ptiller(at)lolacars.com Guest
Posted: Mon Dec 15, 2008 6:40 am Post subject: Mod 58 |
Hello All,
My rebuild is now on to the trim tabs......
I understand that Mod 58 was the replacement fitting of the trim tab drive pins. Does anyone know why? I've looked in the factory newsletters and can't seem to find the reason for it.
Phil
Visit - www.EuropaOwners.org
Brian Davies
aireupora(at)sbcglobal.ne Guest
Posted: Mon Dec 15, 2008 7:09 am Post subject: Mod 58 |
Lead in paragraph on Mod 58
An incident occurred to the company demonstrator aircraft G-GBXS where one of the TP16
anti-servo/ trim tab drive pins became detached due to the plate it was welded to fracturing. The
aircraft was on the ground when the failure occurred, probably during engine starting, and the
resulting behaviour of the aircraft in flight was to pitch nose up. The pitch up force was containable by the pilot and a circuit and landing was successfully flown.
The fracture was established to have been caused by fatigue due to repeated bending of TP16¢s plate. The bending that this plate had been subjected to was likely to have been in excess of normal due to ibrations caused by an engine starting problem. The aircraft had completed 426 hours of flight which included 895 take-off and landings. It is important that the cause of unusual vibrations, for example engine starting problems or an unbalanced propeller, are resolved at the earliest opportunity.
--- On Mon, 12/15/08, flyingphil2 <ptiller(at)lolacars.com> wrote:
| Quote: | From: flyingphil2 <ptiller(at)lolacars.com>
Subject: Mod 58
Date: Monday, December 15, 2008, 2:39 PM
| Quote: | --> Europa-List message posted by: "flyingphil2"
Hello All,
Phil
| [quote][b]
europabill(at)bellsouth.n Guest
Posted: Mon Dec 15, 2008 7:13 am Post subject: Mod 58 |
They beefed up the plate that gets bonded to the trim tab. I think they
found one on a plane that was fractured...
Bill
A010 Monowheel Classic
Rotax 912S - 13 years and still building.....
Posted: Mon Dec 15, 2008 7:54 am Post subject: Mod 58 |
Ah, Ok - that's great, thanks for all your help.
Phil
