Sam
Posted: Sun Oct 19, 2008 4:57 pm Post subject: Routing wires point-to-point |
I am getting to route wires, aft of the firewall, and was wondering what kind of methods guys used. The first time I did this, 20+ years ago, the result was a spaghetti bowl.
I am thinking of hanging some loops of wire ties in various spots, then running wires along those paths. When all the wires are in, I would secure with the cromagnum wire ties, rather than the more elegant lacing. It's all hard to access and the ties are decidedly easier.
One recent post referred to wire loom. Is that easy to work with? What about making short conduits?
Lets hear you.
Sam Hoskins
Murphysboro, IL
www.samhoskins.blogspot.com
_________________ Sam Hoskins
www.samhoskins.blogspot.com |
nuckolls.bob(at)cox.net Guest
Posted: Sun Oct 19, 2008 5:53 pm Post subject: Routing wires point-to-point |
At 07:56 PM 10/19/2008 -0500, you wrote:
| Quote: | I am getting to route wires, aft of the firewall, and was wondering what
Lay out your wire routes for finished bundles. Run
some Nylaflow 1/4" tubing on little plastic wire
bundle clamps. You can get the tubing from hardware
stores and big boxes like Home Depot. It's used
to plumb up ice-makers in refrigerators . . . among
other things. The 1/4" clamps can be had from most
'real' hardware stores . . . or you can simply make up
a little band clamp out of tin-can metal. These are
temporary. Install the clamps at the same attach points
that you plan to use for finished bundle supports.
Use bond studs, nutplates, etc.
Lay your 'real' wire bundles up along side these
Nylaflow road markers. Get a wad of el-chesso tie
wraps from Harbor Freight to hold each new wire into
place cutting off ties underneath new wires as they
become surplus.
After your bundles are all finished. cut out segments
of Nylaflow and Replace throwaway ties with good tie
wraps or string ties. Replace your temporary bundle
support clamps with the real ones.
This technique allows you to set the wire-way for
bundles that are many strands from self-supporting.
This allows you to apply finishing restraints in an
orderly cutting the forms away as you go after the
bundles are completely finished.
You can also use heavy copper wire #10AWG solid
ground wire is generally stiff enough. You may find
other materials that will do as well.
( -Thomas Paine 1776- )
dale.r(at)cox.net Guest
Posted: Sun Oct 19, 2008 6:22 pm Post subject: Routing wires point-to-point |
Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)cox.net>
become surplus.
It might be worth noting that the new self-sticking (double-
sided) velcro strips make excellent temporary, reusable
bundle ties. When done with the wiring, replace them with
one's preferred permanent ties, and reuse the temps on the
next bundle being assembled. And they are easily available
from your friendly local H.D. aviation supply store.
(Home Depot)
Dale R.
jaybannist(at)cs.com Guest
Posted: Mon Oct 20, 2008 3:57 am Post subject: Routing wires point-to-point |
I found a very temporary type of "velcro" at the garden department of Lowes. It is green in color since it is meant for use on plant materials. It is "sticky" enough, but not nearly as hard to un-do as regular Velcro. Great for temporary bundling.
I also found a "plenum rated" type of Velcro that I used as a permanent tie in several places. This material is fire resistant and made for above-the-ceiling wiring (where it is required by most building codes) and in data centers.
Jay in Dallas
Sam
Posted: Mon Oct 20, 2008 4:07 am Post subject: Routing wires point-to-point |
Sounds like an excellent tip, Bob. I even have some Nylaflow tubing in the hangar.
I'll start today.
Sam Hoskins
On Sun, Oct 19, 2008 at 8:52 PM, Robert L. Nuckolls, III <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)>
| Quote: | I am getting to route wires, aft of the firewall, and was wondering what kind of methods guys used. The first time I did this, 20+ years ago, the result was a spaghetti bowl.
become surplus.
echristley(at)nc.rr.com Guest
Posted: Mon Oct 20, 2008 5:06 am Post subject: Routing wires point-to-point |
Dale Rogers wrote:
(Home Depot)
Dale R.
Why replace the velcro, Dale? What is wrong with leaving the velcro as
the permanent attachment?
longg(at)pjm.com Guest
Posted: Mon Oct 20, 2008 5:53 am Post subject: Routing wires point-to-point |
I just passed through the same dilemma. What to do, what to do. On my
bird the wings may be detached for fuel line maintenance or perhaps
transport at some point, so I decided to install one DB15 connector in
the fuselage to handle trim and wing lights which need to be loose to
detach the wings.
I wanted to use the trailer type connectors but had no luck finding the
necessary 5-pole jobs (Lowes, Home Depot, Wal-Mart, Hardware, Pep Boys
etc.) so gave up and decided a good male/female db connector setup held
the most promise. I hope to never separate the two, but you never know.
After initial run-up etc I plan to pull the wings and flush the tanks
out once more. I take the approach of doing everything for the sake of
future maintenance. If your fuel lines have connectors between the stub
and the wing that may be one more reason for taking the wings off to
replace hoses or fix a leak.
It's Murphy's law, what goes up will need maintenance when it comes
down.
Glenn
Speedy11(at)aol.com Guest
Posted: Mon Oct 20, 2008 10:08 am Post subject: Routing wires point-to-point |
Sam,
I believe Bob's technique to be the best. I did mine that way and it was relatively straight forwarded - even for a beginner like me. One suggestion is that when you buy the el-cheeso tie wraps from Harbor Freight - buy red ones or orange ones (or some other color you wouldn't want on your plane's wiring). That way when you are ready to replace them with higher quality ties, finding the correct ones to remove and replace will not be difficult. Don't ask me how I discovered this.
Stan Sutterfield
| Quote: | Lay your 'real' wire bundles up along side these
become surplus.
bundles are completely finished. |
New MapQuest Local shows what's happening at your destination. Dining, Movies, Events, News & m2/aol?redir=http://local.mapquest.com/?ncid=emlcntnew00000002">Try it out!
Posted: Mon Oct 20, 2008 7:20 pm Post subject: Routing wires point-to-point |
At 09:52 AM 10/20/2008 -0400, you wrote:
detach the wings.
Are you paralleling some of the pins per . . .
http://aeroelectric.com/Pictures/Schematics/D-Sub_Power_Dist_1.jpg
Posted: Tue Oct 21, 2008 10:04 am Post subject: Routing wires point-to-point |
Good point. Max is 2 amps for either trim or led strobe lights, so I
should be ok?
Glenn
Posted: Tue Oct 21, 2008 2:54 pm Post subject: Routing wires point-to-point |
At 02:00 PM 10/21/2008 -0400, you wrote:
should be ok?
Yup.
Landing lights get bigger tho . . .
