Posted: Sun Dec 21, 2008 12:06 pm Post subject: Has anyone landed 914 on pump #1 run by generator only? |
Curiosity question. Has anyone had a failure where the only way you could keep 914 running was by Europas schematic that has you wiring fuel pump #1 direct to generator?Thx.Ron Parigoris [quote][b]
paul.the.aviator(at)gmail Guest
Posted: Sun Dec 21, 2008 1:45 pm Post subject: Has anyone landed 914 on pump #1 run by generator only? |
Hi Ron,
My pumps are wired as per the Europa drawings. As I recall it has one
of the connected to the output of the regulator... I need to check
again for the exact details.
Anyhow, getting back to your question, yes, when I took a lightning
hit the main contractor dropped offline and all of my electrics with
it.
I did not turn on my E-Buss straight away, I spent a good deal of time
deciding how damaged the aircraft was, from a structural and flight
control perspective. Only after this did I turn on my E-Buss, so up
until then I was running off one fuel pump which was powered directly
from the output of the regulator.
So, I guess this is a long winded way of saying from a redundancy
perspective the system worked as designed.
I did see a number of postings from you on the AeroElectric forum, my
only recommendation I can make to you is to keep it simple. I have a
single battery dual electrical buss in my airplane. Never in my
imaginings did I consider if the design was robust enough to take the
punishment that was handed out that day, but it was.
Regards, Paul
budyerly(at)msn.com Guest
Posted: Mon Dec 22, 2008 12:34 pm Post subject: Has anyone landed 914 on pump #1 run by generator only? |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Ron,
Wire the 2nd boost pump as the Europa manual and Rotax Installation diagrams indicate is light and simple with good redundancy. The only deviations I do are in a dual generator setup when a 2nd battery and non tied bus is used (you could call it an E bus) runs the other pump and associated emergency electrics. The E bus derives power from the rotax alternator, and the other pump off the main bus is charged by the belt driven alternator. My other is to have a single small battery charged off a shot key diode which drives the secondary pump. In the event of a primary bus failure, you have to turn on the secondary pump and now have a 30 minute battery to get you on the ground. You can get into endless number of what if's in these scenarios and become the office of redundant redundancy.
Many are flying with both pumps wired to the main bus. If the master solenoid fails, and you use a relay to control the Rotax alternator, you can loose fuel pump power permanantly if the main bus / master solenoid fails.
The Europa/Rotax method is simple and it works.
Bud Yerly
