malpass
Joined: 27 Aug 2007 Posts: 39 Location: Marietta, Georgia
Posted: Mon Sep 22, 2008 11:33 am Post subject: starters |
I have a kitfox model III , 582 with the starter mounted on the rear of the engine. The starter extends inward of the cabin and the fabricated cover consist of sheet aluminum riveted together to create the cover. All of this fabrication is standard straight out of the construction manual, so this should be a common scenario. I am having starter problems as the bendix gear will not completely engage but rather will touch and make that common grizzly grinding sound. I have cleaned the bendix and it rotates freely but still wont engage. I am trying to get the starter out but the indications are that the engine needs to be slid forward and/or removed to adequately service the starter. Any suggestions to ease my pain on this project?
_________________ kitfox III w/ 582 greyhead |
Fox5flyer Guest
Posted: Mon Sep 22, 2008 11:50 am Post subject: starters |
Remove the engine, remove the starter, then take it apart. More than likely you quickly see what the problem is. Some of the older 582s had flywheel gears that would come apart (break at the bolt holes).
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 397+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
matronics(at)bob.brennan. Guest
Posted: Mon Sep 22, 2008 12:12 pm Post subject: starters |
For starters (pun intended<g>) - are you sure you have a good fully charged battery? Low volts can do that too, and are far easier to fix.
Bob Brennan - N717GB
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Bill Malpass
Sent: 22 September 2008 3:33 pm
Subject: Kitfox-List: starters
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
malpass
Posted: Mon Sep 22, 2008 12:42 pm Post subject: starters |
battery is reading 12.8 volts which is lower than what it should be (at about 13.8 v). Do you think this is the trouble?
Posted: Mon Sep 22, 2008 1:08 pm Post subject: starters |
I had a similar problem with an old battery, about 14 years old. How old is yours? If not new it might be worth replacing just for sh*ts and grins, especially if you think it is reading low. And what you are describing is not a starter or gear problem, it's a solenoid or battery or alternator problem.
Wrightsville Pa
Sent: 22 September 2008 4:42 pm
Subject: Re: Kitfox-List: starters
malpass
Posted: Mon Sep 22, 2008 1:30 pm Post subject: starters |
Thanks- I just found the problem..............One of the 2 broken studs. It allows the starter to skew slightly off center when starting. Just shows that anything can go wrong.
Thanks for the help....................
gary.algate(at)sandvik.co Guest
Posted: Mon Sep 22, 2008 2:44 pm Post subject: starters |
I had the same set up - when you say the bendix rotates freely does it also move forward and engage the ring gear fully when you do it by hand - As I recall there is a small spring in the Bendix assembly - also the starter is mounted on a stack of rubbers and if the mounting bolts are over-torqued it will jam the Bendix assy.
Unfortunately you may have to remove the engine - it's a bit of a pain but once you get into it, it only takes about 45 mins
best regards
Gary
Gary Algate
Classic 4 Jab 2200
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
"Bill Malpass" <malpass-architect(at)comcast.net>
Sent by: owner-kitfox-list-server(at)matronics.com
23/09/2008 05:14 AM
Please respond to
kitfox-list(at)matronics.com To
<kitfox-list(at)matronics.com> cc
Subject
starters
malpass
Posted: Mon Sep 22, 2008 4:46 pm Post subject: starters |
Thanks Gary,
Thanks for your input
paul(at)eucleides.com Guest
Posted: Mon Sep 22, 2008 8:07 pm Post subject: starters |
On Mon, September 22, 2008 1:42 pm, Bill Malpass wrote:
| Quote: | battery is reading 12.8 volts which is lower than what it should be (at about 13.8 v).
Not too likely but charge it up and test first.
Paul A. Franz, P.E.
PAF Consulting Engineers
Office 425.440.9505
Cell 425.241.1618
