david.nelson(at)pobox.com Guest
Posted: Mon Oct 06, 2008 10:55 am Post subject: Copper buss-bar from copper tubing |
Hi Bob,
I'm having a heck of a time finding either brass or copper sheet/straps to
make the contactor-to-contactor buss bars. The 'KS Engineering'
(spelling?) display seems to have become quite rare in the likes of Lowes,
Home Depot, and Ace Hardware.
Looking around the shop, I was thinking of taking some 1/2" annealed (ie.
soft) copper tubing and flattening it out in a vise w/ smooth jaws to make
some ~3/4" "bar" with a thinkness of around .098" (I think the wall
thinkness is .049, IIRC). I was then thinking of silver soldering brass
washers though that that may be overkill.
If my math is right, this comes out to something around 93500 CM which is
somewhere between 1 and 0 AWG. While this may seem overkill, I chose 1/2"
over 3/8" tubing to allow plenty of edge distance (a little over 1/4")
around the 5/16" contactor bolts.
Do you have any concerns of using this method?
Thank you,
/\/elson
JOE RONCO
Joined: 04 Aug 2007 Posts: 31 Location: CENTENNIAL COLORADO
Posted: Mon Oct 06, 2008 11:33 am Post subject: Copper buss-bar from copper tubing |
DAVID: Go to http://www.mcmaster.com/ and search for Page 3610. There is a
large selection of copper bar stock.
Joe R
lists(at)stevet.net Guest
Posted: Mon Oct 06, 2008 12:06 pm Post subject: Copper buss-bar from copper tubing |
Try a hobby store. They are most likely to have those products.
On Oct 6, 2008, at 11:54 AM, David E. Nelson wrote:
Hi Bob,
straps to make the contactor-to-contactor buss bars. The 'KS
Engineering' (spelling?) display seems to have become quite rare in
the likes of Lowes, Home Depot, and Ace Hardware.
(ie. soft) copper tubing and flattening it out in a vise w/ smooth
jaws to make some ~3/4" "bar" with a thinkness of around .098" (I
think the wall thinkness is .049, IIRC). I was then thinking of
silver soldering brass washers though that that may be overkill.
which is somewhere between 1 and 0 AWG. While this may seem
overkill, I chose 1/2" over 3/8" tubing to allow plenty of edge
distance (a little over 1/4") around the 5/16" contactor bolts.
Thank you,
/\/elson
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Mon Oct 06, 2008 12:20 pm Post subject: Copper buss-bar from copper tubing |
I found the K&S display at a hobby shop. They might also be at craft stores.
In lieu of that, the flattened tubing is an accepted, time-honored method in
the experimental world.
Greg Young
[quote] --
JOHN TIPTON
Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
Posted: Mon Oct 06, 2008 1:39 pm Post subject: Copper buss-bar from copper tubing |
Hi All,
It appears that I've miscommunicated my intentions via the subject line as
I should not have used the word 'buss-bar'. Sorry about that.
What I was aiming for was the big copper jumpers between the master relay,
starter contactor, and the ANL current limiter base that are mounted on
the firewall of an RV-7A.
/\/elson
~~ Lately my memory seems to be like a steel trap .... without any spring. ~~
nuckolls.bob(at)cox.net Guest
Posted: Mon Oct 06, 2008 3:17 pm Post subject: Copper buss-bar from copper tubing |
Joe R
riggs_la(at)yahoo.com Guest
Posted: Mon Oct 06, 2008 3:40 pm Post subject: Copper buss-bar from copper tubing |
Hi Joe,
Thanks for the lead. Wow, McMaster just seems to have everything. Wouldn't it
be nice to be able to just stroll through the isles?
Anyways, looked at the available stock. They seem to only stock "Temper: Hard
(H04)" for the sizes that I'm interested in. Just how "hard" is H04? I need
to be able to put either a 90 deg bend or a twist (depending on where I put the
ANL current limiter block).
/\/elson
Joe R
mike109g6(at)insideconnec Guest
Posted: Mon Oct 06, 2008 3:46 pm Post subject: Copper buss-bar from copper tubing |
Nelson,
AircraftSpruce, Wag aero, Chief, Onlinemetals.com sell the copper bar that
you need.
Mike H 9A/8A
Posted: Mon Oct 06, 2008 3:49 pm Post subject: Copper buss-bar from copper tubing |
Hi Steve,
That was next on my list. Honestly, I'm getting tired of driving around with
zero results and dumb looks by clerks/staff. While I could phone ahead to some
of the places, getting somebody knowledgeable has, in the past, proven to be
somewhat of an "experience".
The materials I listed I've in the garage and I could assemble them in little
time. I'm hoping that Bob will look favorably at my approach and maybe help
somebody else that may be in the same situation as me. If not, that's Ok, too.
Then on to "Plan B" - whatever that might be.
/\/elson
On Mon, 6 Oct 2008, Steve Thomas wrote:
> <david.nelson(at)pobox.com>
> Hi Bob,
> Thank you,
> /\/elson
Posted: Mon Oct 06, 2008 4:03 pm Post subject: Copper buss-bar from copper tubing |
Hi Bob,
Thank you for replying. From Joe's email, I was reviewing the selections.
I'll either need to twist or bend a tab from the relay/contactor to the ANL
current limiter block. My main concern here is the 'Hard (H04) Temper'
characteristic. I have no idea how to relate to 'H04'. Do you have any
comparative annecdotes?
Thank you,
/\/elson
On Mon, 6 Oct 2008, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)cox.net>
> Joe R
Posted: Mon Oct 06, 2008 4:06 pm Post subject: Copper buss-bar from copper tubing |
Hi Lynn,
I considered that part with my recent order from B&C. However, from a previous
email on this list (dated Sun, 18 May 2008 13:15:58 -0500), the .5" width was
considered marginal for the edge distance even though it has performed well in
the field. I was looking for a better alternative.
/\/elson
On Mon, 6 Oct 2008, Lynn Riggs wrote:
Try here.
http://www.bandc.biz/cgi-bin/ez-catalog/cat_display.cgi?26X358218
Lynn A. Riggs
http://home.comcast.net/~lariggs/wsb/html/view.cgi-home.html-.html
Posted: Mon Oct 06, 2008 4:18 pm Post subject: Copper buss-bar from copper tubing |
At 06:49 PM 10/6/2008 -0500, you wrote:
Hi Steve,
with zero results and dumb looks by clerks/staff. While I could phone
ahead to some of the places, getting somebody knowledgeable has, in the
past, proven to be somewhat of an "experience".
little time. I'm hoping that Bob will look favorably at my approach and
maybe help somebody else that may be in the same situation as me. If not,
that's Ok, too. Then on to "Plan B" - whatever that might be.
Many folks have done what you've proposed. I'm aware
of no particular difficulties.
Posted: Mon Oct 06, 2008 4:21 pm Post subject: Copper buss-bar from copper tubing |
At 07:06 PM 10/6/2008 -0500, you wrote:
Hi Lynn,
previous email on this list (dated Sun, 18 May 2008 13:15:58 -0500), the
.5" width was considered marginal for the edge distance even though it has
performed well in the field. I was looking for a better alternative.
That IS bus bar stock made from brass (several
times higher resistance than copper) but narrow
enough for use at the relatively low currents
experienced at the breaker panel.
For conductors in the cranking current path,
real copper is much better.
Bob. . .
Posted: Mon Oct 06, 2008 4:22 pm Post subject: Copper buss-bar from copper tubing |
At 07:00 PM 10/6/2008 -0500, you wrote:
Hi Bob,
ANL current limiter block. My main concern here is the 'Hard (H04) Temper'
I don't think you're going to find copper in any
harness that will make your task difficult.
dale.r(at)cox.net Guest
Posted: Mon Oct 06, 2008 7:23 pm Post subject: Copper buss-bar from copper tubing |
> Hi Bob,
> selections. I'll either need to twist or bend a tab from the
> relay/contactor to the ANL current limiter block. My main concern
> here is the 'Hard (H04) Temper' characteristic. I have no idea how to
> relate to 'H04'. Do you have any comparative annecdotes?
And ... flattening the ends of copper tubing will work-harden it. You
may want to anneal it after you get the fit right.
Dale R.
COZY MkIV #0497
Ch. 13
