		rgarrett7(at)gmail.com Guest
				 Posted: Tue Dec 23, 2008 8:11 am    Post subject: Starter Ring Gear source? |
				My starter ring gear has gotten chewed up and is beginning to have
 problems engaging.  Anyone have recommendations for a good parts
 source.  I believe it is 149 teeth -- it is an O-360-A1A, bought new
 from Van's in 2000.  A location in the Washington, DC area would be
 great, but I suppose it can be mailed from anywhere.
 Thanks!
 Randy Garrett
 RV-6A
 850 hours
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		n8zg(at)mchsi.com Guest
				 Posted: Tue Dec 23, 2008 8:55 am    Post subject: Starter Ring Gear source? |
				Randy -
 I'd suggest Barrett Precision or Mattituck.
 Rhonda and Mahlon provide an invaluable service to The Lists.
 Let's support them.
 Neal George
 CherokeeJet N9586J
 RV-7 N8ZG
		tiger10(at)centurytel.net Guest
				 Posted: Tue Dec 23, 2008 9:33 am    Post subject: Starter Ring Gear source? |
				I have used  Preferred Air Parts in Ohio for years. They have some new but
 mostly used parts and are reliable and honest. I'm on the road at the
 moment, but they have a web site.
 Jim Carey
 8-A building
		HCRV6(at)comcast.net Guest
				 Posted: Tue Dec 23, 2008 9:49 am    Post subject: Starter Ring Gear source? |
				I have the same problem, caused by the factory installed lightweight starter not aligning properly with the ring gear.  I replaced the starter at about 400 hours and it now seems to engage properly but the damage to the ring gear was already done.  I bought my replacement ring gear from Sacramento Sky Ranch (www.sacskyranch.com).  It is 149 teeth.
 Harry Crosby
 RV-6 N16CX, 533 hours
		rv8a2001(at)yahoo.com Guest
				 Posted: Tue Dec 23, 2008 11:10 am    Post subject: Starter Ring Gear source? |
				I have never had to deal with a ring gear....... but, couldnt you remove it, flip it over and reinstall it with the worn teeth facing forward instead of on the starter side?
 Scott
 RV-8a
    From: "HCRV6(at)comcast.net" <HCRV6(at)comcast.net>
 To: rv-list(at)matronics.com
 Sent: Tuesday, December 23, 2008 9:45:56 AM
 Subject: Re: Starter Ring Gear source?
  p {margin:0;}  I have the same problem, caused by the factory installed lightweight starter not aligning properly with the ring gear.  I replaced the starter at about 400 hours and it now seems to engage properly but the damage to the ring gear was already done.  I bought my replacement ring gear from Sacramento Sky Ranch (www.sacskyranch.com).  It is 149 teeth.
 Harry Crosby
		chaskuss(at)yahoo.com Guest
				 Posted: Tue Dec 23, 2008 12:42 pm    Post subject: Starter Ring Gear source? |
				Try Don George in Orlando. He has non certified ring gears which are a big seller with the air boat guys down here in Florida. See
 http://orlando-fl.digicity.org/GeneralCompanies/Don_George_Aircraft_Engines_and_Parts-1987442849id.html
 Charlie Kuss
 --- On Tue, 12/23/08, Randy Garrett <rgarrett7(at)gmail.com> wrote:
  	  | Quote: | 	 		   From: Randy Garrett <rgarrett7(at)gmail.com>
  Subject: Starter Ring Gear source?
  Date: Tuesday, December 23, 2008, 11:08 AM
  to have
  parts
  bought new
  area would be
  Thanks!
  Randy Garrett
  RV-6A
  850 hours
		krhooper(at)gmail.com Guest
				 Posted: Tue Dec 23, 2008 1:07 pm    Post subject: Starter Ring Gear source? |
				You might check Ebay. Check for the proper part number. Not all ring gears are created equal. I recently bought one for an O-320 for $50.
  Someone earlier mentioned flipping the ring gear. There is a bevel on one side so that will not work.
  Randy Hooper
  On Tue, Dec 23, 2008 at 2:40 PM, Charles Kuss <chaskuss(at)yahoo.com (chaskuss(at)yahoo.com)> wrote:
 Randy Hooper
				 Posted: Tue Dec 23, 2008 4:03 pm    Post subject: Starter Ring Gear source? |
				The starter side of the gear tooth is beveled to help the starter gear
 to engage.  No bevel on the other side.  Also, how do you get the gear
 off without destroying it?
 Linn
 scott bilinski wrote:
  	  | Quote: | 	 		   I have never had to deal with a ring gear....... but, couldnt you
  Scott
  RV-8a
				 Posted: Tue Dec 23, 2008 6:47 pm    Post subject: Starter Ring Gear source? |
				The starter side of the gear tooth is beveled to help the starter gear to engage.  No bevel on the other side.  Also, how do you get the gear off without destroying it?
 Linn
  Moderately heat the steel and put a bag of ice on the inner aluminum. Bump the ring right off. Works pretty easy.
  Randy Hooper
  On Mon, Dec 22, 2008 at 6:00 PM, linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)> wrote:
  [quote]--> RV-List message posted by: linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)>
 Linn
  [quote]I have never had to deal with a ring gear....... but, couldnt you remove it, flip it over and reinstall it with the worn teeth facing forward instead of on the starter side?
