Paul A. Franz, P.E.
Posted: Wed Dec 24, 2008 10:58 am Post subject: tail wheel slack |
On Wed, December 24, 2008 10:25 am, Clint Bazzill wrote:
You are right, the rudder is connected directly to the pedals. There should be no
play (backlash) to the tail wheel. It is like loose steering, it will keep you on the
highway but not desireable.
I've been advised to allow a little slack, just a little in the tail wheel to allow it
to caster. The turning is done with rudder authority and the tail wheel follows the
turn. That way you can move the rudder some without having to tug so hard on the tail
wheel chains and springs. A little throttle blast and some rudder input and the
tailwheel follows in a tight turn. On my setup, with the chains tight and the engine
off the airframe pushing the rudder hard will actually bend the control arms that the
chains connect to with the additional weight on the tail (no engine).
I have also been told to experiment a little with the spring tension and slack during
initial taxi testing to see what I like.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
lcfitt(at)sbcglobal.net Guest
Posted: Wed Dec 24, 2008 11:40 am Post subject: tail wheel slack |
In my personal experience this appears to be one of those belt vs.
suspenders things. I was soundly warned by a Stearman expert once that I
was in for some real trouble if I didn't take the slack out of the rudder /
tailwheel linkage. It was once when I was ferrying a friend to pick up his
Stearman after his annual. I finally did when I put rod ends to eliminate
some of the acuteness of the angle of the chain from rudder to tailwheel
steering arms. The slack disappeared because of the link length of the
chain and I could either have real loose or snug. I chose snug. I frankly
can't say it improved or worsened the ground handling. I think argument for
both configurations could be made and it is possibly just a matter of habit
and personal preference.
Lowell
