kenharrison
Posted: Mon Dec 22, 2008 7:11 am Post subject: Kitfox III Fiberglass Seat Pan Cracking |
What is the best way to keep the fiberglass seat from cracking? Mine has very small cracks that are right at the outside edges both sides, basically half way up the back. It makes a crackling sound every time I get in. I have re-enforced the seat with some seat belt material underneath but was wondering if anyone has a better solution.
I am going to repair the fiberglass and thought I’d check to see if anyone has dealt with this problem. I don’t want to make the fiberglass repair and then just have it crack again in the same place.
I’ve read about the seats failing and jamming the controls...always in the back of my mind.
Ken
_________________ Ken Harrison
Kitfox III
Rotax 582 C Box
Powerfin 3-Blade |
dan(at)azshowersolutions. Guest
Posted: Mon Dec 22, 2008 7:32 am Post subject: Kitfox III Fiberglass Seat Pan Cracking |
Ken,
If you are thinking about making repairs you could really strengthen critical areas if you used carbon fiber instead of fiberglass...just a thought.
Dan B
Mesa, AZ
--- On Mon, 12/22/08, Ken Harrison <kenharrison(at)comporium.net> wrote:
| Quote: | From: Ken Harrison <kenharrison(at)comporium.net>
Subject: Kitfox III Fiberglass Seat Pan Cracking
To: "Kitfox List" <kitfox-list(at)matronics.com>
Date: Monday, December 22, 2008, 8:11 AM
cracking? Mine has
sides, basically
time I get in. I
underneath but was
I am going to repair the fiberglass and thought I¹d check
to see if anyone
has dealt with this problem. I don¹t want to make the
I¹ve read about the seats failing and jamming the
back of my mind.
Ken
sbennett3(at)aol.com Guest
Posted: Mon Dec 22, 2008 7:33 am Post subject: Kitfox III Fiberglass Seat Pan Cracking |
Ken, I don't have suggestions to help you fix your seat issue, just a reminder that there are control rods running under that seat that if collapsed on will keep you from being able to control ailerons. I had that happen to me once. Maybe a new seat can be on your Christmas list. Personally, i'd replace it. Steve Bennett classic 4 912ul... Durham NC
In a message dated 12/22/08 10:12:44 Eastern Standard Time, kenharrison(at)comporium.net writes:
| Quote: | .aolmailheader {font-size:8pt; color:black; font-family:Arial} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal} What is the best way to keep the fiberglass seat from cracking? Mine has very small cracks that are right at the outside edges both sides, basically half way up the back. It makes a crackling sound every time I get in. I have re-enforced the seat with some seat belt material underneath but was wondering if anyone has a better solution.
Ken
Listen to 350+ music, sports, & news radio stations including songs for the holidays FREE while you browse. Start Listening Now!
msm_9949(at)yahoo.com Guest
Posted: Mon Dec 22, 2008 8:21 am Post subject: Kitfox III Fiberglass Seat Pan Cracking |
Ken, There will always be varying opinion on such issues so here's mine, FWIW: You've apparently already addressed the safety issue by installing webbing straps. These are, in reality, now supporting the weight of the seat pan and it's occupants. If you've done this job properly (as I'm sure you have) so long as the webbing is intact, the seat pan will not fail. So, my humble advice would be to repair the cracks in the pan and carefully inspect pan, webbing and its attachment points at each annual.
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1 w/clutch
--- On Mon, 12/22/08, sbennett3 <sbennett3(at)aol.com> wrote:
| Quote: | From: sbennett3 <sbennett3(at)aol.com>
Subject: Re: Kitfox III Fiberglass Seat Pan Cracking
Date: Monday, December 22, 2008, 10:32 AM
| Quote: | #yiv123930800 .aolmailheader {font-size:8pt;color:black;font-family:Arial;} #yiv123930800 a.aolmailheader:link {color:blue;text-decoration:underline;font-weight:normal;} #yiv123930800 a.aolmailheader:visited {color:magenta;text-decoration:underline;font-weight:normal;} #yiv123930800 a.aolmailheader:active {color:blue;text-decoration:underline;font-weight:normal;} #yiv123930800 a.aolmailheader:hover {color:blue;text-decoration:underline;font-weight:normal;} What is the best way to keep the fiberglass seat from cracking? Mine has very small cracks that are right at the outside edges both sides, basically half way up the back. It makes a crackling sound every time I get in. I have re-enforced the seat with some seat belt material underneath but was wondering if anyone has a better solution.
Ken
Listen to 350+ music, sports, & news radio stations – including songs for the holidays – FREE while you browse. Start Listening Now!
blank rel=nofollow>http://www.matronics.com/contribution
arget=_blank rel=nofollow>http://www.matronics.com/Navigator?Kitfox-List
=nofollow>http://forums.matronics.com
wingsdown(at)verizon.net Guest
Posted: Mon Dec 22, 2008 8:49 am Post subject: Kitfox III Fiberglass Seat Pan Cracking |
Even before any cracks developed I too reinforced the pans with carbon fiber. Good idea,
Rick
Float Flyr
To get the strength to weight you should have there the only way is to vacuum bag the repair and carefully weigh the amount of resin you put into the cloth. For something that needs to be strong like a seat I think I’d even go with pre-preg cloth with the nap running 45Deg on each layer. Finding someone with a autoclave or a hotshot will be the major problem.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Ken Harrison
Sent: Monday, December 22, 2008 11:41 AM
To: Kitfox List
Ken | Quote: | | http://www.matronics.com/contribution | 01234567890123
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Mon Dec 22, 2008 10:39 am Post subject: Kitfox III Fiberglass Seat Pan Cracking |
Here's another idea....install under-seat tool boxes. John & Debra
McBean sell them I'm sure. Either there or Murle Williams. I got two
of 'em and installed them and I seem to recall that they will contact
a diagonal member of the fuse before anything hits the control rods.
Talk about killing two birds....now you've got places to put more crap!
Lynn Matteson
Jabiru 2200, #2062, 596+ hrs
Sensenich 62x46
flying again after rebuild, and new Electroair direct-fire ignition
system;
also building a new pair of snow skis
On Dec 22, 2008, at 11:20 AM, Marco Menezes wrote:
| Quote: | Ken, There will always be varying opinion on such issues so here's
Marco Menezes N99KX
solution.
Ken
contributionarget=_blank rel=nofollow>http://www.matronics.com/
Navigator?Kitfox-List=nofollow>http://forums.matronics.com
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
lcfitt(at)sbcglobal.net Guest
Posted: Mon Dec 22, 2008 11:02 am Post subject: Kitfox III Fiberglass Seat Pan Cracking |
Ken,
My suggestion would be to scuff sand the cracked edge top and bottom and lay
a couple of layers of fiberglass tape (top and bottom) over the surface near
the edge. The top (white) layer is gelcoat and make sure the scuff sanding
removes the gelcoat in the affected areas. the edge would then be similar to
a foam sandwich where the original glass and cracks would be like the foam
and really non structural and the layers of glass top and bottom would be
the structural part. Also my opinion is that your repair would be for the
most part to eliminate the noise and give some confidence that the seat will
not crack straight across. Fiber glass structures are not like plexiglass
where a crack will always continue to propagate. Consider also that seat
lockers were common options for small tools etc. These required cutting
large holes in the seat bottoms which would seriously weaken the structure.
Regarding the seat pan failures in the past. I don't think there has ever
been a pan failure in a Model I through IV. The failures came after Skystar
added the trim panel in front of the seat and needed to change the leading
edge of the seat from the tube grabbing "C" lip to the gentler curved and
shorter 45° lip to accommodate the trim panel. This is a classic example of
how a seemingly non structural design change to add a bit of eye appeal (and
weight) resulted in a serious safety issue. The failures were not
structural failures of the pan, but would come on a hard landing or severe
turbulence when the seat would spring down under the pilot's weight and the
forward lip would slip off the bulkhead tube. I am not aware of a seat
failure from structural collapse. Also regarding the old style, I know a
guy that has put over a thousand hours on two Model IVs and has never tied
the seat pan to the airframe with the nylon tiewraps. I have seen him in
"turn back" turbulance and tons of off airport landings with no incidences.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL
Currently focusing on the Left Wing - almost ready to cover, fuselage as
well.
MichaelGibbs(at)cox.net Guest
Posted: Mon Dec 22, 2008 12:32 pm Post subject: Kitfox III Fiberglass Seat Pan Cracking |
Lynn sez:
>John & Debra McBean sell them I'm sure. Either
I can't say how they affect the structural integrity of the seat pan
but during my accident both under-seat compartments in my 'fox were
completely flattened. We believe they helped cushion the impact by
crumpling, though, and I had no back injuries.
I got my toolboxes from Murle Williams <http://
MurleWilliamsAviation.com>
Mike G.
Kitfox IV-1200 Speedster
Phoenix, AZ
Lynn Matteson
Posted: Mon Dec 22, 2008 1:09 pm Post subject: Kitfox III Fiberglass Seat Pan Cracking |
They might just provide a "crush zone" in that regard. I think I got
mine from Williams, too. As I recall, John either didn't have them
when I ordered mine, or I didn't check....and this was before he
became www.kitfoxaircraft.com anyway.
Lynn Matteson
Sensenich 62x46
system;
On Dec 22, 2008, at 3:23 PM, Michael Gibbs wrote:
<MichaelGibbs(at)cox.net>
Lynn sez:
pan but during my accident both under-seat compartments in my 'fox
were completely flattened. We believe they helped cushion the
impact by crumpling, though, and I had no back injuries.
Mike G.
Phoenix, AZ
N369LM |
Lynn Matteson
Posted: Mon Dec 22, 2008 1:16 pm Post subject: Kitfox III Fiberglass Seat Pan Cracking |
When I bought my minimally completed kit, it came with a seat support
kit, which consisted of 2" wide web strapping, and 8 hose clamps,
and directions for slotting the seat so the clamps could be slid
through the slots and around the fuselage tubes. I installed all 8 at
first, then during the first annual, cut the number to 4. Big PITA to
R & R them, and I feel 4 does the job WAY more than the tiewraps
could ever hope to.
Lynn Matteson
Sensenich 62x46
system;
On Dec 22, 2008, at 1:54 PM, Lowell Fitt wrote:
<lcfitt(at)sbcglobal.net>
| Quote: | I know a guy that has put over a thousand hours on two Model IVs
and has never tied the seat pan to the airframe with the nylon
tiewraps. I have seen him in "turn back" turbulance and tons of
Lowell Fitt
N369LM |
MDKitfox(at)AOL.COM Guest
Posted: Mon Dec 22, 2008 1:31 pm Post subject: Kitfox III Fiberglass Seat Pan Cracking |
Lynn,
When I installed my seat pan (at the very end of the build process) I had already installed four web straps to support the seat from 'falling' onto the controls. (Each piece of webbing is good for supporting over a ton.) I opted to use the tie wraps (instead of hose clamps) figuring they're there just to keep the seat pan from bouncing up and off the support tubes in case of turbulence. I don't see that they don't provide any other obvious function. Even wearing the seat belts provides substantial down force on the seat to hold it in place. Am I missing something here about the hose clamps?
Rick Weiss
N39RW Series V Speedster, 912ULS
SkyStar S/N 1
Port Orange, FL
On Dec 22, 2008, at 4:16 PM, Lynn Matteson wrote:
| Quote: | --> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
When I bought my minimally completed kit, it came with a seat support kit, which consisted of 2" wide web strapping, and 8 hose clamps, and directions for slotting the seat so the clamps could be slid through the slots and around the fuselage tubes. I installed all 8 at first, then during the first annual, cut the number to 4. Big PITA to R & R them, and I feel 4 does the job WAY more than the tiewraps could ever hope to.
Lynn Matteson
Sensenich 62x46
flying again after rebuild, and new Electroair direct-fire ignition system;
| Quote: | --> Kitfox-List message posted by: "Lowell Fitt" <lcfitt(at)sbcglobal.net (lcfitt(at)sbcglobal.net)>
I know a guy that has put over a thousand hours on two Model IVs and has never tied the seat pan to the airframe with the nylon tiewraps. I have seen him in "turn back" turbulance and tons of off airport landings with no incidences.
Lowell Fitt
| http://www.matronics.com/contribup; &n --> http://forums.matroni===================
= [quote][b]
Lynn Matteson
Posted: Mon Dec 22, 2008 1:47 pm Post subject: Kitfox III Fiberglass Seat Pan Cracking |
I don't think you're missing a thing, Rick. In fact, I think I missed
something when I installed them. I think the maker of that
aftermarket kit went overboard when they decided on the hose
clamps...and these are the 1/2" wide jobs to boot. I may just opt for
the tiewraps in the future, or at the very most the narrower 1/4"
size hose clamps.
My web straps are slotted so the hose clamps or tie wraps can go
through them and help hold them in place.
I guess I should have said earlier that the "4 hose clamps are WAY
more than *necessary* to do the job."
Lynn Matteson
Sensenich 62x46
system;
On Dec 22, 2008, at 4:30 PM, Weiss Richard wrote:
| Quote: | Lynn,
clamps?
Rick Weiss
SkyStar S/N 1
Port Orange, FL
> Lynn Matteson
N369LM |
Tom Jones
Posted: Mon Dec 22, 2008 3:30 pm Post subject: Re: Kitfox III Fiberglass Seat Pan Cracking |
| Quote: | | I am going to repair the fiberglass and thought I’d check to see if anyone has dealt with this problem. I don’t want to make the fiberglass repair and then just have it crack again in the same place. |
Ken, I broke my seat during the building. I had the seat sitting in the fuselage and was in there doing something. I put all my 160 pounds on one knee on the center ridge and it popped like a rifle shot. It had a crack clear through about six inches long. I fixed it by laminating a couple layers of fiberglass cloth on the underside. I tested it with the knee treatment after it cured and have not had any more problems. It's probably stronger that new.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
patreilly43(at)hotmail.co Guest
Posted: Mon Dec 22, 2008 8:06 pm Post subject: Kitfox III Fiberglass Seat Pan Cracking |
Lowell C My Mod 3 seat pan has holes in it and on the frame cross members that match up for rivets. You mention using tie wraps to attach pan to frame. Is that the normal method? I mounted my radiator with your shutters today after combining the parts you sent to me to modify the shutters to accomodate my taller radiator. Looks like they will work fine. I purchased the control cable you recommended. Any progress on the electric trim kit yet?
Pat Reilly
Mod 3 582 Rebuild
Rocford C IL
[quote] From: lcfitt(at)sbcglobal.net
Date: Mon C 22 Dec 2008 10:54:32 -0800
--> Kitfox-List message posted by: "Lowell Fitt" <lcfitt(at)sbcglobal.net>
Ken C
structural failures of the pan C but would come on a hard landing or severe
failure from structural collapse. Also regarding the old style C I know a
Lowell Fitt
Cameron Park C CA
Currently focusing on the Left Wing - almost ready to cover C fuselage as
well.
Posted: Mon Dec 22, 2008 9:24 pm Post subject: Kitfox III Fiberglass Seat Pan Cracking |
Yes, Pat, when I built my 1993 Model IV the standard installation for the
seat pan was tiewraps. As I recall I put them about every six inches. I
used the ones that are about 9 inches long. I rechecked the manual and it
calls for eight in front and nine across the back. Keep in mind that the
tiewraps, the manual calls the them zip ties, are to hold the pan down on
the tubing supports. The "C" shaped lips keet it off the controls. I plan
to use the same method on the IV I am building now. I see no reason not to.
As I mentioned, the failures were due to the pan slipping off the forward
tube support due to a redesign of the forward pan lip. Also the tiewraps
are replaced every annual as the seat pan is removed to inspect linkages
beneath it, so no age issues there.
Regarding the elevator trim kit. It is still on the back burner pending a
completion of a current project. I am within a week of finishing that - I
think - then I will get the tooling out and make up the kit parts and try
to determine a cost. Maybe the first week in January for the results.
Yes, retired folks no longer get weekends and holidays. I will probably
spend at least part of Christmas day in the hangar trying to burn some holes
in some 4130 tubing or maybe if I am lucky, bending some aluminum into a
trim tab.
Lowell
Posted: Tue Dec 23, 2008 9:13 am Post subject: Kitfox III Fiberglass Seat Pan Cracking |
Lowell C I know what you mean. When someone asks if I am retired. I ask them what retired means. I work from the time my feet hit the floor in the morning until I go to bed at night. If they ask C "What do you do" the reply is C "Whatever Joyce tells me to do. Joyce works me like a mule. But C I am crazy not stupid." Like the old guy I met at the doctors office said C "I'm retired. I get up in the morning without a damn thing to do. And C by the time I go to bed at night C I'm only half done." There is a secret to leading a productive life.......PRODUCE..... something anything C just produce. I'll be trying to get out of the casket to build something C anything. Keep up the good work and designing KF options.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Mon C 22 Dec 2008 21:20:08 -0800
Yes C Pat C when I built my 1993 Model IV the standard installation for the
tiewraps C the manual calls the them zip ties C are to hold the pan down on
As I mentioned C the failures were due to the pan slipping off the forward
beneath it C so no age issues there.
Yes C retired folks no longer get weekends and holidays. I will probably
in some 4130 tubing or maybe if I am lucky C bending some aluminum into a
trim tab.
Lowell
Lynn Matteson
Posted: Tue Dec 23, 2008 10:42 am Post subject: Kitfox III Fiberglass Seat Pan Cracking |
I figure I'll be in the casket thinking: "Now what in hell prompted
them to build this thing like they did? Damn, if only they had....."
Lynn Matteson
Sensenich 62x46
system;
On Dec 23, 2008, at 12:13 PM, patrick reilly wrote:
| Quote: | I'll be trying to get out of the casket to build something, anything.
| Quote: | do not archive
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
N369LM |
Ken Potter
Joined: 18 Aug 2007 Posts: 85 Location: Lanark, Ontario
Posted: Wed Dec 24, 2008 3:56 am Post subject: Re: Kitfox III Fiberglass Seat Pan Cracking |
Like Pat's, my model II has rivet holes. I am just about at the point of installing the seat and wasn't comfortable with the rivets (not being able to easily remove the seat for inspection. The hose clamp idea sounds like a good solution.
Cheers and Merry Christmas
Ken
_________________ Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario |
peteohms
Posted: Wed Dec 24, 2008 7:03 am Post subject: Kitfox III Fiberglass Seat Pan Cracking |
My Model III has sheet metal screws in the "rivet" holes.
Pete
--- On Wed, 12/24/08, Ken Potter <kjpotter(at)sympatico.ca> wrote:
[quote]From: Ken Potter <kjpotter(at)sympatico.ca>
Date: Wednesday, December 24, 2008, 4:56 AM
[quote]--> Kitfox-List message posted by: "Ken Potter"
good solution.
Cheers and Merry [quote][b]
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
