RichWill
Joined: 24 Feb 2006 Posts: 24 Location: Southern Maine
Posted: Sun Mar 12, 2006 10:24 am Post subject: Fitting Formed Windshield - I Could Just Scream |
After "carefully" fussing over several hours of fitting a brand new formed windshield onto my KF3, I was down to the final fitting and trimming... when one final push and tweak.... boom!
I cracked the windshield right at the curve on the leading edge attach point.. It's a 4 inch crack headed inboard...
Any suggestion, recommendation on repairing, stopping the crack from continuing, masking, filling in so it's not noticeable... OR am I stuck with a $500 piece of plastics scrap??
Rich
Kennebunk Maine
Don Cravener
Posted: Sun Mar 12, 2006 10:42 am Post subject: Fitting Formed Windshield - I Could Just Scream |
Rich:
You can stop the crack by drilling a 1/8" dia. hole at
the very end of the crack. Then deburr the hole to make the edges
very smooth.
I have a couple of cracks in a similar area and didn't attempt any
further repair and they have not spread. Doesn't look nice but
has apparently has relieved the stress in this area.
My 2 cents
Don C.
clint_bazzill(at)hotmail. Guest
Posted: Sun Mar 12, 2006 11:07 am Post subject: Fitting Formed Windshield - I Could Just Scream |
How come the Lexan cost that much. I bought a half sheet of 1/4 inch (by
mistake) thought it was 3/16 and installed it on my model IV. No problem,
did increase my VNE to 140 though. My Lexan from Tapp Plactics was about 60
or 70 dollars. Clint
Subject: Fitting Formed Windshield - I Could Just Scream
Date: Sun, 12 Mar 2006 10:24:01 -0800
Rich
Kennebunk Maine
http://forums.matronics.com/viewtopic.php?p=21263#21263
RichWill
Posted: Sun Mar 12, 2006 12:03 pm Post subject: Re: Fitting Formed Windshield - I Could Just Scream |
P/N 1334 Windshield - One Piece with Overhead, extends from cowling to turtledeck - Heat Formed tinted...
$380.60 Clear
$456.90 Tint Plus shipping....
Nice but, expensive...agreed.
iworonko(at)cox.net Guest
Posted: Sun Mar 12, 2006 1:13 pm Post subject: Fitting Formed Windshield - I Could Just Scream |
Rich,
with a magnifying glass find where the crack ends, then go 1/4" in front of
it and drill a 1/8" hole. This should guarantee that your crack will not go
beyond this point. Next , drill a #40 or smaller hole on each side of the
crack close to the edge of your windshield ( hopefully these holes will be
covered up later by the edge fairing) You will use these holes to lace your
crack together after working some Plexiglas glue into the crack. When
working the glue in be careful not to make it crack beyond the stop drill .
Use .020 safety wire for lacing.
You may not be able to get the glue all the way to the end of the crack but
if you get any at all in there it will keep the two halves from moving and
propagating the crack. Access glue can be later removed with a razor blade
and buffed.
Eric
