Would like to buy an XS monowheel...............Am I mad or
Bryan Allsop
PostPosted: Mon Sep 22, 2008 1:49 pm    Post subject: Would like to buy an XS monowheel...............Am I mad or Reply with quote
I suppose that those who have needed to bolt on fixed undercarriages to a beautiful aeroplane C would wish to justify it.
Whilst I have never "seen" experienced pilots with damaged nose wheels C I know of plenty who have. Meanwhile C the many happy "Mono" flyers quietly fly on C with more fun.
Bryan
> Subject: Re: Would like to buy an XS monowheel..............Am I mad or
Date: Mon C 22 Sep 2008 11:56:23 -0700
--> Europa-List message posted by: "rampil" <ira.rampil(at)gmail.com>
On the other hand C I've seen pilots ranging in experience from newbie
to 747 senior captain prop strike and ground loop with damage
monowheels.
I for one C spent too much time building my trike to risk the airframe
and engine like that. Building was fun C but flying is more fun.
Cheers C
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=205543#205543
> _========================
Get more out of the Web. Learn 10 hidden secrets of Windows Live. Learn Now
Roger.Mills(at)btinternet
PostPosted: Tue Sep 23, 2008 2:15 am    Post subject: Would like to buy an XS monowheel...............Am I mad or Reply with quote
After 500+ hours with a mono, I can only second what Bryan has said about it being a beautiful aeroplane - but let’s break the silence:
The monowheel has attracted some very unfair commentary. Yes, ideally, you need some taildragger skill or a conversion course to fly it safely. Also, if you’ve got heavy boots or slow reactions, you will have problems. However, if you follow the factory advice of keeping the tail wheel hard down until you gain enough airspeed for adequate rudder and aileron response, then it behaves as well as any other taildragger – i.e. you simply pay attention and be prepared to make minor, quick corrections on the ground run.
While the Tri Gear has its own advantages, the Mono without doubt is lighter, flies faster and is extremely rewarding to fly – don’t let the pundits put you off!
Roger Mills
Europa 141
nwcmc(at)tiscali.co.uk
PostPosted: Tue Sep 23, 2008 3:51 am    Post subject: Would like to buy an XS monowheel...............Am I mad or Reply with quote
Also the monowheel is unique in what it offers with regards to strip operation combined with economical, fast cruise and long range flight. Once you limit yourself to the trigear there are a number of other serious competitors out there.
Nigel Charles
jp(at)brannenworks.com
PostPosted: Tue Sep 23, 2008 5:09 am    Post subject: Would like to buy an XS monowheel...............Am I mad or Reply with quote
Bob,
I do not regard the distinctions between handling characteristics of mono vs trigear as being significant. The mono is more pleasing to the eye etc. I modified my mono to tri for two reasons: with the mono
1. I was unable to retract gear with the rright hand, I also cannot fly other manually retractables, and
2. The high desert strip from which I fly is 30 feet wide and I could not turn the mono around without stopping, and doing it by hand from the ground.
The europa is the most enjoyable plane to fly that I have experienced.
These experiences began with the stearman in 1945. After a half century lay off I retired and took up flying again.
Off strip attributes are not applicable in the high, 6500 ft,desert.
jp
karelvranken(at)hotmail.c
PostPosted: Tue Sep 23, 2008 1:42 pm    Post subject: Would like to buy an XS monowheel...............Am I mad or Reply with quote
Roger and all,
The mono is a purebred.
Karel Vranken, F-PKRL only 200 hours.
garrys(at)tampabay.rr.com
PostPosted: Tue Sep 23, 2008 3:06 pm    Post subject: Would like to buy an XS monowheel...............Am I mad or Reply with quote
Why has every aircraft manufacturer in every country in the world, commercial, military, General, light sport, ultra-lights, rejected the monowheel design?
Garry
rlborger(at)mac.com
PostPosted: Tue Sep 23, 2008 6:50 pm    Post subject: Would like to buy an XS monowheel...............Am I mad or Reply with quote
Garry,
Not completely. The U-2/TR-1 series of aircraft are of the "bicycle" configuration.
Check six,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
(99.9% done) Presently fighting gremlins in the instrument panel.
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Sep 23, 2008, at 18:03, Garry wrote:
[quote]Why has every aircraft manufacturer in every country in the world, commercial, military, General, light sport, ultra-lights, rejected the monowheel design?
Garry
[quote]---
hurstkr(at)redzone.com.au
PostPosted: Tue Sep 23, 2008 7:30 pm    Post subject: Would like to buy an XS monowheel...............Am I mad or Reply with quote
Really! Just to name a few, what about Glassflugel, ASW, Schempp Hirth, Alexander Schleicher, DG Flugzeugbau, SZD, LET not to mention Europa !
acrojim7534(at)YAHOO.COM
PostPosted: Wed Sep 24, 2008 3:55 am    Post subject: Would like to buy an XS monowheel...............Am I mad or Reply with quote
Well... I can name the U-2, and the Harrier as two a/c that have outriggers. If memory serves me correct there was the B-47 several years ago, for starters. Not to mention all the high performance guilders, with the same mono wheel, and no outriggers.....
Jim Brown
--- On Tue, 9/23/08, Garry <garrys(at)tampabay.rr.com> wrote:
[quote]From: Garry <garrys(at)tampabay.rr.com>
Subject: Re: Re: Would like to buy an XS monowheel...............Am I mad or
Date: Tuesday, September 23, 2008, 11:03 PM
_filtered #yiv554562678 { font-family:Calibri;} _filtered #yiv554562678 {margin:72.0pt 72.0pt 72.0pt 72.0pt;} #yiv554562678 P.MsoNormal { FONT-SIZE:11pt;MARGIN:0cm 0cm 0pt;FONT-FAMILY:"Calibri", "sans-serif";} #yiv554562678 LI.MsoNormal { FONT-SIZE:11pt;MARGIN:0cm 0cm 0pt;FONT-FAMILY:"Calibri", "sans-serif";} #yiv554562678 DIV.MsoNormal { FONT-SIZE:11pt;MARGIN:0cm 0cm 0pt;FONT-FAMILY:"Calibri", "sans-serif";} #yiv554562678 A:link { COLOR:blue;TEXT-DECORATION:underline;} #yiv554562678 SPAN.MsoHyperlink { COLOR:blue;TEXT-DECORATION:underline;} #yiv554562678 A:visited { COLOR:purple;TEXT-DECORATION:underline;} #yiv554562678 SPAN.MsoHyperlinkFollowed { COLOR:purple;TEXT-DECORATION:underline;} #yiv554562678 SPAN.EmailStyle17 { COLOR:windowtext;FONT-FAMILY:"Calibri", "sans-serif";} #yiv554562678 MsoChpDefault { } #yiv554562678 DIV.Section1 { } Why has every aircraft manufacturer in every country in the world, commercial, military, General, light sport, ultra-lights, rejected the monowheel design?
Garry
PostPosted: Wed Sep 24, 2008 8:19 am    Post subject: Would like to buy an XS monowheel...............Am I mad or Reply with quote
Garry,
You are perhaps getting the best answer to your question from Booing or Airbus. Don't ask sailplane constructors!
Karel Vranken.
ward.t(at)xtra.co.nz
PostPosted: Wed Sep 24, 2008 8:29 pm    Post subject: Would like to buy an XS monowheel...............Am I mad or Reply with quote
Well said Roger, quite agree. A wonderful aircraft.
12 Waiwetu Street
Fendalton,
Christchurch
NEW ZEALAND
PH 0064 3 3515166
MOB 021 0640221
ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
Roger Mills
Europa 141
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
