info(at)bigskymartialarts Guest
Posted: Mon Oct 20, 2008 3:23 am Post subject: Heat and Cowling RV6 |
RV Group,
I have an RV6, changed the oil today and noticed that the bottom cowling has a bubble about 6” in diameter next to the exhaust where it makes the bend from the manifold (closest point to the cowling), obviously the exhaust is to hot for the cowling at this point, from the out side of the cowling you can also just see the bubble. This is now a weaker area of the cowling; I did not build the airplane and am wondering what I should do about the heat first and then the cowling. The cowling may have been like this since my last oil change and perhaps will be something I deal with down the road. I can not imagine this causing a major failure but will probably just become unsightly to a point where it needs to be fixed. Any feed back is wanted and welcome.
Thank you,
John Paul
Montana [quote] [b]
| - The Matronics RV6-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
Painless
Joined: 10 Jan 2006 Posts: 40 Location: Peshtigo, Wisconsin
Posted: Mon Oct 20, 2008 6:34 am Post subject: Heat and Cowling RV6 |
John:
Van's sells a self-adhesive foil heat shield material that you can stick on the inside of the cowl in the area where heat is a factor. Just make sure you clean the area real well so it will adhere. K2R spot remover does real well to suck oil out of the pre-preg type epoxy cowls that Vans now supplies with their kits if that is the type you have. If not, just use naphtha (coleman's lantern fuel) or lacquer thinner.
Jeff Orear
RV6A N782P
Peshtigo, WI
On Oct 18, 2008, at 4:39 PM, John Paul Noyes wrote:
Thank you,
John Paul
Montana
012345678
9
_________________ Jeff Orear
RV6A N782P
Peshtigo, WI |
robertrv607(at)yahoo.com Guest
Posted: Mon Oct 20, 2008 12:10 pm Post subject: Heat and Cowling RV6 |
Jophn: Also you can go to Home Depot
and get the aluminum Insulation they use on homes. It comes in a roll, you
can buy what youneed and tghat is all. It comes with the adhesive ready, for
install..
It has some writing accross, if I remember is the Mgr. or name...
and it is cheap.. too..
hope this is another idea.
for you
bert
rv6a
--- On Mon, 10/20/08, Jeff Orear <jorear(at)new.rr.com> wrote:
Quote: | From: Jeff Orear <jorear(at)new.rr.com>
Subject: Re: Heat and Cowling RV6
To: rv6-list(at)matronics.com
Date: Monday, October 20, 2008, 10:33 AM
John:
Jeff Orear
RV6A N782P
Peshtigo, WI
Thank you,
John Paul
Montana
012345678
9
| 0
_________________[quote][b]
Posted: Tue Oct 21, 2008 3:32 am Post subject: Heat and Cowling RV6 |
Thank you for the suggestion I called Vans this morning and will get the heat shield on, maybe this should be some thing other RV owners should consider before they have a fiberglass issue as I now do.
John Paul
From: owner-rv6-list-server(at)matronics.com [mailto:owner-rv6-list-server(at)matronics.com] On Behalf Of Jeff Orear
Sent: Monday, October 20, 2008 8:34 AM
John:
Jeff Orear
RV6A N782P
Peshtigo, WI
RV Group,
Thank you,
John Paul
Montana
href="http://www.matronics.com/Navigator?RV6-List">http://www.matronics.com/Navigator?RV6-List
Posted: Sat Oct 25, 2008 1:49 pm Post subject: Heat and Cowling RV6 |
John: the first thing, clean the area, sand it to clean the best way you can. not too much
then put a fine coat of super fill,(,, a two part) item goes 2 to one,, read the container
let over night.. then sand smooth.. clean. "Apply , paint I used rustoleum,
heat resistan,, I preferred white...
Once dry,,, put a wide piece of Self Adhesive, Aluminum tape, lbuy anywhere
Auto parts, Home Depot...is about 6" wide.. put a long piece right under the
Exhaust pipes. I might do as many do, perhaps a better way.. I have seen
where they use aluminum sheets instead of tape,, and over the entire inside of
the cowl....you also get that under home... at home depot,,it has like writing
all over,, my friend at the airpot did that, it looks good,,with some color inside..
and it is fully protected against heat fire etc...
Hope this will help
Bert
RV6a
--- On Sat, 10/18/08, John Paul Noyes <info(at)bigskymartialarts.com> wrote:
Quote: | From: John Paul Noyes <info(at)bigskymartialarts.com>
Subject: Heat and Cowling RV6
Date: Saturday, October 18, 2008, 5:39 PM
RV Group,
Thank you,
John Paul
Montana
Quote: | http://www.matronics.com/Navigator?RV6-List | 012345678
9
Posted: Sat Nov 01, 2008 3:05 pm Post subject: Heat and Cowling RV6 |
jOHN: YOU CAN USE THE ALUMINUM SHEETS HOME DEPOT SELLS, FOR
HOME INSULATION I BELIEVE.
CHEAPER THAN VAN'S,,SAVE SHIPPING TOO.
i USED IT WORKS GREAT... SOME OF THE FELLOWS AROUND MY AIRPORT
SUGGESTED TO ME ALSO, THEY ONLY PUT STRIP, ALONG SIDE THE
LENGTH OF THE MUFFLER, ON BOTH SIDES...IN OTHER WORDS COVERS
THE AREA BOTH SIDES INSIDE THE COWLING, WHERE THE HEAT WILL
DAMAGE THE FIBERGLASS...
NO NEED TO COVER THE ENTIRE COWLING,, BUT I DID, IT AT THE TIME..
ANOTHER SUGGESTION
ROBERTY
RV6A
Subject: RE: Heat and Cowling RV6
Date: Monday, October 20, 2008, 1:37 PM
John Paul
John:
Jeff Orear
RV6A N782P
Peshtigo , WI
RV Group,
Thank you,
John Paul
Montana
et=_blank rel=nofollow>http://www.matronics.com/Navigator?RV6-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
