dean.psiropoulos(at)veriz Guest
Posted: Mon Nov 17, 2008 7:45 pm Post subject: 406 MHz ELT |
When I was flying missions with Civil Air Patrol in the State of Oregon we
had far more 121.5 ELT false alarms than real activations but...we responded
to every one of them and learned some lessons along the way. Most of the
missions I was associated with were production spam cans who had their
antennas mounted on top of the fuselage behind the cockpit. Yes it's ugly
but they put them there for a reason. When the ELT IS activated in a crash,
these installations have the BEST chance of being located by search and
rescue (SAR).
Scott's waveguide premise is correct, the cockpit does make a great one and
NO that is not helpful in getting one located and rescued in a timely
manner. If you land (crash) right side up that waveguide will direct the ELT
signal upward where the satellites will receive it. But, once the 121.5 ELT
is heard by the satellite and a SAR aircraft dispatched, the area to be
searched is still quite large. The SAR aircraft has to be able to "hear" the
ELT in order to pinpoint you. If your installation is in the cockpit then
this waveguide effect means that the SAR aircraft's direction finding (DF)
equipment needs to be A LOT closer to you to pick up the signal. That takes
more time in the grid and eats up precious time getting help to a stricken
pilot who may be badly injured.
This waveguide effect was brought home to me quite vividly on one CAP
practice mission where our incident commander placed the ELT inside a metal
garbage can and then tipped the can on its side with the open end facing a
mountain peak. We spent hours with the direction finder pointed at the
mountain listening to the reflected signal from the garbage can waveguide
and searched all over that mountain but never located the "stricken"
aircraft. A frustrating exercise but very eye opening.
John is correct, the practical value of "hiding" the ELT antenna along the
roll bar or under the tail fairing is ZILCH!!! I just finished my RV-6A and
mounted the ELT antenna on the top of the fuselage behind the sliding
canopy. Yup it's ugly sticking up there but...if I do go down and the unit
is activated, that location gives me the best chance of being found as fast
as possible. Yes I know the activation rate is not that great but...you
spent good money on and are installing a tool that could save your life in
an emergency so why not give yourself the best chance of having it do some
good.
Since 406 MHz ELTs still use radio waves to perform their magic, everything
I just mentioned applies. There will be a lot fewer false alarms on the 406
ELTs IF AND ONLY IF all you aviators out there fill out your registration
cards and mail them in. Then, when the USAF search and rescue center gets
your signal they can phone you right away and find out whether it's just a
false alarm or a real emergency. The good news is, if it's a real emergency
the satellites will pick up your 406 MHz signal quicker and locate you
within a smaller radius of area. The only down side is for the SAR team,
the 406 ELTs send out a burst of data every so often as opposed to the
continuous transmission of the 121.5 units. This makes DF tracking a little
more difficult but you should still be found much more quickly than before.
Recommendation: read the instructions that come with your unit and mount the
antenna where they say to do so. If no instruction, mount on top of the wing
or fuselage in an open area with the least potential for reflections. And
PLEASE PLEASE register your unit. I live in Florida now where boaters have
had 406 MHz EPIRBs for a long time. Problem is, there are still lots of
false alarms because boaters have a dismal record of registering their
units!! Fill out that card and send it in.
Dean Psiropoulos
RV-6A N197DM
First flight scheduled for this Saturday.
jsflyrv(at)verizon.net Guest
Posted: Mon Nov 17, 2008 9:02 pm Post subject: 406 MHz ELT |
DEAN PSIROPOULOS wrote:
| Quote: | I just finished my RV-6A and
as possible.
Dean Psiropoulos
RV-6A N197DM
Of course it well not do much good if you are inverted and the antenna
is bent over
against the fuselage or is broken off.
I am one of those people that mounted mine inside under the roll over
frame on a tip up, it
has just as much chance of working there as anywhere else.
Jerry
skylor4(at)yahoo.com Guest
Posted: Mon Nov 17, 2008 9:37 pm Post subject: 406 MHz ELT |
All of this discussion regarding mounting of the ELT antenna is very interesting and eye opening, but we -8 builders have one issue: There is simply no place on top of the fuselage to mount the antenna because the canopy on the -8 slides all they way back to the vertical stabilizer when it's open! As far as I can tell, this leaves only the options of mounting the antenna in the cockpit, or underneath the empennage fairing as others have done. Anyone have any other suggestions?
Skylor
RV-8 under construction (getting close)
--- On Mon, 11/17/08, DEAN PSIROPOULOS <dean.psiropoulos(at)verizon.net> wrote:
[quote]From: DEAN PSIROPOULOS <dean.psiropoulos(at)verizon.net>
Subject: 406 MHz ELT
To: rv-list(at)matronics.com
Date: Monday, November 17, 2008, 7:43 PM
[quote]--> RV-List message posted by: "DEAN PSIROPOULOS"
rescue (SAR).
"hear" the
along the
good.
emergency
PLEASE PLEASE register your unit. I live [quote][b]
timb
Joined: 16 Apr 2008 Posts: 77 Location: Frankston, Texas
Posted: Tue Nov 18, 2008 5:54 am Post subject: 406 MHz ELT |
I have my antenna mounted just in front of the vertical stabilizer. My
thinking was in a rollover the stabilizer *might* protect the antenna from
being smashed. Now I am wondering if the stabilizer causes any shielding of
the signal. Dean, any thoughts on that?
Tim Bryan
RV-6 Flying
N616TB over 100 hours now
[quote] --
_________________ Tim Bryan
RV-6 Flying
N616TB |
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Tue Nov 18, 2008 9:17 am Post subject: 406 MHz ELT |
Regardless of where you choose to mount the antenna and for whatever reason,
consider the routing of the cable from the ELT to the antenna. If you route
it through or near bulkheads or metal edges, it can be severed in a crash.
My ELT was mounted on the keel by the elevator bellcrank in my -6, the
antenna on the seatback cross member and the cable routed under the baggage
floor and thru the rear spar bulkhead. Although my crash was upright, the
cable was severed by the crushed and twisted structure. No signal was ever
detected. I'm keeping the cable for the new one inside the tailcone with the
antenna somewhere back there too.
Greg Young
[quote] --
timb
Posted: Tue Nov 18, 2008 11:08 am Post subject: 406 MHz ELT |
Excellent point Greg! I mounted my ELT in the baggage compartment up
against the baggage closure and the cable runs through the tail cone but not
through any holes. It is tie wired to the formers and hopefully that
wouldn't be an issue. I hadn't thought of that, just did it that way as it
was easy.
Tim Bryan
RV-6 Flying
[quote] --
RV-6 Flying
N616TB |
AV8ORJWC
Posted: Tue Nov 18, 2008 11:34 am Post subject: 406 MHz ELT |
Bob Collins asked a question that has not yet been directly answered.
The question I wanted expanded was to clarify for the masses that 121.5
ELTs have been installed without much consideration for intended
function. Vanity and foolhearty following the builder before you leads
to widely accepted misunderstandings. "Oh, I did it because twenty
other guys in my EAA chapter have done the same thing and it seemed
okay".
Stein has not answered if he can measure the strength and directional
pattern or who else might. Bob is still waiting for more clarity.
Several have made excellent posts. My question remaining is what is the
required polarity needed (Horizontal or Vertical), how will that antenna
installed work in the event the required device is needed as in the case
of Steve Fossett. Several posters added anecdotes on lives lost because
ELTS don't work as needed (which may often be because of installation
errors). We should all know those errors. We should know how effective
our installed antennae are working. We should be protective of the
distance and routing of the coax (Bob's question). Just because you can
get an annunciation during a test function does not mean that the
aircraft can be located before the battery goes dead from a few thousand
yards away.
Antenna propagation is still on the table. The idea of a belly mounted
antenna because so many flip over or are stuck nose down is an
interesting one.
John Cox
W7COX
RV builder #40600
michele.delsol(at)microsi Guest
Posted: Tue Nov 18, 2008 12:19 pm Post subject: 406 MHz ELT |
I had asked the question - how about two antennas, one top side and one
belly mounted, via a splitter. Is that an option ?
Michèle
-----Message d'origine-----
De : owner-rv-list-server(at)matronics.com
[mailto:owner-rv-list-server(at)matronics.com] De la part de John Cox
Envoyé : mardi 18 novembre 2008 20:34
À : rv-list(at)matronics.com
Objet : RE: 406 MHz ELT
okay".
yards away.
interesting one.
John Cox
W7COX
RV builder #40600
gyoung
Posted: Tue Nov 18, 2008 2:28 pm Post subject: 406 MHz ELT |
Another reality is access after the crash may not be easy or even possible
if you're thinking you can actually use the portability feature of the ELT.
Fasteners that were normally accessible may be blocked by bent metal or even
bent themselves. I had to cut a hole to get mine out of the salvage. EPLB's
probably make more sense if you want to assure use in the aftermath.
Greg Young
[quote] --
ronlee(at)pcisys.net Guest
Posted: Tue Nov 18, 2008 3:01 pm Post subject: 406 MHz ELT |
EPLB's > probably make more sense if you want to assure use in the
aftermath.
PLBs...unless the terms have changed. EPIRBs are boat units.
Ron Lee
Posted: Wed Nov 19, 2008 9:18 pm Post subject: 406 MHz ELT |
Just in front of the vertical stab is still a very good location (mine is
about 18 inches forward of the vertical stab). Since the vertical
stabilizer is quite narrow and parallel to the antenna there will be very
little interference or reflection off of the leading edge. It's the folks
who have mounted the ELT antenna underneath the fiberglas tail intersection
fairing that are really limiting their usefulness. In that location the
antenna is mounted horizontally on the aft turtle deck bulkhead (RV-6/7/9)
projecting out into the 90 degree corner created by the intersection of the
vertical and horizontal stabilizers. That creates an excellent waveguide
effect, blocking the signal from reaching half of the area on the other side
of the aircraft.
Jerry, I understand the thinking about putting the antenna on the bottom and
it's another one of those multitude of "what if" scenarios that we RV
builders run through our heads so many times while we're building. I guess
to answer that somebody has to do some research on how many downed RVs have
ended up on their backs. I have heard of several but don't know just what
percentage of ALL RV accidents they actually make up. If you put it under
the wing and you stay right side up in a crash, you will be attenuating a
good bit of the signal and shortening the range at which you can be
detected. If you put it between the trailing edge of the wing and the
forward edge of the horizontal stab (top or bottom of fuselage) your range
should be quite good (right side up or upside down). Then you have to start
thinking about how to keep the antenna from being ripped off in the crash
(Tim Bryan's idea). And so the thought process goes... sometimes being a
safety analyst makes my brain hurt but, more food for thought.
Dean Psiropoulos
RV-6A N197DM
[quote] --
t.gummo(at)verizon.net Guest
Posted: Wed Nov 19, 2008 10:10 pm Post subject: 406 MHz ELT |
Dean and all,
I would like to add one more thought about where to put the ELT antenna.
It shouldn't be what percentage land on their backs but ...
If the plane stay upright, there is a great chance that I am relatively OK,
and the ELT will be the least of my problems,
however, if the plane ends up on its back, then the crash was not controlled
and there will be a good chance that I am NOT OK.
And any help the ELT can be might make all the difference.
Of course, there is no good answer for crashing. And remember most things
on the ground are harder than your plane.
Lets hope no one has need of their ELT.
GummiBear
Air Force Chief of Safety at Incirlik AB, Turkey (many years ago)
panamared5(at)brier.net Guest
Posted: Thu Nov 20, 2008 8:30 am Post subject: 406 MHz ELT |
How about in front of the canopy. On the wing, or on the fuselage side angled up at a 45 degrees. Recommendation: do what ever you want, it is your airplane.
What I like about this list is we can truly beat a horse to death!
Bob
RV6 “Wicked Witch of the West”
