First Flight
ding(at)tbscc.com
PostPosted: Sun Oct 12, 2008 5:13 pm    Post subject: First Flight Reply with quote
Zenith 601 XL / Corvair N4ZK made it's maiden voyage tonight. It has a standard recipe William Wynne conversion, and performance is excellent. Climbout is strong and handling easy. I have no performance numbers to share yet, as I was more concerned at this early stage with just monitoring critical temps and airspeed. EGT and CHT were well below the max indicators I placed on the guage faces, but oil temp did keep creeping up, and required me to throttle back to arrest the trend after a while. This plane is fast and smooth, and my single landing so far was easy. High idle speed carried me a ways down the runway, and that will be addressed in time. It seemed to take quite a bit of elevator trim to bring the nose up and remove the pressure from the stick. It's possible I'll need to adjust the elevator angle a bit, but too soon to say. It's currently 1 deg. down. A very nice handling plane, and I'm looking forward to burning off some of those pesky Phase one hours. I'll share more as I gather performance data and tweak things if needed. Keep building !!
Lynn Dingfelder
601 XL / Corvair Corry, PA. ding(at)tbscc.com (ding(at)tbscc.com)
amyvega2005(at)earthlink.
PostPosted: Sun Oct 12, 2008 5:34 pm    Post subject: First Flight Reply with quote
difelder my man! i think we met at Russ's place at ZPH. COngrats
JUan
TxDave
PostPosted: Sun Oct 12, 2008 10:08 pm    Post subject: Re: First Flight Reply with quote
Congrats Lynn. Thanks for sharing your triumph with the group. I look forward to hearing more reports.
Dave Clay
Temple, TX
sdthatcher
PostPosted: Mon Oct 13, 2008 1:26 am    Post subject: Re: First Flight Reply with quote
Congratulations Lynn! That first flight has to go down as one of the most heart pounding, adrenaline rushing experiences ever... unless you do test flights for a living Cool That heaviness seems to be fairly common as mine is also very heavy, yet well within the CG. I talked to Scott L. awhile back and he said his stabilizer was down in front and up in back and now flies hands-off. I'm looking forward to that day, although he does have about 30 lbs back in the baggage area as well. Again congratulations.
Scott Thatcher
N601EL w/Corvair E-LSA
16 hours and climbing
Scott Thatcher, Port Saint Lucie, FL
601XL with Corvair, Registered as E-LSA
N601EL, EAA203 140 hours and not flying currently.
Gig Giacona
PostPosted: Mon Oct 13, 2008 5:29 am    Post subject: Re: First Flight Reply with quote
Congratulations!!!
At what temp did you oil temp peak and which of WW's oil cooling systems do you have? The remote or the newer on the engine version.
W.R. "Gig" Giacona
601XL Under Construction
n801bh(at)netzero.com
PostPosted: Mon Oct 13, 2008 5:34 am    Post subject: First Flight Reply with quote
Congrats to you...
Fly safe.
Ben Haas
N801BH
www.haaspowerair.com
                Lynn Dingfelder
">http://www.matronics.com/Navigator?Zenith-List
tronics.com
www.matronics.com/contribution
[url=_blank]Need cash? Apply now for a credit loan with fast approval.[/url]
PatrickW
PostPosted: Mon Oct 13, 2008 8:12 am    Post subject: Re: First Flight Reply with quote
Great news! Congrats on your accomplishment. Smile
- Pat
leinad
PostPosted: Mon Oct 13, 2008 3:26 pm    Post subject: Re: First Flight Reply with quote
Lynn,
Congrats! I love it when I hear about another Corvair powered Zodiac making it to the skys.
Dan Dempsey
601XL Plans Builder/Corvair
[quote="ding(at)tbscc.com"]Zenith 601 XL / Corvair N4ZK made it's maiden voyage tonight. .....
Lynn Dingfelder
