merlin
Joined: 05 Oct 2008 Posts: 15 Location: Fair Play, S.C.
TxDave
Posted: Sun Oct 05, 2008 8:06 am Post subject: Re: 601XL Construction Sequence (component) |
If you're building in a garage or other small space, I would recommend building your wings before the fuselage. The finished fuselage will take up a lot of space. The wings can be easily stored out of the way.
Flaps and ailerons would be a good next step.
This is just my humble opinion. Other folks may feel differently.
Dave Clay
Temple, TX
bryanmmartin
Posted: Sun Oct 05, 2008 12:38 pm Post subject: 601XL Construction Sequence (component) |
The wings are easier to build than the fuselage and, when completed, take up less storage space.
_________________ --
Bryan Martin
do not archive. |
Ron Lendon
Posted: Sun Oct 05, 2008 5:35 pm Post subject: Re: 601XL Construction Sequence (component) |
Tail, Wings, Fuselage is the build process I'm using. As the wings get finished I will have to store them somewhere to make room for the Fuselage/
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
Gig Giacona
Posted: Mon Oct 06, 2008 8:56 am Post subject: Re: 601XL Construction Sequence (component) |
Tails, wings, fuselage.
One reason for this is the build manual is sort of geared that way in that the fuselage section makes some assumptions about the knowledge you would have picked up building the wings. Also, you need the center spar to build the fuselage and it comes with the wing kit.
601XL Under Construction
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Mon Oct 06, 2008 3:45 pm Post subject: Re: 601XL Construction Sequence (component) |
I built tail, then flaps/ailerons, then wings. Now on fuselage.
While waiting for component kits from Zenith, I worked on building my engine.
Have fun!
- Pat
