Dirtbos
Joined: 01 Sep 2007 Posts: 13 Location: Southern California
Posted: Fri Dec 19, 2008 1:38 am Post subject: Raven/Suzuki 1300 90 HP Conversion |
Is anyone out there flying the Raven/Suzuki 1300 90 HP engine conversion in a 701? If so, how does it perform (climb rate, cruise, etc.).
I read an article and it mentioned a fellow named Tom Mills who thought that the 1300 felt like 70 HP. I wonder if it was a reduction drive. Does anyone know about this one?
Any input would be greatly appreciated
Mike
dougsnash
Posted: Fri Dec 19, 2008 3:56 am Post subject: Raven/Suzuki 1300 90 HP Conversion |
Mike, I'm not absolutely sure about this but I think there was a Tom Mills in Southern Ontario that did extensive flight training in a 701 with Suzuki engines. A year or two ago (I think this was it) he got a "to good to pass up" deal on a 912 and switched over.
Mark Townsend might have more details as they are located fairly close together.
Also, I have no idea if this is the Tom Mills you are refering too.
Hope this helps
Doug MacDonald
CH-701 Scratch Builder
NW Ontario, Canada
--- On Fri, 12/19/08, Dirtbos <dirtbozz(at)att.net> wrote:
| Quote: | "Dirtbos" <dirtbozz(at)att.net>
Mike
ch701builder(at)yahoo.com Guest
Posted: Fri Dec 19, 2008 5:07 am Post subject: Raven/Suzuki 1300 90 HP Conversion |
Isn't this the same engine as the Geo Metro 1.3L?
If it is, then search matronics Zenith list for the Purple Dragon
Rick I think is flying behind one. www.n701RR.com is his website.
Keith
N 38.9940
W 105.1305
Alt. 9,100'
CH701 - scratch
Sent: Friday, December 19, 2008 2:38:08 AM
Subject: Raven/Suzuki 1300 90 HP Conversion
Posted: Fri Dec 19, 2008 7:45 am Post subject: Raven/Suzuki 1300 90 HP Conversion |
Hi Mike,
You might look at Rick Roberts 701 as it's powered by the Suzuki 1300
and it's a nice setup
check the link below.
http://www.zenithair.com/stolch701/7-photo18a.html#suzuki
Dirtbos wrote:
Mike
Dirtbos
Posted: Fri Dec 19, 2008 8:33 am Post subject: Re: Raven/Suzuki 1300 90 HP Conversion |
I appreciate your responses.
I took a look at Rick Robert's website and only find a Cessna 140 featured. I could not find anything about his 701.
I had seen photos of his aircraft before. It is a very nice example of quality construction. Great paint job also.
I would love to get some more information about this aircraft.
Mike
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Fri Dec 19, 2008 3:00 pm Post subject: Re: Raven/Suzuki 1300 90 HP Conversion |
Ricks site sort of changed from Raven G13 CH701 to Cessna 140 over night.
Not sure what is up? Rick are you out there?
I was thinking of this engine but Ricks sudden silence as of late has pretty much put me off of this engine. Sure would like to hear from you Rick.
Kevin
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
dougsnash
Posted: Fri Dec 19, 2008 4:47 pm Post subject: Raven/Suzuki 1300 90 HP Conversion |
Kevin, If I remember correctly, Rick sold his 701 very shortly after his first flight and went in partners with someone on the 140. Of course, my memory could be wrong, wouldn't be the first time.
Doug MacDonald
NW Ontario, Canada
--- On Fri, 12/19/08, kmccune <kmccune(at)somtel.net> wrote:
| Quote: | From: kmccune <kmccune(at)somtel.net>
Subject: Re: Raven/Suzuki 1300 90 HP Conversion
Date: Friday, December 19, 2008, 5:00 PM
"kmccune" <kmccune(at)somtel.net>
140 over night.
Kevin
Mark Twain: Twenty years from now you will be more
disappointed by the things that you didn't do than by
the ones you did do. So throw off the bowlines. Sail away
from the safe harbor. Catch the trade winds in your sails.
Explore. Dream. Discover.
http://forums.matronics.com/viewtopic.php?p 20204#220204
Dirtbos
Posted: Fri Dec 19, 2008 5:30 pm Post subject: Re: Raven/Suzuki 1300 90 HP Conversion |
| kmccune wrote: | Ricks site sort of changed from Raven G13 CH701 to Cessna 140 over night.
Kevin |
Kevin,
Rick responded to a PM this evening. He spoke positively about the engine (not so much about the IVO prop). He liked the Raven Re-drive also. He said that the plane "flew great". No performance specs though. I especially like his aircraft because of the look of the cowling he used. Apparently he used a VW Rabbit radiator that sits back under the engine "similar to what the Subaru guys use". He referred me to Larry McFarland's site, http://www.macsmachine.com/ . Larry built an HD but the site shows some good shots of the radiator set up.
Personally I'm feeling pretty good about the combination at this point. Of coarse I'm going to do some more research. I spoke to the owner at Raven today. After the Holidays he is going to refer me to some builders that have used the 1300 with his re-drive. He is quite busy now due to a time sensitive remodel (I believe at his shop) so I am going to leave him alone until then.
It is certainly not a 100 HP 912, but I would think it would perform at least as well as the 80 HP version. And you cannot beat the price tag.
Mike Allen
Dirtbos
rroberts
Joined: 04 Sep 2006 Posts: 50 Location: Birmingham, AL USA
Posted: Fri Dec 19, 2008 6:07 pm Post subject: Re: Raven/Suzuki 1300 90 HP Conversion |
Guys,
I have put the my 701 web site back up.
Remember, it is for entertainment purposes only!
www.n701rr.com
_________________ Low & Slow
Rick
www.n701rr.com
www.ricksplace.info |
kmccune
Posted: Fri Dec 19, 2008 7:06 pm Post subject: Re: Raven/Suzuki 1300 90 HP Conversion |
Thanks Rick I am always entertained by airplanes!
Kevin
Dorothy McCune |
Dirtbos
