Olfa knife
stepinwolf
PostPosted: Thu Oct 02, 2008 7:32 am    Post subject: Olfa knife Reply with quote
Andy,
Any chance you might have the sku# for the knife. I am in Canada, and when I inquired about the " laminate " type knife, they all gave me the funny look, and responded that since they knew nothing about it, most probably it wasen't available in Canada.
regards
Bob the 701 + 750 scratch
Three Rivers,
Quebec
Long wing + vga's, = lo & slo
dbortol
PostPosted: Thu Oct 02, 2008 8:12 am    Post subject: Olfa knife Reply with quote
From the Home Depot Canada web site:
P-800 Plastic / Laminate Cutter Internet/Cat # 948980 / Store SKU # 410736
Dino Bortolin
Windsor, ON
On Thu, Oct 2, 2008 at 11:30 AM, Robert Pelland <robert.pelland(at)cgocable.ca (robert.pelland(at)cgocable.ca)> wrote:
[quote] Andy,
regards
Three Rivers,
Quebec
jimandmandy(at)yahoo.com
PostPosted: Thu Oct 02, 2008 10:19 am    Post subject: Olfa knife Reply with quote
At least you can get it at Home Depot in Canada. Its not available from any mass market retailer here in the USA.
--- On Thu, 10/2/08, Dino Bortolin <dbortol(at)gmail.com> wrote:
[quote]From: Dino Bortolin <dbortol(at)gmail.com>
Subject: Re: Olfa knife
Date: Thursday, October 2, 2008, 9:11 AM
Dino Bortolin
Windsor, ON
[quote] Andy,
regards
Three Rivers,
Quebec
stepinwolf
PostPosted: Thu Oct 02, 2008 11:29 am    Post subject: Olfa knife Reply with quote
The numbers below refer to the Olfa Series 800 knife, and if you look closely at the original posting, it referred to a different knife, one with a carbide blade, that is not available on the Olfa model.
At the time, it was mentioned in another responce that although it looked like the above Olfa, it was a different model.
regards
malcolmhunt(at)mha1.fsbus
PostPosted: Thu Oct 02, 2008 12:59 pm    Post subject: Olfa knife Reply with quote
Robert
I have just looked at my knife and on the handle it reads ' OLFA P-CUTTER 800 Special Tungsten Steel Blade'.
As I managed to get one in the UK, should be ok in North America, suggest you go onto the Olfa website and get a local stockist.
It is an amazing too I have cut nearly all of my aluminium sheets and am still on the first blade so the 25 spare blades should be ok for another 20 odd aircraft!
Without this knife (and Dave Clay's brake) I would really have struggled.
Hope this helps
Malcolm Hunt
CH601XL Plans Builder in England
TxDave
PostPosted: Thu Oct 02, 2008 1:33 pm    Post subject: Re: Olfa knife Reply with quote
The P800 is the model you need. I got mine at www.olfablades.com
Dave Clay
Temple, TX
stepinwolf
PostPosted: Thu Oct 02, 2008 1:40 pm    Post subject: Olfa knife Reply with quote
Malcolm,
I am happy to hear that you were able to get that much mileage out of your blade. As for myself, I have the exact same knife/blade combo. However not wanting to argue the fact, but when I got through making 5 or 6 swipes on 12' lengths of aluminum, and after having cut 6, 12' sections, the blade ( Special Tungsten Steel ) it showed wear, and needed replacement. When a new blade was finally installed, it was if I had a brand new knife.
The original post mentioned a blade with a " carbide insert " so that is why I was willing to go the extra mile with a second cutter, thinking that it might be even better then the first.
Thank's for your input, and fly safe
regards
Bob the 701 + 750 scratch Three Rivers,
Quebec
