seiders(at)bellsouth.net Guest
				 Posted: Sat Dec 20, 2008 9:44 am    Post subject: Fwd: Re: RV-6A rudder trim tab |
				Oops. Make that a tapered pc of balsa starting at 1/8" and going to about 1/4"
  	  | Quote: | 	 		  Date: Sat, 20 Dec 2008 12:42:01 -0500
 To: rv-list(at)matronics.com
 Subject: Re: RV-6A rudder trim tab
 Tom, most use balsa wood and size is determined by trial and error.
 Most I used are about 4 to 7" long by 1.5" wide. After trying in
 flight and size is determined attach it with JB Weld. and away you go.
 Dick RV6A
 >         I am priming things.  I gather that most planes have a small
 >rectangle of sheet aluminum glued/taped to the trailing edge of the
 >rudder and this is used  to make a tiny trim adjustment to the
 >rudder.  I can't find a reference to this in my manual.  Can some one
 >advise me of the size of this this and what thickness is usually used
 >for it?
 >Thanks,
 >---Tom Sargent, RV-6A, almost ready for the color coat.
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
