david.stanbridge(at)swift Guest
Posted: Mon Dec 22, 2008 12:08 pm Post subject: Revised Europa Specifications |
Hi again,
Today we finished the update of the specifications of all the models on the
Europa website. I would appreciate if you could give them a glance over and
let me know if in their opinion they reflect reality or not.
Thank you,
Dave
Swift Technology Group Limited
www.swifttg.com
(T) +44 (0)1603 262301
(M) +44 (0)7725 655600
david.stanbridge(at)swifttg.com
jimpuglise(at)comcast.net Guest
Posted: Mon Dec 22, 2008 12:34 pm Post subject: Revised Europa Specifications |
Dave-
Generally, very nicely done. I have a couple of comments. First, there is also the conventional gear option available. Currently Bob Berube is doing them, but you may wish to discuss marketing the kit through Europa also. I know that the parts procurement is a nuisance for him. Second, in terms of engines, there are several Jabaru engines in use in the US. I know one of your guys in the UK had a tough time with it, but the engine is still a good option and is 125 HP without supercharging. Also, I am not an authority on it, but I thought the 914 was 125 HP.
My interest, as you may know, is getting an LSA wing option for the airplane. I have lost my physical and if I can't get it into an LSA category, it is just a useless pile of fiberglass to me.
Good Luck -- Glad to see you working on it.
Jim Puglise A-283, Punta Gorda, FL
garrys(at)tampabay.rr.com Guest
Posted: Mon Dec 22, 2008 4:55 pm Post subject: Revised Europa Specifications |
Hi Dave,
I took a look at the "new" website specs. Nice. I'm glad to see that
Europa is no longer advertising 200 MPH cruise speeds, but I'd still argue
that 155 MPH at 75% power is a bit high. I'd be more inclined to say that
140 mph is closer to real experience. Also, I appreciate that "some"
builders can come in at 780 lbs empty weight, but I think if you check with
the Europa Club you'll see that the average is closer to 850 lbs. With full
upholstery, really good paint, and full instruments, speed mods, fairings,
wheel pants, etc., I think 875 to 900 is where you'll end up.
Keep up the fine work!
Garry Stout
A060, 914 Tri
Tampa, Florida
christoph.both(at)acadiau Guest
Posted: Tue Dec 23, 2008 6:19 am Post subject: Revised Europa Specifications |
Hi,
Where would we find the written statement by Andy Draper?
Christoph Both
#223
Wolfville Nova Scotia, Canada
rampil
Posted: Tue Dec 23, 2008 8:37 am Post subject: Re: Revised Europa Specifications |
Hi Dave,
Welcome and thank you for your interest (and more) in Europa!
I have a few comments about the new specs with particular reference
to the XS Trigear with the 912uls
1) There is no long range fuel tank for the trigear (yet!?)
2) At 8000' DA, the 912s can not make 75% power in cruise. Since the
Rotax factory does not provide sufficient data, I modeled power
Output with a simple linear model of MP and RPM. At 8000', at
takeoff rpm (limit 5 min) 5750 RPM, the engine provide 73%. At
5500 (constant pitch prop), the output is 70%, and at standard
cruise rpm of 5000 rpm, the output is 63%. That said, with the
speed kit installed and a fresh wash, I do see in the range of 135kt
TAS at 5000rpm at 8000'. My airdata system is reasonably
calibrated and the altimetry is IFR certificated. The air data is processed
and displayed by a BlueMountain EFIS.
3) While I have not done a diligent study of max climb performance,
I do expect to see about 1100 fpm at sea level up to 1000'MSL at the
published Vy.
Best Regards and Best Wishes for a Prosperous New Year,
rampil
Posted: Tue Dec 23, 2008 8:38 am Post subject: Re: Revised Europa Specifications |
Hi Dave,
published Vy.
4) The MTOW is 1450 lbs in the US, as published in my OpLims
air.guerner(at)orange.fr Guest
Posted: Wed Dec 24, 2008 6:33 am Post subject: Revised Europa Specifications |
Hi Ira,
It is interesting to compare your computed figures with those from ROTAX and DIAMOND.
Based on fig.14, page 10-8 of the ROTAX 912ULS Owner Manual, the engine should be capable of producing 75 % power at 8000 ft at full throttle and 5500 RPM. This is not 75% of 100 HP but 75% of the max continuous power of 94 HP, i.e. 69 HP. At 8000 ft, full throttle, 5000 RPM, the power is 59.5 %.
Below is what Diamond shows on the Katana DA20-100 Flight Manual. This aircraft is JAR-VLA certified and uses the same 912S engine. The Manual is available on line on the Diamond website. Below are their cruise figures at 8000 ft. :
5500 RPM, 22 In.Hg: 75% of max continuous power (assumed to be at full throttle):
5350 RPM, 21,7 In.Hg: 65% (probably not at full throttle) 5100 RPM, 21 In.Hg: 55% (probably not at full throttle)
The Diamond figures are consistent with the Rotax ones at 5500 RPM but not for the other power settings.Your computed figures differ significantly from both the Rotax and the Diamond figures.
One interesting thing is that Diamond provides fuel flow figures. This confirms the higher you fly with the Rotax, the more fuel you use. A typical exemple is 18 liters/hour at 75% at 0 ft and 23,6 l/h at the same power at 8000ft. That is a 31% increase!
Regarding the advertised cruising speed of the Europa, I have made numerous measurements using the 3 way GPS method and consistently get 135 kts TAS at 8000 ft, full throttle and 5000 RPM, which is about 60% power according to Rotax. This is for an XS monowheel with 912 ULS, Airmaster prop and speed kit. So it seems that the advertised 140 kts at 75% at 8000 ft are absolutely achievable, provided you accept to cruise at 5500 RPM.
Best regards and Merry Christmas
Remi Guerner
F-PGKL
rampil
Posted: Wed Dec 24, 2008 1:51 pm Post subject: Re: Revised Europa Specifications |
Hi All,
Thanks for the input Remi!
I think Rotax is using a sleigh of hand, inconsistently using a moving
target for power output. The engine is advertised as 100 hp, and
only in fine print does one see a 5 min max duration for the rated power.
Therefore I was using the advertised power rating in my table, which
I enclose below. I can put 75% of max continuous power in fine
print on the table. The table is a simple model, but I find it useful since
I lack a dyno to test with.
BTW, I published the Diamond power chart some months back since it
confirmed my measured fuel flows as increasing with altitude.
Merry Christmas, Happy New Year,
Description: |
 Download |
Filename: |
912ulsPower.pdf |
Filesize: |
14.74 KB |
Downloaded: |
458 Time(s) |
rampil
Posted: Wed Dec 24, 2008 2:21 pm Post subject: Re: Revised Europa Specifications |
For fun, here is some of my fight test data from June 2006
demonstrating the lack of altitude compensation of mixture in
the Bing 64 carb.
I keep hoping that someone will report (favorably) on the Greensky
manual mixture control for the 912s
Description: |
 Download |
Filename: |
FuelvsAlt Sheet1.pdf |
Filesize: |
21.33 KB |
Downloaded: |
344 Time(s) |
Posted: Thu Dec 25, 2008 8:26 am Post subject: Revised Europa Specifications |
Thanks Ira for your table. I believe it requires some explanation: what do the colors mean? Are all figures at full throttle? If not, at least one parameter (altitude or temperature) is missing.
Can you clarify please?
Remi
Posted: Thu Dec 25, 2008 8:47 am Post subject: Revised Europa Specifications |
Ira,
I would love to have a mixture control system on my aircraft. However as I understand how the HACman/Greensky mixture control works, I am afraid it would unacceptably affect the reliability of the engine.
Up to now, I have not read anything such as reliability analysis, experience in the field, etc... that would convince me that I am wrong!
Remi
Quote: | >>>>>For fun, here is some of my fight test data from June 2006
the Bing 64 carb.
manual mixture control for the 912s>>>>>>>>>>>
Posted: Thu Dec 25, 2008 9:30 am Post subject: Revised Europa Specifications |
Hi Remi
"I'd love to have a mixture control system on my aircraft. However as I
Quote: | understand how the HACman/Greensky mixture control works, I am afraid it
experience in the field, etc... that would convince me that I am wrong!"
N4211W not flying yet, but have and will install a mixture control on 914.
First off installed will be a Split Second mixture display that is driven
by a Bosch O2 sensor (will weld a bung on the muffler inlet just
downstream of turbo).
Slight different install on 914 because of Turbo compared to 912/s, but
will use a needle valve to leak pressure from normal airbox pressure side
of enrichment solenoid to manifold cross tube. The more I leak the leaner
the mixture will be.
This will require a run of hose to cockpit then to manifold cross tube, I
will use high temperature Viton tubing.
I will slight richen mixture on main jet and perhaps even jet needle, I
always like to run slight rich when you are making a lot of BTUs such as
100% power or in 914s case War emergency of 115%. It can also cool things
a little on a hot engine (including when stuck on ground).
Then will size a restriction on the controlled "leak" to manifold cross
tube so it will allow me to only lean to ~14.7 at 18K.
Then will have an emergency "rich" button that will allow me to activate
enrichment solenoid that could further richen mixture on less than War
emergency power if I wish. In addition the emergency "rich" button will
completely bypass all my additional plumbing.
For either a 912/S or 914 install, if you at cruise power if you pull
throttle without closing off your controlled leak, your engine is probably
going to quit. On the other hand, if you set mixture at lets say 60% power
and adjust mixture, if you increase power you will go richer than probably
desired.
Another problem is if you lean at altitude, when you come down things will
lean up further.
Having a Split Second display is a nice tool for this control, a EGT
(which I have one on each side of motor) is only semi useful.
HAC has or had a altitude adjusting bellows, I would rather have full
manual control.
I am a motorhead and feel very comfortable fiddling with carburation. If
you can't tune a lawnmower engine to perfection by ear, owned a hot 2
stroke cycle that you managed to run on the edge for long periods without
blowing up, probably not worth considering the controlled 'leak' method of
adjusting Type 64 constant depression carbs.
Ron P.
rampil
Posted: Thu Dec 25, 2008 5:28 pm Post subject: Re: Revised Europa Specifications |
Hi Remi,
The table is engine performance with a constant speed (AirMaster) prop.
All certificated manufacturers provide a table like mine which shows
the relationship between throttle, selected RPM, and power output.
Rotax does not. The graph is useful to select which combination
works best under specific circumstance, particularly when fuel flow
and TAS are added to the table. My data collection is unfinished for the
bigger version of the table. In this version of just engine, not airframe
performance, density altitude is unneeded. No matter what density
altitude, throttle sets manifold pressure, and obviously without a
turbocharger/supercharger, the maximum MP declines with altitude.
The desired rpm is set on your prop control. Green is the usual
operating range, the other colors are not important here.
Example: 75% power is obtained at 27.5" and 4800 rpm or
26" and 5000 or 24" and 5500 rpm. The "standard" cruise setting
on Continental or Lycomings of 25 squared (or 2500 rpm (at) prop at
25" MP) doesn't work out for Rotax because 2500 rpm would be over
6000 engine rpm, but by extrapolation would be over 80% power.
Or, if you set your prop to 5000 rpm for cruise, then you get 75% at
26" (only possible up 4000' DA), and 65% at 23" MAP.
While there are small inaccuracies due my simple model of the Otto
cycle, so far as I know, this table I created is the only published
attempt to provide guidance for 912s drivers with a constant speed
prop.
Cheers,
