		maarten versteeg
				 Posted: Fri Nov 14, 2008 7:11 am    Post subject: Zenith-List Digest: 41 Msgs - 11/12/08 |
				Hello Paul,
 I agree, and although complex panels seem to attract some, I like the clean
 panels. I also know that experimental - amateur built airplanes don't fall
 under all the rules. But on the other hand I have heard stories where
 the DAR
 sometimes is very specific (remember the whiskey compass discussion).
 I hope you will have a DAR that accepts this and sees the sense of you
 argument.
     Maarten,
     plans building XL, getting close to closing the second wing
  	  | Quote: | 	 		   Time: 08:03:02 AM PST US
  Subject: Re: Wires and fuses and such
  Hi Maarten,
  I guess the regulation you cited explains why so many panels are
  crowded with circuit breakers.  In their great wisdom, the FAA seems
  to have dictated that solution.
  Fortunately, I don't think part 23 regulations apply to experimental
  - amateur built airplanes.  This may be one of many examples of the
  notion that the FAA regulations are overly restrictive on certified planes.
  To directly answer your question, my plans are to limit my flights to
  Day/VFR.  I suspect I could safely conduct such flights without any
  electrical equipment operating at all.  The only really essential
  piece of electrical gear is the starter motor.  My Jabiru is not
  likely to start any other way.
  Best regards,
  Paul
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Maarten Versteeg
601XL  scratch building wings |
		psm(at)att.net Guest
				 Posted: Fri Nov 14, 2008 8:57 am    Post subject: Zenith-List Digest: 41 Msgs - 11/12/08 |
				Hi Maarten,
 I don't want to get into a regulation interpretation battle, but I
 will if I must.
 As I understand the regs and DAR history, the compass issue is
 completely separate from the part 23 question.  Part 23 clearly
 doesn't apply to Experimental airplanes.  Experimental airplanes do
 require a compass.  The issue I have heard discussed is whether the
 compass must be a whiskey compass or if one of the new-fangled
 electrical devices like the one found on the Dynon EFIS is sufficient
 to meet this need.
 I think the electrical compass is really satisfactory to meet the
 requirements, but some builders have run into this issue with their
 DAR and decided a cheap automotive whiskey compass was an easy way to
 get past an old fashioned DAR.
  From a strictly practical point of view, it makes sense that you
 need to be able to figure what direction you are going under all
 circumstances - including electrical failure.  The same argument
 doesn't apply to trying to trouble-shoot electrical problems while
 still in flight.
 Best regards,
 Paul
 XL getting close
 At 07:10 AM 11/14/2008, you wrote:
  	  | Quote: | 	 		  Hello Paul,
 under all the rules. But on the other hand I have heard stories where the DAR
 argument.
     Maarten,
