grantr
Posted: Tue Oct 28, 2008 9:14 am Post subject: Tree landings |
I though this would be another good topic to bring up. Tree landings
scare me! Luckily I have mostly open fields where I fly but one end of
our runway has trees and some other obstructions.
Pine trees in particular do not have many branches and the few they
have are located at the top of the trees. So if you had to make a
landing in the pines it's a good chance your airplane will fall right
through the trees and plummet to the ground some 50+ feet. That would
be very bad!
So what do you do if you have a tight road with possible power lines
crossing that you can't see and road signs in close? Take the trees or
attempt the road? Not sure if our light planes would takeout a power
line without losing control.
Have any of you had a tree landings? I guess if you had a
brs it would help in a tree landings since the chute would get tangled
in the trees. I don't have a brs.
Grant
rlaird
Posted: Tue Oct 28, 2008 9:20 am Post subject: Tree landings |
Don't know if it will help, but here's an account of a friends' crash:
http://www.texas-flyer.com/RicksCrash/
On Tue, Oct 28, 2008 at 12:14 PM, grantr <grant_richardson25(at)yahoo.com> wrote:
be very bad!
Grant
http://forums.matronics.com/viewtopic.php?p 10808#210808
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
grantr
Posted: Tue Oct 28, 2008 11:19 am Post subject: Re: Tree landings |
Thanks for sharing that. A single line of trees would definitely not be good.
Really amazed that he wasn't hurt. It looks like he could have landed in the field on the other side of the road.
rlaird
Posted: Tue Oct 28, 2008 11:48 am Post subject: Tree landings |
He's gone over and over the whole thing in his head a thousand times,
and, in 20-20 hindsight, there were lots of options, but as it was
happening, I guess tunnel vision tends to restrict it to what you see
ahead of you. He also freely admits that he had yet to practice any
engine-outs in -that- plane, so he was unfamiliar with how fast it
would descend, and that reached up an bit him.
As for being unhurt, I'd say it was mostly luck, but, the Buccaneer is
a sea-plane, and sea-planes are usually built much more robustly than
land-planes, and that may have had a lot to do with it.
-- Robert
On Tue, Oct 28, 2008 at 2:19 PM, grantr <grant_richardson25(at)yahoo.com> wrote:
http://forums.matronics.com/viewtopic.php?p 10825#210825
Robert Laird
Houston, TX area
Posted: Tue Oct 28, 2008 12:03 pm Post subject: Tree landings |
Good story.
-also a lesson to not diddle getting to the best spot, if any. Too
high is much better than too low.
When close enough for confidence you can do all the other stuff like
flaps, dump slipping,
S-turns. Have to admit I didn't use my flaps going into the high
alfalfa this spring,
but then I was low and slow to begin.
The last good thing to avail is the high drag a kolb has. Just push
the nose down toward your best spot
and head right there. If you are looking at a fence coming up don't
bother with a stall, plant it.
Just before you hit that barbed wire do a ground loop.
-done it all, not much damage.
BB
> end of
> be very bad!
> trees or
> tangled
> Grant
Posted: Tue Oct 28, 2008 12:30 pm Post subject: Tree landings |
A friend of mine's 80 year old dad crashed his Kolb (seems like it was a
firefly) in a tree. I think it was in a woods not a single tree. It was in
the UP of Michigan were there aren't many single trees. Any way, he didn't
get hurt and I don't think the plane was hurt much either. He did sprain an
ankle climbing down to the ground. The next time he flew the plane, he
crashed the Kolb in a river. Again he wasn't hurt. Another story recovering
the plane from the river After that he was grounded from flying so there
were no more crashes.
Rick Neilsen
Redrive VW powered MKIIIC
grantr
Possums
Posted: Tue Oct 28, 2008 1:24 pm Post subject: Tree landings |
Here's one with a 20 mph crosswind landing,
flipped him up, over and upside down into the trees before he
ever touched down in. Four of us made it down before him and he was
dragging behind everybody because of his floats.
We were actually eating lunch at the other end of the runway (couldn't see him)
when we first heard his engine go from
normal to this God awful "full throttle/chain saw" sound.
You might notice that his "nose" never touched the ground.
Got a Wrecker to pick his plane up and put it on the runway.
He towed it home - one less Possum.
Another one of us landing into our home field with a almost new
Firestar II. Missed the
downwind turn, totaled the plane, in the woods big time, EMT's Ambulance,
Sheriff's deputies, FAA the next day, etc.
Tore the wings off coming through the trees full throttle back 300 ft
in the woods..
All he did was break his arm and wouldn't have had that if he had
keep his arm inside
the cockpit. He was still strapped into the cage and mumbling about
something or other. Later he said he couldn't remember anything after he
hit the first tree.
There used to be big trees where these houses are.
http://video.google.com/videoplay?docid 63159682459782825&hl=en
Description: |
Filesize: |
135.61 KB |
Viewed: |
366 Time(s) |
Description: |
Filesize: |
57.46 KB |
Viewed: |
426 Time(s) |
Description: |
Filesize: |
53.14 KB |
Viewed: |
406 Time(s) |
_________________ Possum |
Dana
Posted: Tue Oct 28, 2008 1:37 pm Post subject: Tree landings |
At 01:14 PM 10/28/2008, grantr wrote:
Quote: | So what do you do if you have a tight road with possible power lines
I think the trees would be a better choice than power lines. If you hit
the lines at one point it'll snap you around fast; with luck trees you'll
hit both wings and absorb some energy. Going full into the trees is a
better choice than a tree lined road that's narrower than your wingspan.
About a month ago I related my friend's tree landing in his MKIII, due
[apparently] to water in the gas. Probably shouldn't call it a landing
though, it was the classic stall/spin scenario through trying to turn back
to the airport after an the engine failed on takeoff. The better choice,
in retrospect, would have been to go into the water straight ahead. From
the point where he hit the treetops to point of impact was about a 45°
angle. Surgery to try to rebuild his shattered angle is Thursday; his
passenger is sore but recovering from a pelvis cracked in three places.
-Dana
The Definition of an Upgrade: Take old bugs out, put new ones in.
ElleryWeld(at)aol.com Guest
Posted: Tue Oct 28, 2008 4:43 pm Post subject: Tree landings |
Don't fly over anything you don't want to land on if you are worried about your equipment
Ellery in Maine
In a message dated 10/28/2008 12:15:53 P.M. Eastern Standard Time, grant_richardson25(at)yahoo.com writes:
Quote: | --> Kolb-List message posted by: "grantr" <grant_richardson25(at)yahoo.com>
be very bad!
Grant
http://forums.matronics.com/viewtopic.php?p=210808#210808
Play online games for FREE at Games.com! All of your favorites, no registration required and great graphics – [url=http://pr.atwola.com/promoclk/100000075x1211202682x1200689022/aol?redir= http://www.games.com?ncid=emlcntusgame00000001] check it out![/url]
