582 Oil Reservoir
Goto page Previous  1, 2, 3
thesupe(at)hotmail.com
PostPosted: Mon Oct 06, 2008 6:33 am    Post subject: 582 Oil Reservoir Reply with quote
The picture is right side up C the Avids mounted the engine inverted. Also C I meant to say about the gauges questions C check barnstormers or ebay for instruments. Sometimes you can get a good deal there. There was a guy on Ebaythat bought out a dealers supply and he was selling a dual EGT for about $30. I posted a message on here a few months ago about a Kitfox airspeed indicator for $60 on ebay C that was the guy with lots of other instruments. If you find the message C you should be able to track him down. Also C last week a guy named Tony Wright had a bunch of adds on Barnstormers and I think he had some EGT gauges also. I bought a carb temp. gauge from him. Jim Chuk Kitfox 4 building. Mn
From: matronics(at)bob.brennan.nameTo: kitfox-list(at)matronics.comSubject: RE: Kitfox-List: 582 Oil ReservoirDate: Mon C 6 Oct 2008 10:00:45 -0400
That is how I pictured it Jim C although maybe a bit closer to the cylinders C not that it probably matters.
It looks like there is some discoloration at the probe holes C probably from exhaust escaping? That's why I was thinking a bit of manifold goop-sealer-stuff might be a good idea(?)
Also - is the picture upside down or the engine?
Bob Brennan - N717GB
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Jim_and_Lucy ChukSent: 06 October 2008 9:20 amTo: kitfox-list(at)matronics.comSubject: RE: 582 Oil Reservoir
I should have thaought about haveing pictures that show this last night C but better late than never they say. This was a picture of my Avid MK IV with 582 before I changed it to the Jabiru engine. Also C look at the probes in a catalog C they come installed in the hose clamp from the factory. Jim Chuk Kitfox 4 building Avid MK IV flying Mn> From: matronics(at)bob.brennan.name> To: kitfox-list(at)matronics.com> Subject: RE: 582 Oil Reservoir> Date: Mon C 6 Oct 2008 08:47:16 -0400> > I can picture the clamp (attached) > > Bob Brennan - N717GB> 1991 UK Model 2 ELSA Kitfox> Rotax 582 with 3 blade prop> Wrightsville Pa > > --
Lynn Matteson
PostPosted: Mon Oct 06, 2008 11:32 am    Post subject: 582 Oil Reservoir Reply with quote
Off topic...how'd you do the picture insert with no framing or
background around it? Very cool!
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 562 hrs, and counting...all systems are NOT go, and I'm
back to flying/testing/"guinea pigging"...damn it!
On Oct 6, 2008, at 8:47 AM, Bob Brennan wrote:
[quote] I can picture the clamp (attached)
Wrightsville Pa
Lynn
Kitfox IV-Jabiru 2200
N369LM
PostPosted: Mon Oct 06, 2008 12:42 pm    Post subject: 582 Oil Reservoir Reply with quote
Went to http://www.aircraftspruce.com/catalog/inpages/westegt6.php and
drag-and-dropped the picture onto the reply email. Easy Wink
Maybe I should have given ACS credit? (copyright!!)
bob
gary.algate(at)sandvik.co
PostPosted: Mon Oct 06, 2008 2:03 pm    Post subject: 582 Oil Reservoir Reply with quote
Bob
I wouldn't right off the fuel sensor too quickly - apart from the obvious benefits of knowing exactly how much fuel you have remaining and the real time fuel burn I also find it is a great tool for setting up for cruise at the best possible fuel burn rate. Sometimes by just changing RPM marginally you can pick up significant savings in fuel burn.
This has a lot to do with prop loading and engine power curve and when used in conjunction with EGT monitoring you really get a great understanding of what your engine is doing.
Gary
Gary Algate
Classic 4 Jabiru 2200
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission. [quote][b]
PostPosted: Mon Oct 06, 2008 2:10 pm    Post subject: 582 Oil Reservoir Reply with quote
Already ordered it Gary - I agree with everything you say! I'm going to install it just past a new gascolator, the old one is getting a bit tired and leaky.
Bob Brennan - N717GB 1991 UK Model 2 ELSA Kitfox
Wrightsville Pa
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of gary.algate(at)sandvik.com
Sent: 06 October 2008 6:01 pm
Bob
Gary
Gary Algate
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Lynn Matteson
PostPosted: Mon Oct 06, 2008 2:12 pm    Post subject: 582 Oil Reservoir Reply with quote
It's very surprising that it came out that clean. Usually a picture
will carry some kind of background with it, and therefore bring some
sort of "framing" with it. That one didn't, and came out very clean.
Credit? Maybe by giving their website, you ARE giving them
credit...at least that's what I'd tell my lawyer (gag!) to say I
intended. : )
OFF TOPIC...do not archive
Lynn Matteson
Kitfox IV Speedster
On Oct 6, 2008, at 4:41 PM, Bob Brennan wrote:
<matronics(at)bob.brennan.name>
bob
Lynn
N369LM
Page 3 of 3
