sarg314(at)gmail.com Guest
Posted: Sat Dec 20, 2008 9:04 am Post subject: RV-6A rudder trim tab |
I am priming things. I gather that most planes have a small
rectangle of sheet aluminum glued/taped to the trailing edge of the
rudder and this is used to make a tiny trim adjustment to the
rudder. I can't find a reference to this in my manual. Can some one
advise me of the size of this this and what thickness is usually used
for it?
---Tom Sargent, RV-6A, almost ready for the color coat.
rhdudley1(at)bellsouth.ne Guest
Posted: Sat Dec 20, 2008 9:42 am Post subject: RV-6A rudder trim tab |
Hi Tom,
What worked for me was a balsa trailing edge for model airplanes purchased
from a hobby shop. I used one about 1" wide attached with double stick foam
tape. I started with one about 8" long and finally trimmed it to about 5-6"
after several trials. I have seen wedges of various materials, attached in
various ways on RVs. I am sure the length needed varies with the individual
plane. So, it is an engineering experiment to adjust the length as needed
until the plane flies with the ball in the center at cruise speed. It is a
separate problem from a heavy wing correction. I used a balsa wedge from the
same stick as my final rudder trim and painted it the color of the rudder.
The foam tape was still intact after three years and 140 hours.
Richard Dudley
seiders(at)bellsouth.net Guest
Tom, most use balsa wood and size is determined by trial and error.
Most I used are about 4 to 7" long by 1.5" wide. After trying in
flight and size is determined attach it with JB Weld. and away you go.
Dick RV6A
for it?
Posted: Sat Dec 20, 2008 10:46 am Post subject: RV-6A rudder trim tab |
Well, I can't really answer your question about the tab size. A fixed
trim tab will only be truly effective at one certain airspeed ..... and
is usually set for the cruising speed most used. I'm building a -10,
and am going through the 'trim tab' scenario as we speak. There's been
a few emails with pictures etc. on the -10 list about bungee (spring)
trim systems .... some folks are really creative. I don't like those
solutions, so I'm going to attach a hinged tab to the trailing edge of
the rudder and move the tab with a model airplane servo. I'm in the
process of creating the servo controller with a 555 timer in pulse width
modulation mode.
Linn
thomas sargent wrote:
for it?
Rick Galati
Joined: 10 Jan 2006 Posts: 91 Location: Lake St. Louis MO.
Posted: Sat Dec 20, 2008 10:49 am Post subject: Re: RV-6A rudder trim tab |
Tom,
A few years ago, I installed this simple wedge now sold by Avery. Trim its length in 1/8" increments and test fly until you are happy with the performance. Can be epoxied into place. My wedge is attached to the rudder with double sided carpet tape, works fine.
http://www.averytools.com/pc-118-112-rudder-trim-tab.aspx
jimmy(at)jhill.biz Guest
Posted: Sat Dec 20, 2008 2:33 pm Post subject: RV-6A rudder trim tab |
Why would you not want to use a small spring attached to the proper rudder
pedal?
Jimmy
8A
Larry Bowen
Posted: Sat Dec 20, 2008 3:26 pm Post subject: RV-6A rudder trim tab |
I tried that. Spring amount that was good at cruise was way too much
at low speeds. I changed it out for the wedge.
pedal?
Jimmy
8A
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
Posted: Sat Dec 27, 2008 5:20 pm Post subject: RV-6A rudder trim tab |
Linn,
To your point here is a trim tab used on our -10. Simple to
build during the process. Some have retrofitted theirs. We just guessed
on size but it works very well.
http://www.painttheweb.com/rv-10/rudderTrim.htm
Robin
jfogarty(at)tds.net Guest
Posted: Mon Dec 29, 2008 8:55 am Post subject: RV-6A rudder trim tab |
Robin, I think what is nice about your install, per the photo's, it should
work on all airspeeds and head winds without holding any or much rudder
control right or left. Looks great. Thank for your post. I don't have a
trim tab on my rudder, so I hope it fly's straight.
Jim
RV9a
