XS Trailer
mp.gamble(at)tiscali.co.u
PostPosted: Thu Sep 18, 2008 12:55 pm    Post subject: XS Trailer Reply with quote
Would somebody with access to a europa XS monowheel trailer please measure and let me have the length of the tailwheel track from the rear face of the main wheel support to the forward end before the tow hitch.
I need to know the minimum length of track needed to accommodate the extended tailwheel of the XS.
Mike
rehn(at)rockisland.com
PostPosted: Thu Sep 18, 2008 1:39 pm    Post subject: XS Trailer Reply with quote
Mike
I just happen to have mine a few feet away. Its 13’-5” from back face of tire to the forward end before the tow hitch. Its 3.5” from face of tire to back of I-beam that tail wheel track starts. There are a couple of extra inches of excess track that tail wheel does not use as it is drawn tight towards tow hitch. Hope this makes sense.
Jerry
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Mike Gamble
Sent: Thursday, September 18, 2008 1:53 PM
To: Europa-List(at)Matronics.Com
Subject: XS Trailer
Mike
cjh.richardson(at)virgin.
PostPosted: Fri Sep 19, 2008 1:49 am    Post subject: XS Trailer Reply with quote
Mike,
My trailer accomodated the Mono which had the extended tailwheel mod. i.e. the tailwheel was not under the fuselage as per the early Monos. The tailwheel was under the rudder and the trailer accomodates this.
Hope this helps.
When you get a figure I will measure my trailer to prevent a wasted journey
John.
PostPosted: Fri Sep 19, 2008 3:41 am    Post subject: XS Trailer Reply with quote
Thanks Jerry - just what I needed. I understand that is for the extended tailwheel XS?
Mike
[quote] [b]
PostPosted: Fri Sep 19, 2008 7:24 am    Post subject: XS Trailer Reply with quote
Yea, I have an XS.
Sent: Friday, September 19, 2008 4:41 AM
Subject: Re: XS Trailer
Mike
96victor(at)gmail.com
PostPosted: Fri Sep 19, 2008 8:08 am    Post subject: XS Trailer Reply with quote
Mike, my factory XS trailer for the extended tailwheel measures 15 ft 1 inch for the dimension you asked for. It is a bit short and caused me to have to mount a winch partway over the hitch in order to have adequate lengh.
Tom Friedland
On Fri, Sep 19, 2008 at 8:23 AM, Jerry Rehn <rehn(at)rockisland.com (rehn(at)rockisland.com)> wrote:
Yea, I have an XS.
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of Mike Gamble
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
Mike
[/b]
