malpass-architect(at)att. Guest
Posted: Mon Dec 22, 2008 8:55 am Post subject: seat pans cracking- kitfox model III |
I found it was easier and cheaper to remove the seat, grind/roughen the back where the fiberglass is, and re-apply several thick layers of fiberglass creating a broad patch in the effected area. Then to double re-inforce the area I put an array of rivits at the edges where the crackes are. I had about 6 areas of long cracks that need repair. Mine has held up fine. Dont make fiberglass repairs on the top side as this is the plastic (ABS, I think) side. The seat has been manufactured like a fiberglass tub.
I tend to take a cheaper way out, and this method seems to work. Besides I bet the seat pan isn't cheap.
