peter(at)sportingaero.com Guest
Posted: Mon Oct 06, 2008 1:22 pm Post subject: Electronic Ignition problem - any suggestions? |
Hi All, I'm posting this for a friend who is not a member and is trying
to diagnose an electronic ignition problem. Any thoughts would be
gratefully received.
I have an interesting problem with my electronic ignition that I'd
appreciate further opinion on. My RV6 has an O-320 with a Slick magneto
on the left drive and Electroair EIS on the right drive. The EIS is a
dual coil, lost spark system (each coil fires 2 opposing cylinders on
both compression and exhaust stroke), and has been successfully operated
for 480 hours.
The problem is that each time I go to take off the engine misfires when
full power is applied. I am getting 2150 rpm static, and as the plane
accelerates at full power, after 10-15 seconds the engine starts to
misfire. The misfires occur at roughly 1-2 seconds frequency and last
for 200-700 milliseconds. There is never any backfiring.
I've conducted one flight, and found that as soon as I eased the climb
and reduced power, the problem went away. I was able to fly at 2,600 rpm
with no problems, and could not re-create the misfire whilst airborne.
Because there is no backfiring, I initially assumed a problem with fuel
supply. This has been eliminated, and I have been testing the ignition
system whilst static on the ground.
I connected an oscilloscope input to an ignition lead and the trace gave
large spikes at every 1/2 engine revolution as expected. However,
intermediate lower amplitude spikes were also observed at 2/3 to 3/4 of
the main spike period. This occurs throughout the full rev range,
including clean running.
I also tested the signal output from the magneto timing housing. It was
found to have irregular modulation and an irregular gap.
I don't know what signal the processor unit can tolerate, but I think
that the irregular signal from the timing sensor may be the issue.
However, the manufacturer still suggests that the charge is arcing out
through either the leads or plugs.
Having replaced both the leads and plugs, and that there's no evidence
or arcing through either the power or earth connections, I think it's a
fault with the unit.
One significant point is that when I turn off the EIS, the engine runs
perfectly on the single magneto. When the EIS is turned back on and the
misfire occurs, I would expect the magneto to continue firing as normal.
I think it probably is, but there's no fuel left to burn and the
misfiring is caused by wrongly timed sparks from the EIS igniting fuel
in the cylinders before the mixture is compressed and ignited by the
magneto.
Am I missing something? Any thoughts would be much appreciated
Regards, James
RV6 G-JSRV
jindoguy(at)gmail.com Guest
Posted: Mon Oct 06, 2008 2:22 pm Post subject: Electronic Ignition problem - any suggestions? |
Peter, I once had a vehicle with a conventional points ignition system and the same problems. The answer was exactly as Electroair is telling you. The vehicle was an early Ford Econoline Van, the kind with the engine in a metal doghouse between the driver and passenger seats. I left the cover off one night to try and diagnose the misfiring by ear and sorted it out by eye instead. Most amazing light show I've ever seen so close up. New plug wires with a high temperature rated silicone insulation did the trick. If you're running car plugs for the EIS system I'd make new plug wires, as A: it's the quickest to eliminate on the list of probables, B: Costs little as airplane parts go, C: If the condition doesn't change you're in a better position to ask for more help from Electroair, and D: If it does work you're flyin' again.
Rick
On Mon, Oct 6, 2008 at 4:20 PM, Peter Pengilly <peter(at)sportingaero.com (peter(at)sportingaero.com)> wrote:
[quote] --> AeroElectric-List message posted by: "Peter Pengilly" <peter(at)sportingaero.com (peter(at)sportingaero.com)>
for 480 hours.
magneto.
Regards, James
RV6 G-JSRV
klehman(at)albedo.net Guest
Posted: Mon Oct 06, 2008 3:20 pm Post subject: Electronic Ignition problem - any suggestions? |
I wouldn't waste any time thinking about this until first replacing the
spark plugs (seriously) and then the wires but apparently that has been
done. I've also seen failing ignition coils do what you describe.
Electroair coils look like GM automotive coils which would mean they may
be cheap to replace??
A multi tooth pickup wheel will have a repeating irregular pulse pattern
AND the pulse voltage will vary accordingly. All teeth are not evenly
spaced or there is at least one tooth missing to establish timing. I
don't know how reliable the Electroair pickup has been but it would not
be my first suspect.
A scope will show an amazing amount of noise on both primary and
secondary sides of these coils. As long as it is a regular repeating
pattern, it is probably normal. Yes they are of similar voltage to what
fires the plugs. I'd only be suspicious if they are non repeating spikes.
Ken
Peter Pengilly wrote:
for 480 hours.
magneto.
Regards, James
RV6 G-JSRV
