Posted: Sat Nov 01, 2008 8:09 am Post subject: Screw hardware for instrument panel |
I'm thinking of using black socket head screws for most of the panel.
Stein's blank is setup for #8, the electronic instruments (autopilot,
ADI) are setup for #6. I'm thinking black socket heads will look good
on a tan/brown panel.
What's a good source for black socket heads? A/C Spruce doesn't seem to
do those. Any other thoughts?
Bill "making holes in the panel blank" Watson
40605 in Durham NC
rnewman(at)tcwtech.com Guest
Posted: Sat Nov 01, 2008 8:33 am Post subject: Screw hardware for instrument panel |
Bill, Regardless of what screws you pick, if you go for black oxide
screws you will definetly want to paint them first. Black oxide is not
much of a rust inhibitor and you will have rusted panel screws after a
couple of humidity cycles.
-Bob Newman
40176
Posted: Sat Nov 01, 2008 9:37 am Post subject: Screw hardware for instrument panel |
That's real good to know. Sounds like the voice of experience.
Thanks Bob.
not much of a rust inhibitor and you will have rusted panel screws
after a couple of humidity cycles.
-Bob Newman
40176
Deems Davis
Posted: Sat Nov 01, 2008 9:57 am Post subject: Screw hardware for instrument panel |
Ace hardware, Home Depot, or Lowes
Deems
MauleDriver wrote:
to do those. Any other thoughts?
40605 in Durham NC
Dave(at)AirCraftersLLC.co Guest
Posted: Sat Nov 01, 2008 12:54 pm Post subject: Screw hardware for instrument panel |
Bill,
Try searching for this P/N: 96006A616 at http://www.mcmaster.com/
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
N777TY
Joined: 09 Apr 2006 Posts: 69 Location: Charlotte, NC
Posted: Sat Nov 01, 2008 1:57 pm Post subject: Re: Screw hardware for instrument panel |
I tried those cap screws and then had a change of heart and went to regular black oxide screws... I do love the looks of black oxide against my tan panel.. The heads of those cap screws were too "tall" and I didn't care for that look that much after I saw it all mounted in the plane.. (easy to snag on..)
McMaster is a good place for this kind of hardware.. their selection is hard to beat..
good luck....
Radomir
RV-7A
_________________ RV-7A
N777TY |
