l.p(at)talk21.com Guest
Posted: Mon Nov 10, 2008 3:05 am Post subject: Z-13 and SD-8 |
Bob.
> If the rectifier/regulator were inadequately heat-sinked, it could have caused internal damage at some point in the flight.That's about the only part of the SD-8 system that's vulnerable.
My system uses the stainless steel firewall as a heat sink... is that sufficient? Do I need conductive paste(?) between it and the firewall? Any other suggestions?
> Check with a voltmeter that you have AC voltage coming in while the engine is running and that the disconnect relay is closing.
So far have only checked the disconnect relay is working ok, it is, and the DC output at the relay. This varied from 12.9 to 12.3 volts depending on load. Are these the figures you'd expect?
I can't seem to find what the SD-8s dc output should be on any website pages! I'd have hoped/thought it would be similar to the main alternators approx 14.7v, is this correct?
Would my results indicate a regulator fault, or should I still check the ac output?
Any help much appreciated.
Kind regards
Patrick C Elliott, Reigate, Surrey, England. G-LGEZ
nuckolls.bob(at)cox.net Guest
Posted: Mon Nov 10, 2008 10:43 am Post subject: Z-13 and SD-8 |
At 10:35 AM 11/10/2008 +0000, you wrote:
| Quote: | Bob.
other suggestions?
ac output?
That's where you need to begin. If there's no power input
to the rectifier/regulator, then there can be no output.
Yes, the output voltage should be on the order of 14.2 to
14.8 volts. The engine RPM will have to be much higher than
ground idle before the alternator comes on line.
