jan 03, 2009 7:15 am Post subject: Trailering a Kitfox |
James,
I trailer my Model 2 every time I fly. Though it's only about 5 miles to the airport, I've towed routinely at 60mph with no issues. Rudder deflection is not a problem, held in place as it is by a carpet pad protecting the rudder and v-stab from the folded wings and flaperons. I stabillize the elevator in up position with a bungie holding the stick full-back. Wings are supported forward and aft by towing braces.
Mud flaps are, obviously, essential on towing vehicle. With an open trailer, you will still likely have infequent damage from stones thrown by passing vehicles. Keep your roll of 100mph tape handy. Tail-first, tail-elevated trailering is recommended for open trailer towing. Closed trailers are nice but can cost near as much as your airplane.
Finally, be sure to unload the tail spring. The tail is very heavy with the wings back, especially if you haven't de-fueled after flight (I always do). Install a brace to transfer the weight of the heavy tail to the trailer frame. This will spare the tw spring from the extreme wear it will otherwise experience during transport. I'm sure this factor has contributed to at least some of those broken tail springs that have been reported.
IMHO, the Fox's trailering capability is one of it's finest qualities.
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1 w/clutch
--- On Sat, 1/3/09, WurlyBird <james.t.trizzino(at)us.army.mil> wrote:
Quote: | From: WurlyBird <james.t.trizzino(at)us.army.mil>
Subject: Re: Trailering a Kitfox
Date: Saturday, January 3, 2009, 9:29 AM
this idea?
Prospective Kitfox buyer
Here for information on airframes and engines
http://forums.matronics.com/viewtopic.php?p 22547#222547
shinco(at)bright.net Guest
Posted: Sat Jan 03, 2009 7:29 am Post subject: Trailering a Kitfox |
Checked by AVG - http://www.avg.com
This is what I have done..and found out to do..I had made..Braces out of
wood.1X4 in.and used a sleeping bag pad.cut it.and glued it in to
place.I had made 2 for the stab.,1 for each side.and 2 for rudder..I tow
my KF backwards .on trailer.and I all so tie down tail wheel real good
so it does not move at all..all so winch strap,at wing tie downs,to
trailer.but not real tight...that helps stop wind at hi way speeds from
lifting up wings.I can tow my KF at 50-60mph with no problems..but you
do not want to tow on windy days.I had built a custom trailer to haul
airplanes that I sell..I have a trailer company that builds them for
me.and then I sell them..the largest plane that I have hauled on it was
a Cessna 170.right down the inter state..you just want to make sure.to
tie the tail down tight.so it does not move around on you.all so
rudder+stab.or if you do not..the trailer will move from side to side..I
have hauled airplanes from way out west to Ohio.like this with no
problems..C120-140-170-172 tri pacers etc.I all so rent my trailers
out..Steve Shinabery N554KF
djwild2(at)hotmail.com Guest
Posted: Sat Jan 03, 2009 7:32 am Post subject: Trailering a Kitfox |
I transported my model 1 from NY to Kansas on a flatbed. tied the tires
down. Put foam between the rudder and wing. I put a couple extra rope tie
downs to hold the wings together. I also put on trailer engine in the front.
I didn't read about supporting the tail wheel till I got home so I forgot to
do that, but my tail spring held up ok so I guess I got lucky there. I drove
65 on interstate 4 lane the whole way. 23 hour drive. I checked every rope
at every gas stop and did have to adjust it a few times.
Dan Wild
Model 1
532
From: "WurlyBird" <james.t.trizzino(at)us.army.mil>
Sent: Saturday, January 03, 2009 8:29 AM
with no issues?
on this idea?
aerobatics(at)aol.com Guest
Posted: Sat Jan 03, 2009 7:39 am Post subject: Trailering a Kitfox |
I have a fully enclosed trailer insulated with ramp electric winch
with remot... interior lights alarm etc that needs some work for
sale if that helps...
planecrazy2020(at)gmail.c Guest
Posted: Sat Jan 03, 2009 9:21 am Post subject: Trailering a Kitfox |
James,
The first photo shows the tail wheel support and the second shows the front spar brace that you will need. By the way this is not my aircraft.
David
KF II, HKS
On Sat, Jan 3, 2009 at 8:29 AM, WurlyBird <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)> wrote:
Quote: | --> Kitfox-List message posted by: "WurlyBird" <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)>
[url=http://forums.matronics.com/viewtopic.php?p 22547#222547]http://forums.matronics.com/viewtopic.php?p 22547#222547[/url]
Description: |
Filesize: |
76.12 KB |
Viewed: |
742 Time(s) |
Description: |
Filesize: |
84.97 KB |
Viewed: |
726 Time(s) |
