pascal(at)rv10builder.net Guest
Posted: Sat Sep 27, 2008 8:36 pm Post subject: cabin heat cables where and how? |
I can't locate where in the plans it tells one how to run cables for the cabin heat. I see under Section 27 to bolt the Vents but other than the AN3-3A setup there is nothing for the brackets nor cables or anything else.
Any feedback on this is appreciated!
Pascal
dlm46007(at)cox.net Guest
Posted: Sat Sep 27, 2008 9:10 pm Post subject: cabin heat cables where and how? |
The firewall forward runs are in FF1-3. the inside runs are user choice. Mine are two knobs on the right side of the throttle quadrant. see picture
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pascal
Sent: Saturday, September 27, 2008 9:36 PM
To: rv10-list
Subject: cabin heat cables where and how?
Pascal
543.45 KB |
358 Time(s) |
AirMike
Posted: Sun Sep 28, 2008 1:56 pm Post subject: cabin heat cables where and how? |
Note - do not do a permanent install till your panel is all ready to install as the heater cables have to be removed and run thru the hole in the bracket or panel.
_________________ See you OSH '18
Q/B - sold. |
