Sam
Posted: Sun Nov 23, 2008 5:02 pm Post subject: 2-10 SWITCH - Can this be done? |
I am trying to configure a switch and am currently stumped.
I have two possible power inputs A or B.
I have two possible devices, C or D.
I want the three position switch to have the following conditions, with no other combinations.
A powers C
B powers D
Off
Do you think this is possible with a single 2-10 Switch? I sure couldn't figure it out. How else might I be able to accomplish it with only one switch? Maybe a 4-10 (and where would I get one)?
This all has to do with redundant power inputs providing power to two sets of fuel injectors.
Sam
_________________ Sam Hoskins
www.samhoskins.blogspot.com |
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Sun Nov 23, 2008 5:31 pm Post subject: 2-10 SWITCH - Can this be done? |
Sam,
Can the center position be 'OFF'?
If so, a double pole/double throw switch will work if you use it to only switch the positive leads and use a common for the negative for both connections. One pole, with throw in one direction, (say up) could give you the A power to C and the other pole with the other direction throw (say down) would give you B power to D.
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
mrspudandcompany(at)veriz Guest
Posted: Sun Nov 23, 2008 5:43 pm Post subject: 2-10 SWITCH - Can this be done? |
A powers C
B powers D
Off
Sam [quote] You can accomplish this using a 2-10 switch connected as follows: A to 2, B to 5, C to 1, D to 6. A simple dpdt center off switch can be also wired for this circuit. Roger[b]
Posted: Sun Nov 23, 2008 6:28 pm Post subject: 2-10 SWITCH - Can this be done? |
A powers C
B powers D
Off
Sam
*You can accomplish this using a 2-10 switch connected as follows: A to 2, B to 5, C to 1, D to 6.*
*A simple dpdt center off switch can be also wired for this circuit.*
*Roger*
Is it acceptable that one switch failure takes out both systems?
klehman(at)albedo.net Guest
Posted: Sun Nov 23, 2008 6:37 pm Post subject: 2-10 SWITCH - Can this be done? |
I never understood why guys like this sort of thing. It means you do NOT
have redundant systems since one switch failure can fail both sources of
power.
FWIW my engine continues to run if I energize both injection systems and
feed twice the normal fuel to it. Definitely rich but not a show stopper.
Ken
Sam Hoskins wrote:
Quote: | I am trying to configure a switch and am currently stumped.
A powers C
B powers D
Off
Sam
nuckolls.bob(at)cox.net Guest
Posted: Mon Nov 24, 2008 5:51 am Post subject: 2-10 SWITCH - Can this be done? |
At 08:41 PM 11/23/2008, you wrote:
NOT have redundant systems since one switch failure can fail both
sources of power.
and feed twice the normal fuel to it. Definitely rich but not a show stopper.
Ken
It is a product of design goals that do not consider every
single component's vulnerability to failure. In the certified
side of the house, we like to fill spread sheets with lots
of calculations derived from failure rate numbers that are
too often assumed and combinations that are too seldom
confirmed for reliability. The final insult comes when all
potential consequences for failure have not been mitigated
even when a backup for the failed part exists. Remember
Apollo 13? Somebody cranked the numbers on that thermostat
and was "comfortable" with the probability of failure. Shucks,
the vehicle had a service life of less than 1000 hours. Just
how good does it need to be? Oh yeah, if it DOES croak . . .
can I live with getting my tail blasted off?
I will suggest that the term "redundant" is most useful when
Plan-A has no components in common with Plan-B. The icing
on the cake comes from consideration of the consequences of
any single failure . . . the "best" failures do not propagate
their effects beyond a need to replace the failed part after
a comfortable termination of flight has been accomplished.
Sam, the best advice we can give you is to craft your redundant
systems with as much electrical isolation as possible/practical.
This would include separate control switches for each set of
injectors.
>A powers C
>B powers D
>Off
>Thanks,
>Sam
Sam
Posted: Mon Nov 24, 2008 6:56 am Post subject: 2-10 SWITCH - Can this be done? |
Thanks, Bob, et al.
This project could be held up as a textbook example of the laws of unintended consequences.
The initial project Goal: Make an already flying plane go faster and more efficient.
The method: Aerodynamic clean up and addition of Electronic Fuel Injection.
The consequence: The project stretching out over a year, with many items not on the original list, and worst, a not insignificant gain in weight - in direct opposition to The Goal.
I have a wire count well over one hundred, 16 switches to control power and fuel, and require in the neighborhood of 20 amps to feed endurance loads! I am using a version of Z19/RB. I have pretty much run out of real estate for the switch grouping.That is why I am trying to include the A power source and B power source with one switch.
There are lots of asides to this story, but the project really has been fun. I'll mull all this over and see if I can find room for another #(at)$*% switch.
FWIW, here is my current power distribution:
http://www.mistakeproofing.net/transfer/N202SH_POWER_DISTRIBUTION_07.pdf
And the wire page for the coils and injectors:
http://www.mistakeproofing.net/transfer/injectors_and_coils.pdf
And the load analysis:
http://www.mistakeproofing.net/transfer/Load_analysis.pdf
Sam
On Mon, Nov 24, 2008 at 7:49 AM, Robert L. Nuckolls, III <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)>
Quote: | --> AeroElectric-List message posted by: Ken <klehman(at)albedo.net (klehman(at)albedo.net)>
I never understood why guys like this sort of thing. It means you do NOT have redundant systems since one switch failure can fail both sources of power.
FWIW my engine continues to run if I energize both injection systems and feed twice the normal fuel to it. Definitely rich but not a show stopper.
Ken
injectors.
A powers C
B powers D
Off
Sam
Posted: Mon Nov 24, 2008 8:25 am Post subject: 2-10 SWITCH - Can this be done? |
and more efficient.
<http://www.mistakeproofing.net/transfer/N202SH_POWER_DISTRIBUTION_07.pdf>http://www.mistakeproofing.net/transfer/N202SH_POWER_DISTRIBUTION_07.pdf
<http://www.mistakeproofing.net/transfer/injectors_and_coils.pdf>http://www.mistakeproofing.net/transfer/injectors_and_coils.pdf
<http://www.mistakeproofing.net/transfer/Load_analysis.pdf>http://www.mistakeproofing.net/transfer/Load_analysis.pdf
It's not clear how you ended up with so many switches. It's
axiomatic that the more choices you have for operating switches
in a tense situation, the less likely that you'll make the
optimum/right choice. Further, the more switches you have, the
more likely it is that you'll suffer a switch failure thus
creating a situation that causes you to take some action.
Can you share the rationale that prompted your departure
from Z19 suggestions? What value is perceived for splitting
the ECU controls into two separate switches as opposed to
single, double pole switches? Have you thought through the
process(es) you'll exercise when the engine is not running
quite right? The best Plan-B involves a minimum of activity,
ideally free of possibilities for doing the wrong thing.
Sam
Posted: Mon Nov 24, 2008 8:54 am Post subject: 2-10 SWITCH - Can this be done? |
Here are my basic thoughts and rational on the design.
The RWS EFI controller (ECU) has two separate Ignition/fuel injection controllers mounted on a single board. These are labeled as A & B. They are almost identical and separate.
They allow separate +12V supply inputs, as well as separate ignition and fuel injector output triggers. The two battery busses, main and engine, can each supply the A or B sides of the ECU.I am able to select a feed from either the main or the engine battery bus and supply it to either the A input of the B input. On my drawing, the engine bus is sometimes reffered to as "backup".
Adding to that, are two Walbro fuel pumps, and here I continued a similar thought pattern. That is, either the main battery bus or the engine battery bus would feed either the main EFI pump, or it's backup. The two Facet pumps transfer fuel from the main and aux tanks to the header supply tank.
All of this adds up to a boatload of switches. I invite ideas for a better way.
Sam
On Mon, Nov 24, 2008 at 10:23 AM, Robert L. Nuckolls, III <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)> wrote:
Posted: Mon Nov 24, 2008 11:07 am Post subject: 2-10 SWITCH - Can this be done? |
At 10:53 AM 11/24/2008, you wrote:
The <http://www.rotaryaviation.com/eficont.html>RWS EFI controller
Quote: | I am able to select a feed from either the main or the engine
Okay, why not a double-pole switch that controls each ECU
from it's own battery bus as depicted in Z-19. This eliminates
two switches. In other words, what do you perceive a need to
"back up"? It is exceedingly remote that you will experience
two failures on any one tank full of fuel. I presume you're going
to carry well maintained batteries (known capacity) and that your
alternator-out endurance numbers for loss of an alternator are
know.
Quote: | Adding to that, are two Walbro fuel pumps, and here I continued a
Why not one switch per pump fed from different batteries?
You have dual ignition already. Why not one switch to control
magneto. One to control electronic ignition from a battery bus.
Do the fuel injectors draw current if their associated ECU is
powered down? If not, hook main injectors to engine battery,
TB injector to main battery. No switches.
Quote: | All of this adds up to a boatload of switches. I invite ideas for a
better way.
I think this reduces your switch count by 3.
( -Thomas Paine 1776- )
peter(at)sportingaero.com Guest
Posted: Mon Nov 24, 2008 11:45 am Post subject: 2-10 SWITCH - Can this be done? |
Sam,
I think you are over complicating the matter – I am assuming that the engine will run on either the A or the B system. Why not wire the whole of the A system from the main bus and the whole of the B system from the engine bus? Both systems become completely independent and you have 2 completely redundant systems. There is no confusion as to which side of the ECU/pump/etc is running on what.
If you suspect any kind of failure switch off the system currently in use and switch on the other one. Fly to the nearest airport and investigate the failure on the ground. Use both systems regularly so you trust them both. Any further redundancy perhaps is overkill and may just introduce further (unintended?) failure modes.
Regards, Peter
Sam
Posted: Tue Nov 25, 2008 4:57 am Post subject: 2-10 SWITCH - Can this be done? |
Yes, I probably am over complicating the matter. In fact, I'm sure of it.
Armed with a wide set of possibilities and a good CAD program, I can merrily
spend hours and hours woring on all sorts of permutations.
Now I'll spend a little time trying to simplicate the thing. I appreciate
the reality check.
Thanks.
Sam
On Mon, Nov 24, 2008 at 1:38 PM, Peter Pengilly <peter(at)sportingaero.com>wrote:
[quote] Sam,
Regards, Peter
Posted: Tue Nov 25, 2008 7:05 am Post subject: 2-10 SWITCH - Can this be done? |
At 01:23 PM 11/24/2008, you wrote:
Quote: | Thanks Bob. Let me cogitate over that a few hours.
Sam
On Mon, Nov 24, 2008 at 1:02 PM, Robert L. Nuckolls, III
The
<<http://www.rotaryaviation.com/eficont.html>http://www.rotaryaviation.com/eficont.html>RWS
Yes, there are MANY combinations of things you can do that
function as advertised. I've seen airplanes at fly-ins that
have LOTS of switches.
Your task as system designer and integrator of components is
to 'optimize' the design. I.e., what components can be eliminated
to reduce complexity from the (1) perspective of reliability and
space savings and (2) reduce pilot workload for having to make
the right decisions for continued flight when some part of the
system decides to throw a temper tantrum.
I'll suggest you reconsider your design with the notion that
(1) the hardware SHARED by plan-a and plan-b systems needs to
be an absolute minimum. (2) Likelihood of having two failures
in the airplane on any single tank full of fuel is exceedingly
rare (read insignificant). (3) Manage energy sources and loads
to meet design goals for endurance when a failure does occur.
I'm certain that you'll discover a way to reduce numbers of
switches down to independent control of system-A and system-B
probably as simple as one switch per system. Does each ECU
have its own dedicated fuel pump or can either pump supply
either system? If the former, combine the pumps on the
ECU controls. If the later, one switch per pump is called for.
Sam
Posted: Tue Nov 25, 2008 8:03 am Post subject: 2-10 SWITCH - Can this be done? |
Either pump can supply either system. The second EFI pump is just a back-up
to the first.
I think these automotive pumps are very reliable and I won't ever need the
backup unit, but since it keeps the fan turning, it's pretty important to
have the backup.
The fuel system has a bypass-type pressure regulator. When I originally set
this up, I wanted to design it so either pump could be on-line, but not
both, so as not to overload the regulator. That lead to the set-up that
required two switches and an either/or condition. I don't really know the
capacity of the regulator, it just seemed like a good idea.
Instead, I think I will go back to one switch per pump, dedicate them to
main/engine, and arrange the switch bank to better group things together -
make the error proofing visual rather than mechanical.
As you suggested, I am looking into the characteristics of the internally
excited coils and the fuel injectors to see if there is any current draw
when there is no ECU input. My first reaction was to insist that they be
switched, mostly for maintenance purposes. But on second, thought maybe a
panel breaker would do the trick - provided there is no current draw.
Yes, the switch count is coming down.
Sam
On Tue, Nov 25, 2008 at 9:04 AM, Robert L. Nuckolls, III <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)> wrote:
Sam
On Mon, Nov 24, 2008 at 1:02 PM, Robert L. Nuckolls, III <<mailto:nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)>nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)> wrote:
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <<mailto:nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)>nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)>
The <<http://www.rotaryaviation.com/eficont.html>http://www.rotaryaviation.com/eficont.html>RWS EFI controller (ECU) has two separate Ignition/fuel injection controllers mounted on a single board. These are labeled as A & B. They are almost identical and separate.
Posted: Tue Nov 25, 2008 8:04 pm Post subject: 2-10 SWITCH - Can this be done? |
Sam
FWIW there have been several cases of EFI pump failure over the years so
I agree that a backup is a very good idea. On my subaru the fuel
pressure goes up 2 or 3 psi if I run two paralleled pumps
simultaneously. I'm aware of similar reports with other regulators. That
pressure increase is pretty insignificant as far as the engine is
concerned as injector flow varies with the square root of the pressure.
I no longer bother to run two pumps for takeoff and landing but my
switches are laid out such that all engine problems are dealt with by
positioning all switches up with one hand without having to look at
them. A simple emergency procedure like that is well worth some effort
to implement if you can.
The injectors that I'm aware of operate by grounding one side of the
coil through a solid state "transistor". There have been a few cases of
injectors locking on from a shorted "transistor" or wiring. I don't know
if there have been any from the coil shorting internally to ground.
However a locked on injector will not likely be noticed at full power
and maybe not even at cruise power. Definitely noticeable upon power
reduction.
Ken
Sam Hoskins wrote:
Quote: | Either pump can supply either system. The second EFI pump is just a back-up
to the first.
have the backup.
Sam
www.samhoskins.blogspot.com <http://www.samhoskins.blogspot.com>
Sam
Posted: Wed Nov 26, 2008 5:37 am Post subject: 2-10 SWITCH - Can this be done? |
Okay.
I have completely split the two EFI fuel pumps - one from the engine bat bus and one from the main bat bus.
The four primary injectors are now fed solely by the main bat bus and the backup throttle body (TB) injector is fed solely by the engine bat bus.
A single double-pole switch turns on both A & B sides of the ECU - OFF/BOTH. The ECU has it's own dedicated panel with it's own A/B switch, not shown here.
I have not figured another, more independent way to feed the four ignition coils from either the main or bat bus, so I guess I'll leave that switch arrangement alone. I think it's important to be able to feed from either bus.
I have also rearranged the remaining switches a little better.
Here are the modified arrangements:
http://www.mistakeproofing.net/transfer/Isolated_POWER_DISTRIBUTION.pdf
http://www.mistakeproofing.net/transfer/Switches_POWER_DISTRIBUTION.pdf
Thanks for everyone's input. A team always has a better result than just individuals slugging away.
Sam
Posted: Wed Nov 26, 2008 7:16 am Post subject: 2-10 SWITCH - Can this be done? |
Okay.
engine bat bus.
from either bus.
better.
Sam,
Going back to your first request for info on this thread, you asked how to
operate either of 2 ECU's from 2 separate power sources through 1 switch.
Several individuals indicated that it is not a good thing to go through 1
switch and thus create a "single point of failure" for both systems. You
now have a single point of failure in your ECU ON / Off switch.
Assuming that you will need to have 1 ECU and 1 EFI pump operating
continuously, wire ECU A and EFI# 1 through a DPDT switch, the one you
presently have for your ECU ON / OFF, connected as follows:
Engine Battery Bus to pin 2; Engine Battery Bus to pin 3 (fused separately);
ECU A to pin 1; EFI Pump 1 to pin 4. Repeat similar wiring from Main
battery Bus to ECU B and EFI pump 2. This will give you a totally separate,
redundant system and will also eliminate 1 switch.
Now when you turn on switch #1, ECU A and EFI fuel pump# 1 will be on,
supplied with power from the Engine Battery Bus. If you turn on Switch# 2,
ECU B and EFI fuel pump# 2 will be on, powered from Main Battery Bus.
This is only one of many ways to wire a fault tolerant redundant system. I
am sure others will have different ideas for wiring schemes.
Description: |
 Download |
Filename: |
winmail.dat |
Filesize: |
5.16 KB |
Downloaded: |
703 Time(s) |
Sam
Posted: Wed Nov 26, 2008 7:45 am Post subject: 2-10 SWITCH - Can this be done? |
Roger, you are correct. My oops.
Right after I hit the send button I realized my error. I changed it so the ECU is controlled by two independent switches. I had to add in another switch, but I laid out the panel to be more logical. The second row is all the backup stuff. You can see that if you click on the links below.
This is what I came up with before your e-mail. I'll spend a few minutes and look over your suggestions.
Thanks.
My bad.
Sam
"I'm not a real airplane builder. I just play one at home".
On Wed, Nov 26, 2008 at 9:12 AM, ROGER & JEAN CURTIS <mrspudandcompany(at)verizon.net (mrspudandcompany(at)verizon.net)> wrote:
[quote] Okay.
engine bat bus.
from either bus.
better.
Sam,
