steve(at)tomasara.com Guest
Posted: Sun Sep 14, 2008 3:21 pm Post subject: E-Mag P-Mag Safety info - Referenced msg from Mr. Cotner |
************ Forwarded from Canard Aviators list ****************
Fellow fliers,
I received this from a friend on the Bearhawk owners group. I have no
dog in
this fight but feel it is important for everyone to be aware of.
Ric Lee
Sandy, Utah
Received this as a forward to the Bearhawk group.
My name is Gary Cotner Until
August 11th I had flown my Thorp T-18 N57GC for twenty years and 1500
hours without any problems. That all changed. Story to
follow. I will try to keep it very factual and objective.
To all the people on the list and any of the people that you might know
that fly with E-MAG or P-MAG on their planes. I want every body to
forward this to all concerned. I want this to get out to the aviation
community at large. I am going to tell what happened to
me.
I bought two P-MAGS from E-MAG and put them on the plane prior to going
to OSH this year. Flew to OSH and had a good time as usual.
On the trip home about 45 minutes out the engine started having an
intermittent miss. Was going to Kirksville, MO for
fuel, decided to divert to Iowa City, IA. Good thing I did I
almost didn't make it. Had to dead stick land there.
The left P-MAG had failed completely and the right one was
intermittent. I called the E-MAG people and they sent me an E-MAG
and P-MAG to replace the defective ones. Put them on and ran the
tests 6 times and all was well. Full power runs and mag checks went
well. Took off and at about 800 agl the engine started running so
rough that I wasn't sure it would maintain altitude. From the past
experience I needed to get the plane back on the ground before the engine
failed completely. Turned back to runway and was way high to land,
slipped and still running out of room to land. Had to divert to a
closed runway and still short on room got too slow and pancaked in and
totaled the plane. This all because of the E-MAG failures.
I called these people about the crash and they were very nonchalant about
the problem. Said they weren't sure that I in fact had this
failure. Invited them to come to my place and I would run the
Engine for them. to prove the problem. It has been 8 days since I
asked for an answer and no response. I am going to call tomorrow
for an answer as to why they haven't answered my call.
The plane is still in good enough condition to run the engine. I
have since done this and the E-MAG is intermittent and the engine will
back fire when the E-MAG is not firing at its proper time. When
these units fail they can fire at random and cause the engine to quit.
The stress imposed on the crankshaft is very hard and needs to be
addressed as an issue like a sudden stoppage.
I reference Dave's comments below and highly recommend that you GROUND
YOUR plane until you put an other ignition system on it. In other
words don't fly it with E-MAGS or P-MAGS on it. I don't want to see
anyone die because of these units as they have an inherent design
flaw.
The fix that they describe is not a good one,roll pins are very brittle
and subject shattering. plus drilling a hole in the shaft creates a
stress riser and can lead to failure of the shaft.
The shaft should not be able to move at all, the sensor should be
keyed to the shaft.
This item should be removed from the market in it's present design.
All aircraft that are flying with it need to be grounded until they have
a different system on them
I think those of you who are running E-mag products need to be aware
of my experience over the weekend. I am running dual P-mags on my
plane. On the return trip from Waco, TX I developed a rough running
engine in cruise at altitude. At first it was just an occasional
miss or it felt as if the engine was surging slightly. As time went
on the engine ran progressively rougher. Carb heat had no
effect. Mag check, right is fine, engine nearly dies on the
left. Made a precautionary landing at cape girardeau, engine
running terribly, died on rollout, won't restart. When I quit
shaking we eventually determined that the left mag had shifted its timing
by nearly 180 degrees. At the time of the mag check I did not
recognize that the engine would have run fine on the right mag only, I
guess I didn't leave it in that position long enough. Anyway I sent
both mags to E-mag and this is what happened as I understand it.
The mag senses the motor position by a magnet soldered to a brass cap or
sleeve that is attached to the drive shaft by a set screw. Somehow
it loosened up enough that it rotated on the shaft. This has
happened to a small number of others, they were drafting a letter about
it when I spoke to Brad on Tuesday. The fix is they are drilling
the shaft and installing a roll pin so it cannot move. The repair
will be done at no charge. At this time they were not yet
considering it a mandatory update.
As a side note I can't thank Jarod Callis enough for allowing us to
take his T-18 so that we could make it the last hour on
home.
dalamphere(at)comcast.net Guest
Posted: Mon Sep 15, 2008 5:01 am Post subject: E-Mag P-Mag Safety info - Referenced msg from Mr. Cotner |
Thanks to all those concerned for other builder's safety. That's one of the
wonderful benefits of subscribing to a group!
Sure am glad none of the pilots were killed as a result of these failures.
But what a heartache to severely damage a plane that required so much work
to build! It almost sounds like one ignition failed causing
kick-backs/pre-detonation/vibration that broke the other side!
I would like to point out that the fix as I understand it that is posted at
EMag's web-site (and I quote):
"The correction involves 1) replacing the sensor mount with a lighter one
(now only 4 grams), 2) adding a key way to the shaft and the sensor mount,
and 3) drilling and roll-pinning the assembly in place."
It was mentioned in one of the posts that drilling a hole through the shaft
was not acceptable and would create a stress concentration. Please note that
the end of the shaft is necked down in diameter and has a keyway slot milled
out - that sounds to me like a major stress concentration area also - but is
commonly used on magnetos and not a problem to my understanding.
What wasn't said at the EMag site was if they still were using epoxy alone
to hold the magnet into it's mount. If there's some mechanical shape
involved that adds to the integrity of it - good.
In the meantime, as I approach finishing of my plane, I'll probably be
taking the advice of a good friend and go with one conventional magneto and
one (hopefully) fixed EMag product.
Also, is this an issue with O-360's and not others? (O-320, O-235,O-200)
Dave
tim2542(at)sbcglobal.net Guest
Posted: Mon Sep 15, 2008 8:14 am Post subject: E-Mag P-Mag Safety info - Referenced msg from Mr. Cotner |
Dave, if you read Marc Z's account of his problems carefully, you will note
that he was UNABLE to turn off the EMAG in flight. If he had been able to
turn it off he could have continued on without damaging the engine.
Just so you know, it may not be just a matter of turning off the failed Emag
and flying safely on one mag.
Tim Andres
Dave
Posted: Mon Sep 15, 2008 8:58 am Post subject: E-Mag P-Mag Safety info - Referenced msg from Mr. Cotner |
I appreciate your concern. .. but ..
I do not believe that the ignition not shutting off is related to the timing
magnet loosening.
Either the "P" Lead circuit from his ignition switch was broken, the
ignition switch malfunctioning or miswired, or did not switch to running
ignition.
Think about it..
I know it's a VERY emotional issue to have someting that you trust fail, but
let's not give mechanisms sinister minds of their own..
Dave
ftyoder(at)yoderbuilt.com Guest
Posted: Mon Sep 15, 2008 9:03 am Post subject: E-Mag P-Mag Safety info - Referenced msg from Mr. Cotner |
FYI
I installed a Light speed Engineering, Plasma III on my Cont. IO-240 two
years ago and have had NO problems. They have been selling units for over 20
yrs.
I left one mag on just for safety sake and you still get almost all of the
benefits of electronic ignition and save money too.
Great report by Marc and forwarded by Steve.
Thanks, Tim
michele.delsol(at)microsi Guest
Posted: Mon Sep 15, 2008 9:06 am Post subject: E-Mag P-Mag Safety info - Referenced msg from Mr. Cotner |
To all,
The issues on PMags are a concern as I have planned for 2 of them on a
TMX-IO360.
As for shutting down the PMags in flight (it seems that Mark Z had a PMag,
not an Emag), you can't shut it down by just turning the power off because
it will continue generating its own power (above 900 RPM). It does however
have a Plead as regular mags have, which will shut it down by grounding. But
the Plead has to be connected just as on regular mags. Question, did Marc Z
connect his Pleads in such a way that he could shut the PMags down ?
In my set up, I have a regular keyed ignition switch just like regular
magnetos, connecting the Pleads, plus two breaker switches which feed power
to the PMags and LEDS which when lit indicate that the PMags are indeed
getting 12 volts.
Michèle
RV8 - trying to get it finished
-----Message d'origine-----
De : owner-aeroelectric-list-server(at)matronics.com
[mailto:owner-aeroelectric-list-server(at)matronics.com] De la part de Tim
Andres
Envoyé : lundi 15 septembre 2008 18:13
À : aeroelectric-list(at)matronics.com
Objet : RE: E-Mag P-Mag Safety info - Referenced msg from
Mr. Cotner
<tim2542(at)sbcglobal.net>
Tim Andres
Dave
Posted: Mon Sep 15, 2008 11:47 am Post subject: E-Mag P-Mag Safety info - Referenced msg from Mr. Cotner |
FWIW, a misfiring PMAG/EMAG or plain vanilla mag can break a ring in a
second, and hole a piston in little more time than it takes to read this.
Can you turn it off that quick? Whether it was wired correctly or not is not
the real issue. If it losses time (and it's been well documented that they
do) it can do major damage very quickly.
Tim Andres
jpx(at)Qenesis.com Guest
Posted: Tue Sep 16, 2008 7:10 am Post subject: E-Mag P-Mag Safety info - Referenced msg from Mr. Cotner |
Any possibility that grounding the P-Lead would have no effect if the
microcontroller was way too busy handling strangely timed interrupts
due to the timing sensor bouncing around ? That would depend on
whether the P-Lead is a standard input read by the microcontroller, or
goes directly to some circuitry that shuts off the spark outputs.
Anyone know how the circuirty is designed ?
Jeff Page
Dream Aircraft Tundra #10
| Quote: | As for shutting down the PMags in flight (it seems that Mark Z had a PMag,
mlas(at)cox.net Guest
Posted: Tue Sep 16, 2008 7:37 am Post subject: E-Mag P-Mag Safety info - Referenced msg from Mr. Cotner |
Tim,
You bring up the most important issue of unstable timing. If you time
advances at high power it reduces you detonation margin. Their are some
important issues here, one you may not recognize detonation, two you
may/will damage internal components of your engine, and three permanent
damage and/or engine can occur.
I have personally rescued a pilot who landed out on a highway in the
high country of Arizona. He was very lucky that he found a place to
land and no cars were on the road at the time. This could have been a
life altering experience. The recap of the failure mode was attributed
to heat on the emag/pmags. I'm not sure if that was a correct
assessment.
I have been running the Lightspeed Plasma III in a dual configuration
for over 300 hours. I have had one hard failure with one ignition unite
at about 60 hours. Since that repair and upgrade (cooling ports for the
hot AZ summers) both unites have worked perfectly.
I can assure you that if I ever have a problem with maintaining proper
timing that I WILL BECOME A MAGNETO CUSTOMER. Maintaining proper timing
is the difference between being a glider and an airplane. An extreme
example of improper timing is shown by watching a Top Fuel dragster or
funny car go off time. Off timing makes for the BIGGEST explosions in
these cars. Check out You Tube.
Mike Larkin
31 years flying
30 wrenching
8 years professional wrenching
15 years avionics
5 years professional avionics
21 years professional flying
24 years homebuilding
I'm an airplane guy and safety is no. 1
NO COMPROMISING
simon(at)synchronousdesig Guest
Posted: Tue Sep 16, 2008 8:22 am Post subject: E-Mag P-Mag Safety info - Referenced msg from Mr. Cotner |
Jeff, although a good point to bring up, I highly doubt that such an
important function would go to the microprocessor, except as a status input.
Surely it would go to a hard wired shut off circuit outside the micro to
guarantee outside control without software being involved. If it didn't, it
would be a major design error. However, all of these details are most
likely proprietary data, and only Emagair would know.
Simon
Copyright C 2008
Marc Zeitlin
Posted: Tue Sep 16, 2008 9:22 am Post subject: Re: E-Mag P-Mag Safety info - Referenced msg from Mr. Cotner |
I joined the matronics lists to be able to respond to a few of the comments posted here, but don't expect to be a regular.
At any rate:
| dalamphere(at)comcast.net wrote: | | Either the "P" Lead circuit from his ignition switch was broken, the ignition switch malfunctioning or miswired, or did not switch to running ignition. | The Emagair products I had on my engine (one Pmag and one Emag) were both wired with "P" leads, just as the manual explains, and both ignitions were tested with "mag checks" before every flight, including the one in question. In fact, you CAN turn off a Pmag, even with the RPM's above the cutoff of the generator kick-in, with a "P-lead" grounding event, and it had always worked before.
The switch worked correctly for 6.5 years prior to and all tests after the failure event, indicating that the switch and wiring were/are working fine. While in the air, I attempted to run off of one EI, then the other EI, then Both EI's, and saw minor differences in operation in the three cases. After landing and UNPLUGGING the power from the failed EI, the engine ran perfectly on the single remaining EI.
| dalamphere(at)comcast.net wrote: | | I do not believe that the ignition not shutting off is related to the timing magnet loosening. | I don't know what the firmware in the EI assumes, or how it works, and I don't know what the hardware is doing either. All I can tell you is that when the EI failed due to the magnet slippage and the HUGE change in timing, in this one case the EI would NOT shut itself off via "P-lead" grounding. In all other cases of Emagair product failures that I've had (and it's been a substantial number), they've always shut themselves off when grounded, but in this case, it did not.
Believe what you will - I'm certainly more than familiar with believing what I WANT to believe, no matter what the facts of the matter are - just review my usage history with the Emagair products to see that. But the facts are what the facts are.
_________________ Marc J. Zeitlin
marc_zeitlin@alum.mit.edu
http://www.cozybuilders.org/
http://www.mdzeitlin.com/Marc/ |
