uvtreith(at)t-online.de Guest
Posted: Sat Sep 27, 2008 2:44 am Post subject: Monowheel Towbar + Handling device |
Hi Europa Family,
In Europa Flyer 55 from December 07 Remi Guerner presents his Monowheel Towbar.
It is easy to make, light weighting and costs nearly nothing.
This Towbar is really good.
The dimensions are in mm (1” = 25,4mm)
Please see attached file
Walter Swoboda made a device to move his Monowheel around the hangar.
He is using a SS square tube, cut to size and shape and just added small wheels to this.
This device you can use, when you do not have the fairings on.
The FTA document is the supplier of the twin swivel wheel (50 mm DIA) plus clamping sleeve to suit the square tube and the wheel stud.
Also these dimensions are in mm-
Please see attached files
Have a nice time and always a safe flying.
Best Regards,
Bruno
Europa Aircraft Germany
| Description: |
| Filesize: |
1.11 MB |
| Viewed: |
181 Time(s) |
| Description: |
| Filesize: |
155.34 KB |
| Viewed: |
171 Time(s) |
| Description: |
 Download |
| Filename: |
FTA_Dokument.pdf |
| Filesize: |
9.46 KB |
| Downloaded: |
259 Time(s) |
