rv10(at)sinkrate.com Guest
Posted: Sat Oct 18, 2008 9:25 am Post subject: fuel pump wiring |
How are people routing the wiring for their fuel pump and potentially their floscan in the tunnel? Are you routing the wires back and under the seats or forward and up the fuselage? Just curious what ways people have done this... pictures are always nice.
THX
-Ben Westfall
__________ Information from ESET NOD32 Antivirus, version of virus signature database 3534 (20081018) __________
The message was checked by ESET NOD32 Antivirus.
Deems Davis
Posted: Sat Oct 18, 2008 9:52 am Post subject: fuel pump wiring |
Forward and up the firewall
http://deemsrv10.com/album/Sec%2037%20Fuel%20System/slides/DSC06423.html
Deems Davis
Ben Westfall wrote:
THX
-Ben Westfall
Tim Olson
Posted: Sat Oct 18, 2008 10:17 am Post subject: fuel pump wiring |
Ben,
I think you can go either direction if you want. I ran mine back
and under the seats and forward...that's kind of the long way
around but it did let me keep the tunnel cover pretty
sealed up. You'll notice that the cover has a hole where it
allows your brake lines through. If you run wires up, you'll
want to enlarge and protect the edges of that hole. That
#1 flying RV-10 had wires run up there in a bundle with no
protection between the wires and the tunnel cover, and they
were pushed out and rubbing on the tunnel cover's metal
edge. As long as you take care to protect the wires
and give clearance, you can go that route.
I went the other way just to stay away from that tunnel
cover gap, the lower firewall heat by the exhaust, and
because it was an easy wire run to get under the seats
where I also had control stick wires to route to the
panel anyway.
To each his own on this one.
Ben Westfall wrote:
| Quote: | How are people routing the wiring for their fuel pump and potentially
THX
-Ben Westfall
AV8ORJWC
Posted: Sat Oct 18, 2008 10:50 am Post subject: fuel pump wiring |
Tim and Deems have both offered excellent pointers. Dan Checkoway did quite a bit (his RV7 website) on failures of his wire support brackets (Clickbond, DP100, 10 minute epoxy, electric tie wraps and two way tape) along with chafing damage on both wire and sheet aluminum. All of that in his RV7's first year of operation.
The SFAR88 mods that are such a nemesis at work, are a result of 20th century (WWII) wiring techniques which needed updating on 21st Century aircraft. Standoffs, distance between supports, routing, proper size of wire, bundling techniques, heat buildup and a plethora of data lead me to say "Ask Stein". A little wire here, a little more wire there and it adds to grams, to ounces, to pounds, and finally to reduced "Useable" weight. You can always pencil whip your GW limitation to keep the VANS approved Useable number (as was recommended by a Hired Gun), "I sure don't encourage that without Static Loading of the Wings and Landing Gear to the new penciled number".
The standard is yours to establish.
"Trust the force Ben".
The Turbanator - John Cox
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall
Sent: Saturday, October 18, 2008 10:25 AM
Subject: fuel pump wiring
THX
-Ben Westfall
The message was checked by ESET NOD32 Antivirus. [quote] [/b][/b][/b][/b]http://www.matronics.com/Navigator?RV10-List[/b]http://forums.matronics.com[/b]http://www.matronics.com/contribution [b]
Posted: Sat Oct 18, 2008 3:29 pm Post subject: fuel pump wiring |
I see no reason to route the wires aft ..... they'll end up terminating
behind the instrument panel anyway. Unless I'm missing something. What
prompted the question???
Linn ..... Odyssey running .... on the bench.
Ben Westfall wrote:
THX
-Ben Westfall
