patreilly43(at)hotmail.co Guest
Posted: Fri Oct 10, 2008 3:07 pm Post subject: Model IV pre-formed windshield |
Giovanni C When I drill plexi C I heat it to around 120 degrees with a heat gun. I check the temp with a laser thermometer. It seems to stop cracking when drilling or sawing. Give it a test see if it helps.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Subject: RE: Re: Model IV pre-formed windshield
Date: Fri C 10 Oct 2008 02:49:56 +0000
.ExternalClass .EC_hmmessage P {padding:0px;} .ExternalClass body.EC_hmmessage {font-size:10pt;font-family:Tahoma;} Check with a local comercial glass installer and see if they can get it for you on one of their shipments. Probably get it for a good bit less. Also C if you can get it in 4X10 you will have enough for the next time you want to change it also. Jim Chuk Kitfox 4 building Mn
Quote: | Subject: Re: Model IV pre-formed windshield
Date: Thu C 9 Oct 2008 15:17:38 -0700
--> Kitfox-List message posted by: "Giovanni Day" <thedays(at)mchsi.com>
Called about a 4x8 sheet today and it was $213 until the next shipment when it will go up again. The preformed is going to cost about $500 to buy and get here. I have replaced three of the non-preformed ones in the last 1.5 years and it is growing old. The first one broke after being on for several months but never flown. It was the old rhino 0.125 that came with the kit in the 90s. The next two were plexiglass not lexan so I guess I was asking for it with those. I want something that will last a long time and look nice.
Anyone else??
_______________________________________
Giovanni Day
Model 4 speedster 912
http://forums.matronics.com/viewtopic.php?p=208098#208098
See how Windows Mobile brings your life together—at home C wor2mrt/direct/01/' target='_new'>See Now
Quote: | [b]
target=_blank>http://www.matronics.com/Navigator?Kitfox-List
=_blank>http://www.matronics.com/contribution
| [/b] [quote][b]
gary.algate(at)sandvik.co Guest
Posted: Fri Oct 10, 2008 5:56 pm Post subject: Model IV pre-formed windshield |
Malcolm - if the cracks are large (pick up with a fingernail) I have seen people drill a small hole at the end of the crack as to terminate it, I don't know that I would use acetone as even standard gas will craze the lexan on a warm day.
If I were you I would just replace it with a new lexan screen. It is quite an easy job and only takes a couple of hours. I got really good at it as mu=y panel tank on my previous Kitfox had a filler right in front of the windscreen - On hot days I would sometimes splash some gas on the screen while filling and this immediately crazed the lower part of the screen. After about three I ended up removing the panel tank filler and only filled the wing tank!
Gary
Classic 4 Jabiru 2200
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
Malcolm Brubaker <brubakermal(at)yahoo.com>
Sent by: owner-kitfox-list-server(at)matronics.com
11/10/2008 12:22 AM
Please respond to
kitfox-list(at)matronics.com To
kitfox-list(at)matronics.com cc
Subject
Re: Re: Model IV pre-formed windshield
I have a mod 2 w/ Lexine it is starting to crack /craze? around the top outside edge neer the sharpest bend my a-n-p suggested a dab of acetone to stop the cracks? but there is at least 30 of them on each side.the Lexine is at least 8 years old and still looks very good probably because of the way I clean it. any suggestions on how to keep the cracks from getting any worse? Malcolm Michigan
--- On Thu, 10/9/08, gary.algate(at)sandvik.com <gary.algate(at)sandvik.com> wrote:
From: gary.algate(at)sandvik.com <gary.algate(at)sandvik.com>
Subject: Re: Re: Model IV pre-formed windshield
Date: Thursday, October 9, 2008, 11:25 PM
It has to be trimmed to size and it is formed from Acrylic . It is hard and quite brittle but once fitted correctly is optically clear and distortion free.
Minor scratches that develop can be polished out so this is quite a benefit.
Mine is also tinted - damn I'm going to have to fit it now!
Gary Algate
10/10/2008 09:24 AM
Please respond to
To
Subject
What Chemistry is the LP Aero? Does it have to be trimmed at the edges?
Thanks again.
Giovanni Day
http://forums.matronics.com/viewtopic.php?p 8103#208103
-Matt Dralle, List Admin.
FORUMS -
Site -
